Introduction: HOW TO MAKE AN ELECTRONIC DRUM.(not a MIDI Sampler) Aka KIDU
This instructable is going to be
about building an electronic drumset(not a MIDI sampler.),using an Arduino UNO R3.,
similar to a V-DRUM.It is code named KIDU.
(Kompact Intelligent Drumming Unit).Some of the items used may be names differently in your locality.ill try to put as
many pictures as posible.
I saw many instructables based on arduino and MIDI outputs.i thought of
making a completely independent instrument(ie with out a laptop).
Advantages:
(unlike V DRUM);
* Very portable and easy to assemble.
(the whole structure fits in a guitar case :-))
* The user can decide which sound each
drum sounds like.One can even record
a sound and upload it into the device
and make that sound from a drum.
(sound quality-16 MHz,16 bit mono)
* You can use as much storage space for saving the sound files.,
depending on the size of the SD card you use.
So a lot of sound styles can be included.For the sake of simplicity .,i used
5 styles of sound.
* There is no base-drum. Instead the kick pedal
contains a trigger.,that simulates a base kick.
* Total cost just a fraction of what the original
V DRUM will cost.I made it under 6000 rupees(~ $107).
* There are no unnecessary buttons and knobs for selecting the drum styles.
I have programmed it in such a way that.,
The drums themselves acts as the buttons.in this example.,i have used the snare
drum to trigger the count,.and the tom1 drum as the select key.
* There is no LCD display to guide you through selecting the drum style and the tones.
but KIDU will narrate every step.,and what style you have selected.
For example.,When KIDU startsup.,it asks you to enter the style count
using the snare drum.Then you hit the snare drum with the drum stick
less than 5 times,to select a drumming style,numbered from 1-5.
General Advantages :
(unlike acoustic drums)
*KIDU can play a large number of percussion styles.,depending on the
sounds that you have saved in it.
*You can directly record the audio output.,on to any device that can
record an audio signal,with out any ambient noise.for an acustic drum
you may need a studio to record it ambient free.
*You can practice it with out disturbing anyone.,by simply connecting
a 3.3mm headphone jack into the output socket.
*You can individually adjust the sensitivity of each of the drums through
program or a control knob.FSOS(for the sake of simplicity)i have excluded
the pots.I control their sensitivity by adjusting the threshold value in the program
prior to upload.
Step 1: Stuff Needed
*ELECTRONIC STUFF
# Arduino UNO R3
# SD card shield
# USB cable
# 5 V adaptor
# Micro SD card
# Piezo electric transducer(aka piezo disk)
# ribbon wire
# single core shield wire.
# Hook-up Wire.
# Parallel PCB.
# 2 contact jumpers.
# 3.5mm audio jack (male n female)
# Resistors- 1M & 10K (around 10 each)
* HARDWARE STUFF
# PVC PIPE(3.5cm and desired thickness) - 3 meters
# PVC T-junctions
elbows
couplings
stopper
# Thermocoal(real thick).
# Rubber like material(honestly dont kno its fancy name.:)
any material which gives sum rigidity and bounce.i bounght it from a
footwear manufacturing place.they use it for making the shoes soul. )
# Rexin(this material will be the artificial membrane.i used a black cloth
like material.u can use anything to make it look cool.u can even use leather
.it wont affect the way your drum sounds.)
# sumthing that looks cool..,to put your circuitary in.(i used an old laptop
cooler-pad.lot f room inside n looks awesome.)
* TOOLS NEEDED
# Soldering equipments.
# Cutting plier
# Wire Stripper
# Sissors (heavy duty thing)
# Thermocol cutter
# Hack saw
# Measureing instrament.
# Fevicol SR & SH(indian manufacturer for glue used for working with
wood and footwear industry.u can use what ever is used
for the same in your country :P )
# Insulation tape.
# Ducttape or cello tape or masking tape.
# sand paper(of variying grain size for metals.)
# M-seal(a material that can be molded in to any size and sticks)
# Spray paint.(Your choise.i used black.)
* SOFTWARES NEEDED.
# Arduino programming environment.
# SOX (command line format converter)
# FL Studio.
* OTHER STUFF NEEDED.
