Introduction: ESP32 Home Automation : Wireless Light Switch
in this project we'll see the steps needed to make a d.i.y home automation system :
wirelss light switch , with alarm clock around the ESP32 microcontroller
Step 1: The Components Needed
we will need a couple components in addition to the esp itself (images above) :
* The esp32.
* Two switches.
* Along with two 10k resistors , an LED of any prefered color , a small speaker and some generic body of wire , about 2 meters should be enough.
* You will also need a computer with the arduino IDE installed , and the ESP32 programming librairy , you can find how to do that on the internet.
Step 2: Wiring
the wiring job is not hard , just follow the above wiring diagram.
Step 3: The Code
The code consists of two parts , the html code for the web page , which will be embedded later in the arduino code , and the arduino code itself that displays / gets feedback from page and the RTC module for the alarm clock , it's all explained with comments in the arduino file above , so it shouldn't be hard to understand if you have expirience with arduino.
Step 4: The Arduino Code
//Importing all the essetial librairies:
#include <Wire.h> //the wire librairy for the i2c communication with the RTC.
#include <WiFi.h> //the wifi librairy for the website hosting.
#include "RTClib.h" // the RTC librairy that has all the essenssiel RTC code.
//setting the network information for the connection.
const char* ssid = "YOUR_SSID";
const char* password = "YOUR_PASSWORD";
RTC_DS1307 rtc; //initializing the RTC module.
WiFiServer server(80); //initializing the wifi server.
//setting static server information.
IPAddress staticIP(192,168,1,2);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255,255,255,0);
IPAddress dns(192,168,1,1);
//setting the alarm parameters:
// the time of the alarm triggering.
int Hour1 = 6;
int Mins1 = 15;
// the time of the alarm stopping.
int Hour2 = 7;
int Mins2 = 5;
//All the necessairy variables:
int relayPin1 = 13; //Relay pin.
int btn = 0; //The "alarm-off" button pin.
int togpin = 25; //The "alarm on/off" button pin.
int ledPin = 5; //The LED pin.
int Hrs; //Current hour.
int Mins; //Current minute.
int snooze; //The "alarm-off" button state.
int State; //The light state.
int toggle; //The "alarm on/off" button state.
bool nope = true; //The snooze following value.
void setup() {
//Setting the PWM parameters for the speaker pin since we are using the ESP32.
ledcSetup(0, 1000, 8);
ledcAttachPin(17, 0);
//Setting all the pinmodes for the used pins:
pinMode(relayPin1,OUTPUT); //The relay pin as an output.
pinMode(ledPin,OUTPUT); //The led pin as an output.
pinMode(btn,INPUT); //The "alarm-off" button pin as an input.
pinMode(togpin,INPUT); //The "alarm on/off" button pin as an input.
digitalWrite(ledPin,HIGH); //Setting the led pin state high since the pin is attached to the led's cathode , so by setting it high we are turning it off which is needed because it's initial state is low so the led would be on.
digitalWrite(relayPin1,HIGH); //Same for the relay pin since the module we are using is common anode.
ConnectToWiFi(); //connecting to wifi.
server.begin(); //begining the web server.
void loop() {
DateTime now = rtc.now(); //initializing an element with the RTC librairy , storing all the time information.
Hrs = now.hour(); //storing the current hour value in the variable.
Mins = now.minute(); //storing the current minute value in the variable.
snooze = digitalRead(btn); //storing the "alarm-off" button state in the variable.
toggle = digitalRead(togpin); //storing the "alarm on/off" button state in the variable.
if(toggle == 1){ //only do the following if the "alarm on/off" value is True.
if(snooze == 0){ //when button pressed stop the alarm.
nope = false;
AlarmOff();
if(Hrs == Hour1 && Mins >= Mins1){ //only do the following if we hit the the triggering time.
if(nope){ //if we don't hit the snooze.
State = 1;
AlarmOn();
if(Hrs == Hour2){ //do the following if we hit the stopping HOUR.
if(Mins <= Mins2){ //if we're yet to reach the stopping MINUTE.
State = 1;
AlarmOn();
if(Mins > Mins2){ //if we hit the stopping MINUTE.
for(int i ; i < 2 ; i++){ //go around turning everything off twice , for certainty.
