Introduction: ESP32-CAM RC Car
Remote Controlled Car using ESP32-CAM board (Ai Thinker).
  1. 01 - ESP32-CAM board
  2. 01 - Car Chassis (2WD or 4WD)
  3. 02 - DC Motors (3v - 6v)
  4. 01 - L298N Dual H-Bridge board
  5. 02 - White Leds
  6. 02 - 18650 batteries (3.7v - 4.2v)
  7. 01 - Battery support
  8. 01 - Electrolytic Capacitor 1000 μF (16v - 50v)
  9. 01 - (Optional) Antenna for ESP32-CAM board - improves video streaming and prevents lags
  10. 01 - (Optional) OV2640 ESP32 CAM (120 or 160 degree lens) - wide-angle capture
Note: in order to enable the external antenna, it is required to change resistor position in ESP32-CAM board see tutorial.
Step 1: Schematics
The schematics is using the L298N board because it is easier to build the connections, but you can also use other motor drivers such as L293D, L9110, DRV833 and TB6612FNG.
Step 2: About Car Chassis
Step 3: Install VS Code With Platform IO Plugin
Download and install PlatformIO, a plugin for Microsoft Virtual Studio Code
It is a more robust IDE compared to Arduino IDE. It also allows us to easily create our own private libraries and use a more object oriented code.
Step 4: Upload the Code
The project is hosted in Github at:
https://github.com/vitorccs/esp32cam-rc-car
Download the ZIP file containing the source code at:
https://github.com/vitorccs/esp32cam-rc-car/archive/refs/heads/master.zip
Once you open the project folder at VS Code with PlatformIO, it automatically downloads and install all library dependencies - much easier than Arduino IDE and risks free of downloading incorrect source or version (!)
Step 5: Customization
The PINs can be customized in the main.cpp
#include <Arduino.h>
#include <WifiHandler.h>
#include <StreamServer.h>
#include <SocketServer.h>
#include <DCMotor.h>
#include <WebJoystickHandler.h>
#include <JoyCoords.h>
#include <Car.h>
#include <sensor.h>
// Replace with your network credentials
#define WIFI_SSID "YOUR_SSID"
#define WIFI_PWD "YOUR_PWD"
#define WIFI_AP_MODE false // Access Point mode (no internet connection)
#define JOYSTICK_DEBUG true
#define PIN_FRONT_LED 2
#define PIN_CAMERA_LED 4
#define PIN_M1_IN1 14
#define PIN_M1_IN2 15
#define PIN_M2_IN1 12
#define PIN_M2_IN2 13
#define MIN_MOTOR_SPEED 80 // (0 to 255)
#define FRAME_SIZE FRAMESIZE_VGA
#define JPEG_QUALITY 25 // (0 to 63) lower means higher quality
Fine-tuning customization can be done in the individual files like DCMotor.h for changing speed parameters
#ifndef DCMOTOR_H
#define DCMOTOR_H
class DCMotor
public:
DCMotor(uint8_t pinIn1, uint8_t pinIn2);
void backward(uint8_t speed = 100);
void forward(uint8_t speed = 100);
void setMinAbsSpeed(uint8_t absSpeed);
void stop();
private:
uint8_t pinIn1;
uint8_t pinIn2;
uint8_t absSpeed = 0;
uint8_t maxAbsSpeed = 255;
uint8_t minAbsSpeed = 50;
uint8_t ignoreAbsSpeed = 30;
void setSpeed(uint8_t speed);
#endif
Step 6: Control
The ESP32-CAM connects to your Wi-Fi network and provides a Web page containing a virtual joystick.
Note: In order to control your car remotely from your public internet IP address, you need to set up Port Forwarding in your home router for ports 80 (Web page), 81 (video streaming) and 82 (web socket/joystick commands).
Step 7: Advices
Power Supply
I recommend to use high quality 18650 batteries (3.7v - 4.2v, 2200mAh, at least 2C of discharge rate).
Most people prefer to use different power sources for ESP32-CAM (3.3v or 5v) and Bridge driver (7.4 - 8.4v).
I prefer to have a single power source and thus a single power switch. However, it is recommended to use capacitor to filter the electrical noise created by the 02 DC motors.
Step 8: Resources
Fritzing file
The eletronic schematic was created in the Fritzing software and can be downloaded at
  1. Esp32CamRcCar_v3.zip