# A PC to program the Arduino.
# An amplifier to Hear the sound.
Step 2: WORKING
WORKING
In this step,ill try to explain the working of our E DRUM (or KIDU as i call
it) as simple as possible.Il just briefly talk about the steps for
making each subsystem.,and then ill detail them in the following steps.
Since we are working on an electronic drum.,the mechanical impulses(playin
the drum).,needs to be coverted to electric signals.this task is done by the piezo discs.
Each of the drums that we are make will contain 1 such piezo sensor.
When ever a mechanical pressure is applied on the disks.,an electric signal
whose magnitude is proportional to the pressure is produced.
This signal is sent to the Arduinos analog pins(via pulldown resistors.,which i wil explain later)
.Since there are only 6 anaog pins on an UNO.,the no of drums and cymbals used wil be restricted to 6.
We use digital pins to trigger the base kick and the choke.
The arduino is also linked to the SD Card shield.,with the SPI pins.
(ie pins 13 to 10).
Now the program.As you might already know.,the arduino's analog pins.,convert their
analog inputs to a value between 0 and 1024.We program it such that if this
value exeeds a particular thrush hold value.,then fetch the corresponding
audio file from the sd card and play it through a PWM enabled pin.This is
much easier said than done.There are some hurdles that we need to cross
if we need to play an audio file from the SD card directly with out any
audio decoder.(about which ill explain in detail later.)
Another advantage of KIDU is that it does not require any control buttons.
i have programmed it such that the drums themselves can be used to
select the drumming style.
Step 3: MAKING THE FRAME
MAKING THE FRAME
I am not very good at mechanical part of things..,but i tried my best.
for making the drums and the structure or frame.,it used some materials
(not the best materials i kno;)but i used them coz they are easy to work with
and are very cheap and lightweight.
But this step is pretty straight forward.Any one with little imaginatin
can make.Jus follow the structural frame diagram.
For making the frame of the KIDU.,i used PVC pipes with 3.5 cm diameter.
ul need about 3 meters of it.We need to convert this 3 meter pvc into a structure
as shown in the figure.
I could just give you the exact mesurement of the frame components.but
to tell u the truth.,i never had cut them to exact length.i just cut
1 meter pVC and checked if that is the length that i needed.wen i think its
too much i measured and marked a little.i measured the height that i found
comfortable to play.and i measured 4 such pillars.And found out the
lengths of all the components by this trial and error method.but surprisingly
nothing went to waste.Because all the components of the frame were small.
and a lot of connections were there.so i used up almost 2.7 meter.very little was left
over.This was the method i used(the fun way).
But for those who dont like too much fun.,ill measure and mark the on another diagram.
NAMING THE FRAME COMPONENTS.
This is important because.,this is very helpful when we are assembling
it together.It can be very confusing if we have alot of components and
no way to kno which one is which.So i have made up a Structural
frame assembly diagram.With each component a name.
BL2 -BACK LEFT 2
BL1 -BACK LEFT 1
SL1 -SIDE LEFT 1
SL2 -SIDE LEFT 2
FL2 -FRONT LEFT 2
FL1 -FRONT LEFT 1
GL -GOINT LEFT
ML -MIDDLE LEFT
M -MIDDLE
MR -MIDDLE RIGHT
GR -GOINT RIGHT
FR1 -FRONT RIGHT 1
FR2 -FRONT RIGHT 2
SR1 -SIDE RIGHT 1
SR2 -SIDE RIGHT 2
BR1 -BACK RIGHT 1
BR2 -BACK RIGHT 2
(i kno joint is spelled wrong.but i am jus gonna go with it :P )
Now connect the whole thing together,without the drums.and
paint it using spray paint.
TIPS :# name the components on the inside of the pipe and out side.
in case it gets covered in paint.
# while painting remember to keep the spray at atleast 25 cm from the
workpice.contasntly move while spraying to get a fine finish.
