Introduction: ESP 32 Project Board
This DIY kit will give you a much easier environment to access most of the functionality of the ESP32. We have created this project board to allow you to access these functions easily and quickly. You can build many different projects with this ESP32 project board. Many of our step-by-step projects will use this board to make things easier to build,
Difficulty rating: Advanced
Average time to build: 30 minutes
Project Diagram
How the ESP 32 Project Board works
The picture above shows all the components that come with the kit.
Step 1:
Place all Resistors, Diodes, and solder pins (always start with the lowest components, this will make soldering easy when flipping the PCB when soldering bottom.) Please ensure that the polarity of the diodes is correct, A simple way of knowing is, that the line on the diode needs to be in the same direction as the squared bracket line on the board.
Step 2:
Place the next highest components Led, Transistor take extra care on soldering the transistor for shorts between legs.
Step 3:
Place 2Pin and 3Pin connectors then solder pins(this will be the next highest components.)
Step 4:
Place next highest level components headers, caps, relay and regulator last the inductor.
Step 5:
Finally, we can inspect the board for any shorts or missing soldering pins.
If all looks good we can power the board and choose you combination of components. We can do a simple test to see if the ESP32 project board works by simply testing a blink LED