State = 0;
AlarmOff();
Page(); //displaying the website and controlling the light throught it.
void Page(){ //function for displaying and getting user input from the web page.
//this is where it gets a little complicated , but just focus and you'll be good :
WiFiClient client = server.available(); //initializing server named client.
if (client) { //if a client is present.
String currentLine = "";
while (client.connected()) { //do the following if we have a client connected.
if (client.available()) { //if the client is ON the page.
char c = client.read(); //storing the info read off the client in the variable.
if (c == '\n') { //if we don't get any information from the client.
if (currentLine.length() == 0) { //if there's no interaction from the client.
if(!State){ //if the light is off.
//The web page displayed if the light is off:
client.print("<!DOCTYPE html>\n");client.print("<!-- saved from url=(0042)file:///C:/Users/HP%20PRO/Desktop/web.html -->\n");client.print("<html>\n");client.print("\t\t\n");client.print("\t<head>\n");client.print("\t<link rel=\"icon\" \n");client.print(" type=\"image/png\" \n");client.print(" href=\"https://pbs.twimg.com/profile_images/863510403120222208/rjVOiTe3.jpg\">\n");client.print("\n");client.print("\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=UTF-8\">\n");client.print("\t\n");client.print("\t<meta name=\"viewport\" content=\"width=device-width initial-scale=1.0 \">\n");client.print("\t<title>esp32</title>\n");client.print("\t<style type=\"text/Css\">\n");client.print("\n");client.print("\t.mobileShow {display: none;}\n");client.print("\n");client.print(" \t@media only screen and (min-device-width : 320px) and (max-device-width : 480px){ \n");client.print(" .mobileShow {display: inline;}\n");client.print(" \t}\n");client.print("\n");client.print("\t.mobileHide { display: inline; }\n");client.print("\n");client.print(" \t@media only screen and (min-device-width : 320px) and (max-device-width : 480px){\n");client.print(" .mobileHide { display: none;}\n");client.print(" \t}\n");client.print("\n");client.print("\t.sansserif {\n");client.print(" \tfont-family: Arial, Helvetica, sans-serif;\n");client.print("\t}\n");client.print(" \n");client.print("\tbody{ \n");client.print("\n");client.print("\t\tbackground-image: url('https://i.pinimg.com/originals/ea/3f/d3/ea3fd3102ccf575e3c33954f73eab78d.jpg');\n");client.print("\n");client.print("\t\tbackground-repeat: no-repeat;\n");client.print(" \t\t\n");client.print(" \t\tbackground-attachment: fixed;\n");client.print(" \t\t\n");client.print(" \t\tbackground-size: cover;\n");client.print("\n");client.print("\t\tfont-family: Arial, Helvetica, sans-serif;\n");client.print("\n");client.print("\t}\n");client.print("\n");client.print("\t.floater {\n");client.print(" height: 100%;\n");client.print(" width: 225px;\n");client.print(" display: inline-block;\n");client.print("\t}\n");client.print("\n");client.print("\t.floaterMob {\n");client.print(" height: 100%;\n");client.print(" display: inline-block;\n");client.print("\t}\n");client.print("\n");client.print("\t.container {\n");client.print(" white-space: nowrap;\n");client.print("\t}\n");client.print("\n");client.print("\t.button {\n");client.print("\ttransition-duration: 0.4s;\n");client.print(" \tborder-radius: 4px;\n");client.print(" \tborder: none;\n");client.print(" \tpadding: 22px 42px;\n");client.print(" \ttext-align: center;\n");client.print(" \ttext-decoration: none;\n");client.print(" \tdisplay: inline-block;\n");client.print(" \tfont-size: 24px;\n");client.print(" \tmargin: 4px 2px;\n");client.print(" \tcursor: pointer;\n");client.print("\t}\n");client.print("\n");client.print("\t.button1 {\n");client.print(" \tbackground-color: #e7e7e7; \n");client.print(" \tcolor: black; \n");client.print("\t}\n");client.print("\n");client.print("\t.button1:hover {\n");client.print("\tbox-shadow: 0 8px 16px 0 rgba(0,0,0,0.2), 0 6px 20px 0 rgba(0,0,0,0.19);\n");client.print(" \tbackground-color: #4CAF50;\n");client.print(" \tcolor: white;\n");client.print("\t}\n");client.print("\n");client.print("\t.button2 {\n");client.print("\tpadding: 22px 42px;\n");client.print(" \tbackground-color: #e7e7e7; \n");client.print(" \tcolor: black; \n");client.print("\t}\n");client.print("\n");client.print("\t.button2:hover {\n");client.print("\tbox-shadow: 0 8px 16px 0 rgba(0,0,0,0.2), 0 6px 20px 0 rgba(0,0,0,0.19);\n");client.print(" \tbackground-color: #008CBA;\n");client.print(" \tcolor: white;\n");client.print("\t}\n");client.print("</style>\n");client.print("</head>\n");client.print("\t\t<center>\n");client.print("\t\t\t\n");client.print("\t<body>\n");client.print("\t\t\t<div class=\"mobileHide\">\n");client.print("\t\t<header> \n");client.print("\n");client.print(" <div id=\"top-header\"> \n");client.print(" \n");client.print(" <div style=\"align-items: center;\" class=\"container\"> \n");client.print("\n");client.print(" \t<div class=\"floater\"><img name=\"wifiLogo\" width=\"160\" src=\"https://i.pinimg.com/originals/db/a9/42/dba94232c569bddc40386bcb540e0f95.png\"></div>\n");client.print("\n");client.print(" <div class=\"floater\"><img name=\"arduinoLogo\" width=\"400\" height=\"100\" src=\"https://elbag.net/wp-content/uploads//arduino-logo-1024x259.png\"></div>\n");client.print("\n");client.print(" <div class=\"floater\"><img name=\"Seperation\" width=\"10\" height=\"10\" src=\"https://about.canva.com/wp-content/themes/canvaabout/img/proLandingPage/banner-wave-3.svg\"></div>\n");client.print("\n");client.print(" </div> \n");client.print("<hr>\n");client.print(" <nav> \n");client.print(" \n");client.print(" </nav> \n");client.print(" </div> \n");client.print(" \n");client.print("</header> \n");client.print("<br>\n");client.print("\t\t\n");client.print("\t\t<div style=\"align-items: center;\">\n");client.print("\t\t\t<center>\n");client.print(" <a href=\"/ON\">\n");client.print(" \t\t\t<button id=\"hell\" onclick=\"document.getElementById('hell').style.display='none' ; document.getElementById('hell2').style.display='block'\" class=\"button1 button\">ON</button>\n");client.print(" \t\t\t</a>\n");client.print("\n");client.print("\n");client.print("\n");client.print(" \t\t\t <a href=\"/OFF\">\n");client.print(" \t\t\t<button style=\"display: none\" id=\"hell2\" onclick=\"document.getElementById('hell2').style.display='none' ; document.getElementById('hell').style.display='block'\" class=\"button2 button\"><strong>OFF</strong></button>\n");client.print(" \t\t</a>\n");client.print(" \t\n");client.print(" \t</center>\n");client.print("\n");client.print(" \t\t</div><br><br>\n");client.print(" \t\t<a href=\"https://en.wikipedia.org/wiki/Goat\" target=\"_blank\">\n");client.print(" \t\t<img width=\"1000\" src=\"https://sammlung.staedelmuseum.de/images/1269/philipp-peter-roos-sheep-and-goat-rocky-landscape-1279--thumb-xl.jpg\" alt=\"A Goa0t\">\n");client.print(" \t\t</a>\n");client.print("\t\t</center>\n");client.print("\t\t</div>\n");client.print(" \t\n");client.print(" \t\t<!