# keep the work piece in a newspaper to prevent paint from ruining anything else.
Step 4: MAKING THE DRUM
MAKING THE DRUM
As shown in the diagram.,the drum has 3 layers.Most of the drum is filled with
Thermocol or foam.i used thermocol(better rigidity).I googed the
drum sizes for a standard drum set.and cut 4 circles with these diameters
on a large slab of thermocol.The drum sizes are listed below.Cut the
rexin and boncy materials with the same diameters, as shown in the diagram.
Now at the center of the thermocol cut a cylindrical grove such that the
tail portion of the T junction fits tightly in the hole.Now mark 4 positions
on the Thermocol nearby the portion of the t junction.(keep in mind that this is
only for extra strengrth.the drums wudnt fall off even if the drummer drums it
hard.).
Now that you got an idea on were the t juction would be on the drum,
remove the junction.Now using the sandpaper.,sand the sides of the thermocol
.This is to getrid of any deformations that you may have while cutting.
Make a grove on the thermocoal along the axis.(axis is the imaginary line
on which the pvc pipe would lie on.)
Now apply fevicol (SH grade) on the walls of the grove on the thermocoal
and on the T junction.Do not use SR Grade coz it will melt the thermocol.
(fevicol is the name of the manufacturer in india for glue.ill put
up the picture also. u can use wat ever u have at your country.)And use a piece
of string to tie the T junction and thermocol.,loop the string throung
the groves that we jus cut on the thermocol.now tie it hard tie on the T juncton.Apply the
SR fevicol on the string were it touches the PVC T junction.(bevare not to
tounch SR on the thermocol.)The SR would cause the PVC to melt parcialy
and the thermocol gets fixed on the t junction.
Now take a piezo disk and solder it with 2strand ribbon wire.(strip 2 from a 10 strand ribbon wire)
make sure to insulate the both leads with insulation tape.now solder the other
end of the wires to a female port 3.5mm audio jack.use a smal plastic piece to screw
the jack in.Make sure that the length of the wire is equal to the radious
of the drum.(we dont want any extra wire sticking out of the drum.)
Using the SR glue.,glue the piezo disk on to the center of the
boncy material that we cut out earlier.Use insulation tape to stick the wire a
and the disk on to the circle.Now glue the side containing the piezo disk
onto the thermocol.Make sure that the 3.5jack is properly placed.and can be
pluged in from out side the drum.(Use only SH for sticking with thermocol.)
Now use the SR glue to stick the rexin on to the boncy material.Leave for drying.
Now for painting the drum.I used spray paint(paint-in-a-can).The
problem is that you cannot use this paint dirctly on thermocol.since
it causes the same effect as the SR glue.it melts the whole thing.
So make a coating of duct-tape on top of it before spraying it on.
I also made a coating of news paper and then a coat of duct tape.
(not necessary.)
Apply a coat of paint.Hold the can a good 25 cm from the drum and
spray it contantly moving,to get a good fine finish.or else.,it could be uneven.
Leave to dry.Repeat after 5 min.
This step covers making of the drums.but making the cymbals and the pedals
will be explained in another step.The problem is that i couldnt photograph
the making of the cymbals and foot pedals.I don have them with me at the
moment either.but ill take their photo as soon as i can and upload them too.
Il up load the steps for now.
Tips :# When ever you use a solvent(like fevicol SH or SR)u havnt
worked with before.,always test it on a sample before
applying it on the original.
(i am emphasising this cos i wasted 1 of ma drums by using
SR on thermocol.The whole thing melted into guie slimy slury :( )
# When u fix the jack (fixing the piezo) make sure that the jack would
be on the easily plugable area of the drum.(u don want it to be on the
left or right part of the drum.coz it may be difficuly wen another drum comes
on its side.)
# Always measure and mark the parameters on the drum by using sum permannt
marker.
# We would be cutting the matterial for all the 4 drums together.
so its easy to mark them which drum they belong to.and their axis.
# Always check how it would be on the frame before gluing on anything.
note:- standard drum size as per a website i googled up.
18 x 22 inch bass drum
9 x 12 and 10 x 13 inch rack toms
16 x 16 inch floor tom
5.5 x 14 inch snare drum
Step 5: Making the Console
MAKING THE CONSOLE.
