Introduction: E.D.C. Pocket First Aid Kit
I have compiled some basic first aid supplies necessary for minor injury's in this small everyday carry "Med Kit"
You will need the following:
1. A small tin of some kind
2. 3 que tips cut in halves
3. A small packed gauze pad
4. Tiny band aids or some other bandage
5. (optional) small butterfly clips
6. Some small Alcohol and antiseptic wipes
7. (optional) a pair on nitrile Gloves
Step 1: Images of Supplies Material
Step 2: Add Your Gauze Pad and Half Que Tips
I recommend trying to fold your gauze in half and it should fit well enough. The que tips should fit with no problem.
Step 3: Add the Bandages
They should fit on top of the gauze.
Step 4: Add the Butterfly Clips
They will fit next to the bandages.
Step 5: Add the Alcohol Wipes and Antiseptic Pads
The alcohol wipes should fit on top of the previous layer, I added 2. The antiseptic pad goes on top of the wipe. I only put one because it was a bit thicker.
Step 6: Optional Nitrile Gloves
If you can I recommend trying to squeeze some gloves into it.
Step 7: YOUR FINISHED!
I added some finishing touches to mine because it would not keep closed. I used hair ties to secure it shut but if you have some thin paper tape you can use that and just break it with your nails when you need it.