---------------------------------------------------------mobile----------------------------------------------------------------->\t\n");client.print(" \t\t<center>\n");client.print("\t\t<div class=\"mobileShow\">\n");client.print("\t\t<header> \n");client.print("\n");client.print(" <div style=\"align-items: center\" id=\"top-header\"> \n");client.print(" \n");client.print(" <div> \n");client.print("\n");client.print(" \t<div class=\"floaterMob\"><img name=\"wifiLogo\" width=\"80\" src=\"https://i.pinimg.com/originals/db/a9/42/dba94232c569bddc40386bcb540e0f95.png\"></div>\n");client.print("\n");client.print(" \t<div class=\"floaterMob\"><img name=\"separation\" width=\"20\" height=\"10\" src=\"https://about.canva.com/wp-content/themes/canvaabout/img/proLandingPage/banner-wave-3.svg\"></div>\n");client.print("\n");client.print(" <div class=\"floaterMob\"><img name=\"arduinoLogo\" width=\"200\" src=\"https://elbag.net/wp-content/uploads//arduino-logo-1024x259.png\"></div>\n");client.print("\n");client.print(" </div> \n");client.print("<hr>\n");client.print(" <nav> \n");client.print(" \n");client.print(" </nav> \n");client.print(" </div> \n");client.print(" \n");client.print("<br>\n");client.print("\t\t\n");client.print("\t\t<div style=\"align-items: center;\">\n");client.print("\t\t\t<center>\n");client.print(" <a href=\"/ON\">\n");client.print(" \t\t\t<button id=\"hell\" onclick=\"document.getElementById('hell').style.display='none' ; document.getElementById('hell2').style.display='block'\" class=\"button1 button\">ON</button>\n");client.print(" \t\t\t</a>\n");client.print("\n");client.print("\n");client.print("\n");client.print(" \t\t\t <a href=\"/OFF\">\n");client.print(" \t\t\t<button style=\"display: none\" id=\"hell2\" onclick=\"document.getElementById('hell2').style.display='none' ; document.getElementById('hell').style.display='block'\" class=\"button2 button\"><strong>OFF</strong></button>\n");client.print(" \t\t</a>\n");client.print(" \t\n");client.print(" \t</center>\n");client.print("\n");client.print(" \t\t</div><br><br>\n");client.print("\n");client.print(" \t\t<img name=\"mainPic\" width=\"350\" src=\"https://i.kym-cdn.com/photos/images/facebook/001/365/202/90e.jpg\" alt=\"A mayrio koala\">\n");client.print("\n");client.print("\t\t</center>\n");client.print("\t\t</div>\n");client.print("\t\t</center>\n");client.print("</body>\n");client.print("\t\n");client.print("\t</html>");
if(State){ //if the light is on.
//The web page displayed if the light is on:
client.print("<!DOCTYPE html>\n");client.print("<!-- saved from url=(0042)file:///C:/Users/HP%20PRO/Desktop/web.html -->\n");client.print("<html>\n");client.print("\t\t\n");client.print("\t<head>\n");client.print("\t<link rel=\"icon\" \n");client.print(" type=\"image/png\" \n");client.print(" href=\"https://pbs.twimg.com/profile_images/863510403120222208/rjVOiTe3.jpg\">\n");client.print("\n");client.print("\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=UTF-8\">\n");client.print("\t\n");client.print("\t<meta name=\"viewport\" content=\"width=device-width initial-scale=1.0 \">\n");client.print("\t<title>esp32</title>\n");client.print("\t<style type=\"text/Css\">\n");client.print("\n");client.print("\t.mobileShow {display: none;}\n");client.print("\n");client.print(" \t@media only screen and (min-device-width : 320px) and (max-device-width : 480px){ \n");client.print(" .mobileShow {display: inline;}\n");client.print(" \t}\n");client.print("\n");client.print("\t.mobileHide { display: inline; }\n");client.print("\n");client.print(" \t@media only screen and (min-device-width : 320px) and (max-device-width : 480px){\n");client.print(" .mobileHide { display: none;}\n");client.print(" \t}\n");client.print("\n");client.print("\t.sansserif {\n");client.print(" \tfont-family: Arial, Helvetica, sans-serif;\n");client.print("\t}\n");client.print(" \n");client.print("\tbody{ \n");client.print("\n");client.print("\t\tbackground-image: url('https://i.pinimg.com/originals/ea/3f/d3/ea3fd3102ccf575e3c33954f73eab78d.jpg');\n");client.print("\n");client.print("\t\tbackground-repeat: no-repeat;\n");client.print(" \t\t\n");client.print(" \t\tbackground-attachment: fixed;\n");client.print(" \t\t\n");client.print(" \t\tbackground-size: cover;\n");client.print("\n");client.print("\t\tfont-family: Arial, Helvetica, sans-serif;\n");client.print("\n");client.print("\t}\n");client.print("\n");client.print("\t.floater {\n");client.print(" height: 100%;\n");client.print(" width: 225px;\n");client.print(" display: inline-block;\n");client.print("\t}\n");client.print("\n");client.print("\t.floaterMob {\n");client.print(" height: 100%;\n");client.print(" display: inline-block;\n");client.print("\t}\n");client.print("\n");client.print("\t.container {\n");client.print(" white-space: nowrap;\n");client.print("\t}\n");client.print("\n");client.print("\t.button {\n");client.print("\ttransition-duration: 0.4s;\n");client.print(" \tborder-radius: 4px;\n");client.print(" \tborder: none;\n");client.print(" \tpadding: 22px 42px;\n");client.print(" \ttext-align: center;\n");client.print(" \ttext-decoration: none;\n");client.print(" \tdisplay: inline-block;\n");client.print(" \tfont-size: 24px;\n");client.print(" \tmargin: 4px 2px;\n");client.print(" \tcursor: pointer;\n");client.print("\t}\n");client.print("\n");client.print("\t.button1 {\n");client.print(" \tbackground-color: #e7e7e7; \n");client.print(" \tcolor: black; \n");client.print("\t}\n");client.print("\n");client.print("\t.button1:hover {\n");client.print("\tbox-shadow: 0 8px 16px 0 rgba(0,0,0,0.2), 0 6px 20px 0 rgba(0,0,0,0.19);\n");client.print(" \tbackground-color: #4CAF50;\n");client.print(" \tcolor: white;\n");client.print("\t}\n");client.print("\n");client.print("\t.button2 {\n");client.print("\tpadding: 22px 42px;\n");client.print(" \tbackground-color: #e7e7e7; \n");client.print(" \tcolor: black; \n");client.print("\t}\n");client.print("\n");client.print("\t.button2:hover {\n");client.print("\tbox-shadow: 0 8px 16px 0 rgba(0,0,0,0.2), 0 6px 20px 0 rgba(0,0,0,0.19);\n");client.print(" \tbackground-color: #008CBA;\n");client.print(" \tcolor: white;\n");client.print("\t}\n");client.print("</style>\n");client.print("</head>\n");client.print("\t\t<center>\n");client.print("\t\t\t\n");client.print("\t<body>\n");client.print("\t\t\t<div class=\"mobileHide\">\n");client.print("\t\t<header> \n");client.print("\n");client.print(" <div id=\"top-header\"> \n");client.print(" \n");client.print(" <div style=\"align-items: center;\" class=\"container\"> \n");client.print("\n");client.print(" \t<div class=\"floater\"><img name=\"wifiLogo\" width=\"160\" src=\"https://i.pinimg.com/originals/db/a9/42/dba94232c569bddc40386bcb540e0f95.png\"></div>\n");client.print("\n");client.print(" <div class=\"floater\"><img name=\"arduinoLogo\" width=\"400\" height=\"100\" src=\"https://elbag.net/wp-content/uploads//arduino-logo-1024x259.png\"></div>\n");client.print("\n");client.print(" <div class=\"floater\"><img name=\"Seperation\" width=\"10\" height=\"10\" src=\"https://about.canva.com/wp-content/themes/canvaabout/img/proLandingPage/banner-wave-3.svg\"></div>\n");client.print("\n");client.print(" </div> \n");client.print("<hr>\n");client.print(" <nav> \n");client.print(" \n");client.print(" </nav> \n");client.print(" </div> \n");client.print(" \n");client.print("</header> \n");client.print("<br>\n");client.print("\t\t\n");client.print("\t\t<div style=\"align-items: center;\">\n");client.print("\t\t\t<center>\n");client.print(" <a href=\"/ON\">\n");client.print(" \t\t\t<button style=\"display: none\" id=\"hell\" onclick=\"document.getElementById('hell').style.display='none' ; document.getElementById('hell2').style.display='block'\" class=\"button1 