This is basicaly putting all the circuitary in a good looking box.
and neatly puting together a way to establish an easily removable connection
with the drums.
For the console i used an old usb powered laptop-coolerpad.I removed the
fan from the pad and gluedon a small piece of cardboard.I connected the
SD card shield on to the arduino and screwed it on to the cardboard.
Another important circuitary is the pulldown resistors.
As explained earlier.,a piezo disk produces electric signal correspondin to
the pressure applied on it.When we glued the drums together with the piezo
inside.,it produces a signal even if we donot play the drum.So
to over come this problem.,we put pull down resistors( 1M ~ 1.3M )
between the live and the ground leads of the piezo discs.
we could put it with in the dums.but i decided to bring together all the
pull down resistors needed onto a single pcb and put it in the console.
This config makes it easier to do any maintenace if necessarty.
The circuit diagram i very very simple.
I connected 6 female jumper leads to a parallel PCB and
used 6 resistors between each of the leads.Then i shorted 1 of the
leads of all the jumper male pins using hook up wire.Then took the live lead out
of each of the jumper pins and 1 of the shorted leads(for GND) and soldered
each to 1 end of the ribbonwire.i connected small pieces of hookup wire to
the end of ribbon wire(to make it easier for connecting to the Arduino).
and connected these wires to the analog pins and the ground.These pins
were exposed to the exterior so that we could make the connections from outside.
Next we connect the output audio socket(3.5mm female audio) on to the console.
then we solder 2 strand ribbon wire to the ground and live of the socket
and the other end to the hookup wire.(to make easy connection to the
arduino.)Now make another hole on the console to take the piwer line out.
I used the USB cable for programming the arduino for powering ther device.
This way i can use the same line for powering the device and also for
programming it.I connect the USB cable to a 5V USB adapter for powering.
This also reduces the weight in the console due to heavy transformers for
stepdown and more efficiency.
Next the cable system.The cable system that i used was made of
single core shield for best sound quality.Each of the drums,cymbals and the pedals will
need a cable to be connected to the console.Cut approx 1.3 meters of
shield wire.now solder 1 end of the shiel wire to the 3.5mm male jack.
other end to the female part of the jumper wire.
Step 6: Preparing the Sd Card
PREPARING THE SD CARD.
This was the most difficult and time consuming step for me.But ill upload all the
the link for all the audio files that i have prepared.so that those who
find it difficult to follow can use these files and skip this step.
But i must warn you that ull miss a hell lot of fun :) .
link is http://www.4shared.com/rar/AoDU14Vy/KIDU_files.html
Before we touch the sd card,we need to select the sounds that we want our drum
to sound like.For this i used Image line FL studio for making each of the
drum samples in wave format.For those who r not familier with Fl studio,
you can simply google for drum samples and download them.If even that is
too much.,ill upolad the link for the wav files that i have used as well :) .
Once you have decided on the sounds that you want to hear.,lets start converting.
As i told you in the WORKING.,it is not easy to play an audio format
with out a dedicated audio decoder.If we had a WAV shield this would have been
easier.Now for playing the audio file direcly from sd card.,we use the arduino
library called the SimpleSDAudio.h .
For this,library to function, we need the audio files in the .RAW format
and the file name in 8.3 naming format,all present in the root directory of the
SD card.
For converting.,the wave files to raw.,i couldnt find any file converter
softwares that support wav to raw.(total video converter also no good.)
so i used a commmand line converter called SOX.You can Audacity as GUI.
but i used.,the commandline technique.
First you need to install SOX.Now bring all the files that you need to
convert to the same directory that contain the file SOX.exe .
Now open command prompt and direct it to the same directory as SOX.exe
(or create a notepad file in that directory and type command.com and save
it as anything.bat.if u open this file the command prompt opens up with
pointing to the same directory.).Now type in the following command.
cd %~dp0
mkdir converted
sox input.wav --norm=-1 -e unsigned-integer -b 8 -r 62500 -c 1 -t raw "converted\output.raw"
pause
replace input.wav in the above command with the filename that you are using.
