Introduction: Eggduino - Eggbot - SphereBot - the Machine for Drawing on Eggs
About: I create projects for my videos that I publish on my YouTube channel
Welcome to this tutorial! With Easter approaching, I will show you how to build an Eduino, a small robotic arm that, thanks to Arduino and Inkscape, can draw on eggs to customize them however you like.
I had to condense many of the construction steps, otherwise this Instructable would have become too long. If anything is unclear, you can watch the video.
Step 1: Motor Assembly
Installing the Egg-Driving Motor
To install this motor, we will use M3x10 screws with 3D-printed spacers to fit them.
Step 2: Assembling the Marker Holder Arm
This motor will be mounted on the lower side using M3x10 screws and spacers, while on the upper side, we will use M3x5 hex socket head screws, recessed into the frame to avoid interference.
Step 3: Servo Installation
We use a 9g servo. To connect it:
  1. Modify the connector: Separate the signal wire (orange) and use a single pin, while the positive and negative wires go into a dual connector.
  2. Position the servo: Route the wire through the groove to prevent it from interfering with the arm.
  3. Secure it with the provided screws.
Step 4: Uploading the Sketch to Arduino
Download the Eggduino.zip file, extract it, and open eggduino.ino using the Arduino IDE. Install the necessary libraries:
  1. AccelStepper (available in the library manager)
  2. SerialCommand (manually installed via ZIP)
Connect Arduino to the PC, select Arduino Uno as the board, and upload the sketch.
Step 5: Assembling the CNC Shield and Drivers
  1. Install the CNC Shield V3 onto the Arduino Uno, ensuring the pins are properly aligned.
  2. Mount the A4988 drivers in the X and Y slots, with the potentiometer facing the power supply.
  3. Configure microstepping using jumpers to achieve 1/16 step resolution.
Step 6: Adjusting the Drivers' Vref
We calculate the Vref based on the motor’s maximum current (from the datasheet) and adjust the potentiometer using a multimeter:
  1. Connect the multimeter's negative probe to GND
  2. Place the positive probe on the potentiometer screw
  3. Adjust until reaching the calculated value
Vref calculation site
Step 7: Power Supply and Final Adjustments
  1. Enable the board by placing a jumper between EN and GND.
  2. Disable auto-reset by soldering a 10μF capacitor between GND and RESET.
  3. Connect the fan to the CNC Shield for cooling.
  4. Secure the power socket and connect the cables.
  5. Connect the motors:
  6. Arm motor → driver Y
  7. Egg motor → driver X
  8. Install the bearings and egg rollers, using rubber to increase friction.
  9. Place the electronics cover and apply the custom logo.
Step 8: Testing With Inkscape
Open Inkscape 0.91 (See documentation) and follow these steps:
  1. Modify the document size to 3200x900 px.
  2. Paste the design you want to print.
  3. Go to Extensions → Eggbot → Eggbot Control.
  4. Set the pen height values (e.g., 55 and 70 for up/down).
  5. Run a test print to check if everything is working correctly.
After the test, you can proceed with the final print!
Step 9: Multicolor Printing Setup
