Introduction: EMP Generator DIY
Simple EMP generator DIY
Step 1: Welding Coil
i must put the coil and pcb together
Step 2: Soldering the Positive and Negative Wires
i use a 9v battery socket,and cut it in the middle,so i can use the 9v battery as the power
Step 3: Use a Box to Hold All the Parts
make some hole on the box,and put the coil on the head,add a switch,so i can click switch to start EMP
Step 4: Triode Sc2078
sc2078,it be used for drive the coil
Step 5: 9v Battery
i use 3pcs battery,but i think use 5pcs is better,over 36v is dangerous,so i just use 3pcs
Step 6: Antenna
i add an antenna on the head,i think it is better for enhance the EMP,but i am not sure about this