& output.raw with the 8.3 file name.(8.3 simpy means an 8 letter name or less,followed by
a '.' & a format in 3 letters eg numb.mp3).So if you have selected the snare sound for conversion.
type.
cd %~dp0
mkdir converted
sox snare.wav --norm=-1 -e unsigned-integer -b 8 -r 62500 -c 1 -t raw "converted\1_snr.raw"
pause
As i have mentioned earlier there is no lcd display.All the selection of the
style and other necessary things are also narrated by the KIDU.So all those
audio files also need to be converted and transfered to the SD card.
For these audio files also i used the speech synthesiser functionality of
FL Studio.You can use any software and obtain the speech audio in wave format.
and then convert to raw usin SOX.I will upload n link these audio files also.
NAMING THE FILES.
This is jus to make the programming a little easier.Be systematic in evrything you do.
NOMENCLATURE
FORMAT <stylecount>_<drumname>.raw
names i have used : for style count 1
1_snr.raw
1_tom1.raw
1_tom2.raw
1_ft.raw
1_cy.raw
1_kick.raw
1_ohh.raw
1_chh.raw
For stylecount 2 replace all the above first letter
by 2.and so on for any number of styles.
The speech files you can name anything.
After you have all the files you need in the raw format.,we can transfer them to
the SD card.For this you can use the windows in built formatter but i recomend
the SD formatter.(do not do quick format.)For SD cards under 2GB format
it as FAT.All others format with FAT32.The library supports both file systems.
Now remove it safly from the PC and insert it inthe SD card shield.
CAUTION:Your computer running on any OS (other than MSDOS) will not be able to
play these RAW files.but not to worry it will play fine in the arduino.if u
are not convinced of its genuinity.,u can convert these file back
to wav or mp3 and play it in your computer.
Step 7: SOURCE CODE
// variables and constants used.
int snare;
int tom1;
int tom2;
int floortom;
int cymbal;
int highhat;
int stylecount=0;
int select=0;
int snarecount;
int tom1choose;
const int snarepin=A0;
const int tom1pin=A1;
const int tom2pin=A2;
const int floortompin=A3;
const int cymbalpin=A4;
const int highhatpin=A5;
#include <SimpleSDAudio.h>
void setup()
Serial.begin(9600);
SdPlay.setSDCSPin(10); // chip select
SdPlay.init(SSDA_MODE_FULLRATE | SSDA_MODE_MONO | SSDA_MODE_AUTOWORKER);
Serial.println("sd ready");
SdPlay.setFile("startup.raw"); // plays the startup tone.
SdPlay.play();
void loop()
////////////////////////////////// reading the analog pins
snarecount=analogRead(snarepin);
tom1choose=analogRead(tom1pin);
tom2=analogRead(tom2pin);
floortom=analogRead(floortompin);
cymbal=analogRead(cymbalpin);
highhat=analogRead(highhatpin);
//////////////////////////////////drum style selection.
if (snarecount>100)
SdPlay.setFile("slctdrm.raw"); // KIDU says "select the drumming stye!"
SdPlay.play();
stylecount=stylecount+1;
if (stylecount>6)
stylecount=1;
///////////////////////////////////////play name of drum style.
if (stylecount==1)
SdPlay.setFile("1_stdstl.raw"); // KIDU says "standard drum set selected!"
SdPlay.play();
if (stylecount==2)
SdPlay.setFile("2_afrcon.raw"); // KIDU says "african-congo style selected!"
SdPlay.play();
if (stylecount==3)
SdPlay.setFile("3_hiho.raw"); // KIDU says "hiphop style selected"
SdPlay.play();
if (stylecount==4)
SdPlay.setFile("4_indian.raw"); // KIDU says "indian style selected"
SdPlay.play();
if (stylecount==5)
SdPlay.setFile("5_funny.raw"); // KIDU says "funny sounds selected"
SdPlay.play();
if (stylecount==6)
SdPlay.setFile("6_demo.raw"); // plays DEMO.
