Introduction: EGG SHELL
It is a personal shelter, made of cardboard.
For when you want to relax, when you want to stay closed, when you want to work.
Size:
- W : about 1.0 meter
- D : about 1.0 meter
- H : about 1.2 meter
Time required for production: about 1 day
Material
- Corrugated Cardboard - 800 x 800 x 3 (mm) , 10sheets
- MDF - 700 x 400 x 5.5 (mm), 1sheets
- (MDF - 700 x 400 x 2.5, so many * for the seating surface)
Tool
- Laser Cutter - trotec Speedy 300 ( 726 x 432 mm) +link+
- CNC Router - Shopbot ( 2438 x 1219 mm ) +link+
- V-bit 1/2 - inch
* You can make it without having a CNC router. by hand
Software
- Adobe Illustrator CS6
- VCarve +link+
It has published how to create a Shell.
We will release the data of the seating surface, but please make it according to the tool and material when making it.
Step 1: Making Cutting Data (for CNC Routers)
First, let's make machining data with CNC router
(If you make it by hand, please DL the data, then print it and paste it on the material.Then please cut with a cutter.
The blue line is a line that makes a groove. The red line is a tear line)
- Enter the size of the material. (In the case of Corrugated Cardboard 3 mm)
- Set the drill to V-bit and set to cut the blue line by 1 mm.
- Set to cut the red line at 3.2 mm.
- Set the hole to be opened with 3.2 mm
Step 2: Cutting Shell Parts
When you have data, cut the material.(In case of shopbot)
Move the shopbot with the data created in Step 1.
Cut out each required number of parts.
Step 3: Cutting Joint Parts
Cut the MDF(5.5mm) with a laser cutter
Step 4: Assembly
Let's assemble the cut parts.
Joint parts from A to X are fitted in 2 parts for each side of each shell part.
Everything is completed and it is completed
Step 5: Option Seat
Please cut the mdf 2.5 mm with a laser cutter and assemble it.
