Introduction: ESP32-CAM Capture Photos and Send Through E-mail Using SPIFF Memmory. ||NO SD Card Required
Hello Folks,
The ESP32-CAM board is a low cost development board that combines an ESP32-S chip, an OV2640 camera, several GPIOs to connect peripherals and a microSD card slot. It has a number of applications ranges from video streaming web server, build a surveillance camera, take photos, face recognition and detection, and much more.
A few days ago I wonder if I could send a photo captured by ESP32-CAM through E-mail. I found many tutorials on ESP32-CAM capturing photos using ESP32-CAM; saving photos to SD card . So I decided to gather all these applications to one place. The SD-card is not a cost-effective solution for ESP32-CAM because we hardly need 500 KB for storing photo. So I tried to research if I could ignore the usage of SD-Card or replace it with some other memory.
I was so excited to know that there is enough memory available in ESP-32 flash memory called SPIFF memory. So I decided to use this solution and avoid the use of using external SD card hence reducing the cost of my project.
So in this tutorial, I will show how to:
1. Getting started with your ESP-32 CAM
2. Using SPIFF to store Captured photos
3. Using SMTP to send Email the captured photos
ESP32-CAM
FTDI programmer
F2F jumper wires
Step 1: Getting Start With ESP32-CAM Using FTDI Programmer
Arduino IDE can be used to program ESP32-CAM AI-Thinker development board. One of the major draw back of ESP32-CAM is that it does not have USB interface for uploading the sketches. So you will be required an external FTDI programmer for programming the ESP-32.Follow the schematics showed in the picture provided in the description.
ESP32-CAM FTDI Programmer
GND GND
5V VCC (5V)
U0R TX
U0T RX
GPIO0 GND
This guide shows how to program and upload code to the ESP32-CAM (AI-Thinker) development board using Arduino IDE.The ESP32-CAM AI-Thinker module is an ESP32 development board with an OV2640 camera, microSD card support, on-board flash lamp and several GPIOs to connect peripherals. However, it doesn’t have a built-in programmer. You need an FTDI programmer to connect it to your computer and upload code.
NOTE: The ESP-32 CAM can only be programmed when it is in Flash mode. For enabling the flash mode of ESP32-CAM you have to attach GPIO0 with GND.
After uploading code you need to take out the GPIO 0 wire to disable the flash mode and run the ESP-32 to in normal mode.
Step 2: Upload the Web Server Example for Testing the ESP32-CAM
Before uploading the email sketch you need to make sure that your ESP32-CAM is working perfectly. For this upload the web-server example from ESP32->camera->web-server. The following configration should be set:
Board: ESP32 Wrover Module
Port: your port #
// Select camera model
CAMERA_MODEL_AI_THINKER
comment all other models.
set SSID and Password to your Wifi Access point and upload the sketch.
if you can see the video streaming from ESP32-CAM you are ready to upload the email sketch.
Step 3: Change Gmail Account Settings (Less Secure App Access)
For the first time your ESP32-CAM might not get access to gmail services. So you need to change the privacy settings by accessing
https://myaccount.google.com/lesssecureapps
allow the less secure app to access your account.
Step 4: Upload the E-mail Application Sketch
Download the sketch given in the description, provide the following parameters:
#define emailSenderAccount
#define emailSenderPassword
#define emailRecipient
SSID
Password
That's it upload the sketch.