SdPlay.play();
///////____________________count to exit the drums from select pin mode.
if (tom1choose>50)
SdPlay.setFile("selected.raw");
SdPlay.play();
select=select+1;
Serial.println("stylecount=");
Serial.println(stylecount);
Serial.println("select=");
Serial.println(select);
while (select==1)
////////////////////////////////////redefning the variables to be drum sound triggers.
snare=analogRead(snarepin);
tom1=analogRead(tom1pin);
if (snare>50 && stylecount==1)
SdPlay.setFile("1_snare.raw");
SdPlay.play();
Serial.println("snare");
if (tom1>50 && stylecount==1)
SdPlay.setFile("1_tom1.raw");
SdPlay.play();
Serial.println("tom1");
if (tom2>50 && stylecount ==1)
SdPlay.setFile("1_tom2.raw");
SdPlay.play();
Serial.println("tom2");
if (floortom>50 && stylecount==1)
SdPlay.setFile("1_ft.raw");
SdPlay.play();
Serial.println("floortom");
if (cymbal>50 && stylecount==1)
SdPlay.setFile("1_cy.raw");
SdPlay.play();
Serial.println("cymbal");
if (highhat>50 && stylecount==1)
SdPlay.setFile("1_ohh.raw");
SdPlay.play();
Serial.println("open highhat");
//////////////////////////////////////////style 2
if (snare>50 && stylecount==2)
SdPlay.setFile("2_snare.raw");
SdPlay.play();
Serial.println("2snare");
if (tom1>50 && stylecount==2)
SdPlay.setFile("2_tom1.raw");
SdPlay.play();
Serial.println("2tom1");
if (tom2>50 && stylecount ==2)
SdPlay.setFile("2_tom2.raw");
SdPlay.play();
Serial.println("2tom2");
if (floortom>50 && stylecount==2)
SdPlay.setFile("2_ft.raw");
SdPlay.play();
Serial.println("2floortom");
if (cymbal>50 && stylecount==2)
SdPlay.setFile("2_cy.raw");
SdPlay.play();
Serial.println("2cymbal");
if (highhat>50 && stylecount==2)
SdPlay.setFile("2_ohh.raw");
SdPlay.play();
Serial.println("2open highhat");
//////////////////////////////////////////////style3
if (snare>50 && stylecount==3)
SdPlay.setFile("3_snare.raw");
SdPlay.play();
Serial.println("3snare");
if (tom1>50 && stylecount==3)
SdPlay.setFile("3_tom1.raw");
SdPlay.play();
Serial.println("3tom1");
if (tom2>50 && stylecount ==3)
SdPlay.setFile("3_tom2.raw");
SdPlay.play();
Serial.println("3tom2");
if (floortom>50 && stylecount==3)
SdPlay.setFile("3_ft.raw");
SdPlay.play();
Serial.println("3floortom");
if (cymbal>50 && stylecount==3)
SdPlay.setFile("3_cy.raw");
SdPlay.play();
Serial.println("3cymbal");
if (highhat>50 && stylecount==3)
SdPlay.setFile("3_ohh.raw");
SdPlay.play();
Serial.println("3open highhat");
/////////////////////////////////////////indian style
if (snare>50 && stylecount==4)
SdPlay.setFile("4_snare.raw");
SdPlay.play();
Serial.println("4snare");
if (tom1>50 && stylecount==4)
SdPlay.setFile("4_tom1.raw");
SdPlay.play();
Serial.println("4tom1");
if (tom2>50 && stylecount ==4)
SdPlay.setFile("4_tom2.raw");
SdPlay.play();
Serial.println("4tom2");
if (floortom>50 && stylecount==4)
SdPlay.setFile("4_ft.raw");
SdPlay.play();
Serial.println("4floortom");
if (cymbal>50 && stylecount==4)
SdPlay.setFile("4_cy.raw");
SdPlay.play();
Serial.println("4cymbal");
if (highhat>50 && stylecount==4)
SdPlay.setFile("4_ohh.raw");
SdPlay.play();
Serial.println("4open highhat");
////////////STYLE 5 FUNNY
if (snare>50 && stylecount==5)
SdPlay.setFile("5_snare.raw");
SdPlay.play();
Serial.println("5snare");
if (tom1>50 && stylecount==5)
SdPlay.setFile("5_tom1.raw");
SdPlay.play();
Serial.println("5tom1");
if (tom2>50 && stylecount ==5)
SdPlay.setFile("5_tom2.raw");
SdPlay.play();
Serial.println("5tom2");
if (floortom>50 && stylecount==5)
SdPlay.setFile("5_ft.raw");
SdPlay.play();
Serial.println("5floortom");
if (cymbal>50 && stylecount==5)
SdPlay.setFile("5_cy.raw");
SdPlay.play();
Serial.println("5cymbal");
if (highhat>50 && stylecount==5)
SdPlay.setFile("5_ohh.raw");
SdPlay.play();
Serial.println("5open highhat");
if (stylecount==6)
SdPlay.setFile("demo.raw");
SdPlay.play();
Step 8: SOURCE CODE WORKING
SOURCE CODE WORKING
The library that we use to play the audio from the sd card is
SimpleSDAudio.h .,the details of which i have explained indetail in
the stem preparing the SD card.
