Introduction: EDGE AVOIDING ROBOT
EDGE AVOIDING ROBOT
Step 1:
PARTS-
1 Transistor switch circuit with relay
2 Ir diode and ir led 2 pair
3 Relay h bridge circuit
4 Battery
5 Diy robot chassis
Step 2:
1 hi welcome to the FOURTH part of five part robot series.this is the same transistor switch circuit that i have used in FOLLOW ME ROBOT, LINE FOLLOWING ROBOT AND LIGHT FOLLOWING ROBOT
Step 3:
2 THERE IS A SMALL CHANGE FROM PREVIOUS BUILD I GIVE +SUPPLY TO RELAYS COMMON PIN
THIS MAKE RELAYS NO AND NC PIN EITHER HIGH OR LOW
Step 4:
3 TO DRIVE MOTOR ACCORDING TO THAT HIGH OR LOW SIGNAL I BUILT THIS RELAY BASED H BRIDGE CIRCUIT EACH PAIR OF RELAY DRIVES ONE MOTOR THESE FOUR BLUE WIRES ARE DATA INPUT PINS AND THESE YELLOW AND GREEN WIRE IS FOR CIRCUITS BATTERY SUPPLY TWO PAIR OF RED AND BLACK WIRE FOR MOTORS.AND LAST RED AND BLACK WIRE FOR MOTORS BATTERY SUPPLY
Step 5:
4 this is the circuit diagram.here you can see all connections.
Step 6:
5 ASSEMBLE IT ON MY DIY ROBOT CHASSIS.i am using a cardboard piece to hold sensors
Step 7:
6 lets test it
