Introduction: ENG 371 Scooper
Hydraulic Scooper Demonstration
Step 1: Cut Out Cardboard:
Cut out c 2 rectangles for arms (12”x2.5”), 2 large squares for base (6”x6”), 2 trapezoids for the base stand arms (8” long, 6” wide at bottom, 3” wide at top), 2 rectangles for scooper (4”x2.5”), 1 rectangle for scooper (6.5”x4”), 1 rectangle for scooper (3.5”x2.5”), 6 squares for dowel reinforcement (1”x1”)
Step 2: Make Base
Glue (2) 6”x6” pieces of cardboard together to make a base
Step 3: Make Base Arms
Glue (2) 8”x6”x3” trapezoid shaped cardboard pieces together to make the base stand arms. Long side down on base, (2) trapezoids should be 1 ¾” apart centered on the base
Step 4: Dowel Hole for Arm
Poke one hole at the top of each base stand arm using a pencil, about an inch from the top of the arm in the center
Step 5: Insert Dowel
Insert wooden dowel into the holes you just poked and glue it to the sides with a 1 ¾” gap
Step 6: Reinforce Dowel Ends
Poke holes into the center of (4) 1”x1” square cardboard pieces, put (2) square pieces on the ends at the top of the base stand arms
Step 7: Connect Arms
Poke a hole on the end of each 12”x2.5” arm, slide arms onto the end of the wooden dowel connected to the base stand arms. Slide (2) 1”x1” squares over the ends of the wooden dowel and glue it
Step 8: Poke Holes for Arm Dowel
Cut the corners off the edge of the arms, poke a hole on the center of each end of the arms about ¼” from the edge
Step 9: Construct Scooper
Make the scooper: fold 6.5”x4” cardboard piece around the (2) 4”x2.5” cardboard pieces and glue it all together, let the glue cure
Step 10: Make Scooper Arm Connector
Make a trifold on the 3.5”x2.5” cardboard piece, glue the center fold to the end of the scooper you just made and poke a hole on each outside fold in the center
Step 11: Attach Scooper to Arm
Attach the trifold of the scooper to the end of the arms with a wooden dowel, glue a 1”x1” square cardboard piece to each end of the arm
Step 12: Lengthen Syringe End Area
Cut a popsicle stick in half, glue one half of the popsicle stick to the end of a syringe
Step 13: Attach Syringe to Base Arm
Poke 4 holes for 2 zip ties to connect the syringe to the stand arms, connect the syringe with a popsicle stick on the end to a base arm and zip tie it using the holes you made. Cut the excess zip tie with a wire cutter or scissors
Step 14: Fill Syringe and Tubing With Water
Cut 2 feet of clear tubing off. Fill a new syringe and tubing with water and insert the tubing onto the end of the syringe. Try to avoid air bubbles as much as possible
Step 15: Complete Hydraulic System
Connect the syringe and tubing to the syringe connected to the base arm
Step 16: Connect Syringe to the Arm
Poke 4 more holes for 2 zip ties like step 13, but this time onto the end of the scoopers arm. Attach a new syringe to the scooper arm using 2 zip ties
Step 17: Finish Hydraulic
Repeat step 14 and connect this new syringe to the syringe located on the scoopers arm