Now in the sketch.,i have programmes only for 4 drums and a cymbal.
since i have not expained how to make the foot pedals.
i will try my maximum to upload it asap.But i have converted the sounds
for everything(8 components per drum style.)ie for 4 drums,1cymbal,
open highhat & closed high hat.and kick.
As mentioned earlier.,the program uses the drums for triggring aswell.
This was a bit of a chalenge for me.but i made it in the end.
You may notice in the source code that i have done the analog reading twice.,
with 2 drums having diferent variable names each time.
The first time.,we use the snare and tom1 drums for selecting the drum style.
The snare drum is used as the style count.the count goes from 1 to 6
and repeats from 1 again.You can add as much styles as the size of the
SD card you use.You just have to upload all the sounds you need.
There is another count to loop through the next set of analog readings.
this is the select count.wen ever you have set the count with
ypur snare drum,we confrm it by the tom1 drum.once the tom1 drum is hit.,
it would start a select count.When the select count is 1,(ie the first hit on
the tom1 drum),the loop for drum triggering starts.
The drum trigering loop is quite simple.If the analog reading exeeds a thushold
KIDU will sound the corresponding sound.And the loop continious.
eg :if analogread value > thrushold & if stylecount==1
then,play the audio file 1_snare.raw for snare drum.
prog eg:
SdPlay.play();
Now for the program involving kick ahd high-hat,its not very hard.
All we need to do is include part for digital reading a button.
We need to use a simple mono pulse switch and a debouncing function,for the kick.
The debouncing function is present in the examples for
arduino programming environment.and for high hat.,the debouncing and switch parts are the same.
The if loop will have an extra condition each for open anf closed.
ie
if (choke==HIGH && highat>thrushold && stylecount==1)
SdPlay.setFile("1_chh.raw");
SdPlay.play();
Serial.println("closed highhat");
if (choke==LOW && highat>thrushold && stylecount==1)
SdPlay.play();
Step 9: THANX a LOT....!
THANKS A LOT...!
> amandaghassaei. your instructable on an electronic xylaphone helped me.
> www.hackerspace-ffm.de.This is the place were i learned about the simpleSDaudio
library.
http://www.hackerspace-ffm.de/wiki/index.php?title=SimpleSDAudio
>My uncle Dilip Panicker for helping me with conversions.
>My friends for helping and funding...:)..!
anu abhi n kusha.
Step 10: LINK FOR FILES
This is the link for the audio files in RAW and wav and the sox conversion software and the SimpleSDAudio library.
Step 11: ABOUT ME
Hii.,,my name is Jishnu Menon.I am a
B-tech (Electronics and Communication.,NSS Engineering college Palakkad)student.,
from India(Kerala).I am new here.,but i used to surf alot
reading many instructables which has helped me do many of my hobby pros
This is my very first instructable.So if there are any mistakes or
if my explaining is not good enough,please excuse me and
correct me.,so that we all can learn together.After all that is what instructables are all
about.This was my mini project for my previous
semester.So i dont have the project with me at the moment.
i am attempting to make the instructable.,
with the images and diagrams that i took a few months ago.It will contain
all the necessary steps.,but ill update the pictures as soon as i get
it back and try to upload a full working video of it.
the The basic concept is pretty simple.but It is not exactly easy to explain.
