Introduction: EEG-Electrode-Tidy-Towel
In University, I worked in an EEG lab. While there was extreamliy interesting work to do, there was also the issue, that the cables of the electrodes we used would tangle very badly, every time they where cleaned and put in a towel to dry. When preparing an experiment, we had to untangel the electrodes and find the right place on the cap, to put them. Once a participant waited for nearly ten minues, until I had untangled and placed the electrodes.
I thought there has to be a better way and after returnig to the problem time and time again, I think I have found it.
EEG-Electrode-Tidy-Towel is based on a simple cleaning towel that you can buy in the supermarked.
Step 1: Painting a Grit
A grit is painted on for better orientation. I used a big ruler and made the lines a bit more than one rouler breath apart from each other. Then I added a horizontal line in the middle between each two horizontal lines.
Step 2: Cutting
Cuts in the towel in regual intervall alow for each electrode to be put in it's own cut.
I made the cuts on the lines, cuting a line segment, not cutting the next line segment. In the next line, I cut the line segments, that where below line segments, that I had not cut.
Step 3: Numbering the Cuts to Find the Electrodes Faster
The cuts are numbert, so that you can easily find the right electrode for each place on the electrode cap.
Place each number abouth the respective cut, so that it is not covered by your hand, when inserting or retrieving the electrode.
Step 4: Usage
The Tidy-Towel is placed on the regular drying towel. Eache electrod is put through the cut coresponding to it's number. To do this press the elctrode on the Tidy-Towel next to the cut, and slide it in the so created opening.
Together the towels are losely wraped around the electrodes. I didn't have oportunity to test this with an actual electrode set, so proceede with caution and I would like to hear about your experiences with this. Thanks for reading Philipp