But ill do my best.
i would love to have the honor of winning the Epilog Zing 16 Laser cutter from instractables.
In India it is very difficult to get such gadjets.And is very expensive too.There are no
companies in India that produces electronic drums.so i am planing to start a small sale setup for
its production.i have succusfully done the controller part without the arduino.now i have to integrate the
SD card shield and the controller into one single chip.But it is not gonna be easy to
make the mechanical parts.I intend to make it more stronger one than the present version.so such a tool as the Epilog Zing 16 Laser cutter
would be very handy.winning comes second.participation comes first.
Epilog Challenge V
62 Comments
7 months ago
The link is dead (no more working). Can you please send me the files via email please sir.
theweerakkodi@gmail.com
11 months ago
amazig project, nice friend, unfortunately the link of the kidu files is not available, would you be so kind as to tell me where I can download them? Thanks and good luck.
1 year ago
This the the best project on edrum so far.yes if you don't own a PC or Midi device you can use it.good job.but there should be a backwards stylecount so if you by pass the style you want, you can get back to it with the back count.also try and use 3 buttons for BACK,SELECT,NEXT. Thank you.
Question 2 years ago
can you send this file (http://www.4shared.com/rar/AoDU14Vy/KIDU_files.html) to my mail
6 years ago
can i hit 2 pad at the same time :3 im just curious
Reply 6 years ago on Introduction
technically no. the latest hit will over write the previous sound. but i made my drumsounds so small in size and duration that one hardly notice that.I am currently working ona drum that can play 4 sounds simultaniously..
Reply 3 years ago
Hi, congratulations... I think use one Arduino for same pad to simultaniosly sounds to independents. Thx
Any progress on the polyphonic drums? :)
3 years ago
how to make this with stereo output ??
4 years ago
I think he answered somewhere below:
"Pin 9 for uno and 53 for mega"
4 years ago
after reading all, i still trting to find what pin to use for audio output.
7 years ago on Introduction
just updated the instructable with the links for the files that you may need,.
Reply 4 years ago
would u give me the updated link please
4 years ago
I amazed by your great project , i just need the diagram of connection between arduino mega and the sd reader , and if it's possible to adjust velocity So when i trigger in low velocity the file play in low volume and so on ?
5 years ago
could a similar project be done with 1sheeld over bluetooth and piezo sensors and sound files in the sd card of phone ?
Using a phone would also give us a screen and so much more...
i am very new to arduino
5 years ago
can you use a guitar hero drum kit as the frame
5 years ago
can i build it with no wave shield and with just one sample into arduino's memory? i have a sample with 15kb 16bit and 16mhz or a converted sample w 6kb 8bit 24mhz
Reply 5 years ago
Yes, its possible. There is an ardhino library for it. You need to encode the audio sample into PCM format and store it the arduino memory. And use the library toplay it. I think the library s name was PCM . I must say that the audio quality was very bad. I dont think the PCM library could play an audio sample above a particular quality. And the tempo and pitch were all wrong too. The arduino memory is another huge constrain . I could use only an audio clip which is about 2 seconds long on arduino uno. Bottom line is it works . but i couldnt get thr required quality or number of clips out of it. If you try it out, do let us know how it worked for you.
5 years ago on Step 11
Cool instructible Jishnu. Just thinking that you could add velocity sensing buy watching the peak amplitude of the trigger inputs then adjusting the output amplitude accordingly.
Reply 5 years ago on Step 11
Oh, yes That did cross my mind, I Don't know if the library I use supports real time amplitude adjustment . But I could store sound samples with different amplitudes and play them with respect to the trigger peak amplitude. I also thought of doing that to get different sounds when I hit different parts of the drum by using 2 piezos in 1 drum and different sounds for different piezo value combinations. I also though of doing amplitude adjustment with a digital potentiometer connected to the output of the sound out and adjusting that value in accordance to the peak amplitude value. I don't know if any of thee will even work. And I am so busy with the job and other stuff that I cant even try out any of these. :( Thanks for the Suggestion though... :)