button\">ON</button>\n");client.print(" \t\t\t</a>\n");client.print("\n");client.print("\n");client.print("\n");client.print(" \t\t\t <a href=\"/OFF\">\n");client.print(" \t\t\t<button id=\"hell2\" onclick=\"document.getElementById('hell2').style.display='none' ; document.getElementById('hell').style.display='block'\" class=\"button2 button\"><strong>OFF</strong></button>\n");client.print(" \t\t</a>\n");client.print(" \t\n");client.print(" \t</center>\n");client.print("\n");client.print(" \t\t</div><br><br>\n");client.print(" \t\t<a href=\"https://en.wikipedia.org/wiki/Goat\" target=\"_blank\">\n");client.print(" \t\t<img width=\"1000\" src=\"https://sammlung.staedelmuseum.de/images/1269/philipp-peter-roos-sheep-and-goat-rocky-landscape-1279--thumb-xl.jpg\" alt=\"A Goa0t\">\n");client.print(" \t\t</a>\n");client.print("\t\t</center>\n");client.print("\t\t</div>\n");client.print(" \t\n");client.print(" \t\t<!---------------------------------------------------------mobile----------------------------------------------------------------->\t\n");client.print(" \t\t<center>\n");client.print("\t\t<div class=\"mobileShow\">\n");client.print("\t\t<header> \n");client.print("\n");client.print(" <div style=\"align-items: center\" id=\"top-header\"> \n");client.print(" \n");client.print(" <div> \n");client.print("\n");client.print(" \t<div class=\"floaterMob\"><img name=\"wifiLogo\" width=\"80\" src=\"https://i.pinimg.com/originals/db/a9/42/dba94232c569bddc40386bcb540e0f95.png\"></div>\n");client.print("\n");client.print(" \t<div class=\"floaterMob\"><img name=\"separation\" width=\"20\" height=\"10\" src=\"https://about.canva.com/wp-content/themes/canvaabout/img/proLandingPage/banner-wave-3.svg\"></div>\n");client.print("\n");client.print(" <div class=\"floaterMob\"><img name=\"arduinoLogo\" width=\"200\" src=\"https://elbag.net/wp-content/uploads//arduino-logo-1024x259.png\"></div>\n");client.print("\n");client.print(" </div> \n");client.print("<hr>\n");client.print(" <nav> \n");client.print(" \n");client.print(" </nav> \n");client.print(" </div> \n");client.print(" \n");client.print("<br>\n");client.print("\t\t\n");client.print("\t\t<div style=\"align-items: center;\">\n");client.print("\t\t\t<center>\n");client.print(" <a href=\"/ON\">\n");client.print(" \t\t\t<button style=\"display: none\" id=\"hell\" onclick=\"document.getElementById('hell').style.display='none' ; document.getElementById('hell2').style.display='block'\" class=\"button1 button\">ON</button>\n");client.print(" \t\t\t</a>\n");client.print("\n");client.print("\n");client.print("\n");client.print(" \t\t\t <a href=\"/OFF\">\n");client.print(" \t\t\t<button id=\"hell2\" onclick=\"document.getElementById('hell2').style.display='none' ; document.getElementById('hell').style.display='block'\" class=\"button2 button\"><strong>OFF</strong></button>\n");client.print(" \t\t</a>\n");client.print(" \t\n");client.print(" \t</center>\n");client.print("\n");client.print(" \t\t</div><br><br>\n");client.print("\n");client.print(" \t\t<img name=\"mainPic\" width=\"350\" src=\"https://i.kym-cdn.com/photos/images/facebook/001/365/202/90e.jpg\" alt=\"A mayrio koala\">\n");client.print("\n");client.print("\t\t</center>\n");client.print("\t\t</div>\n");client.print("\t\t</center>\n");client.print("</body>\n");client.print("\t\n");client.print("\t</html>");
break;
else { //after the client interacted and the light followed , we reset the values.
currentLine = "";
else if (c != '\r') { //if there is information to read from the client , we store it.
currentLine += c;
if (currentLine.endsWith("GET /ON")) { //if ON button pressed.
State = 1;
TurnLightOn();
if (currentLine.endsWith("GET /OFF")) { //if OFF button pressed.
State = 0;
TurnLightOff();
void ConnectToWiFi(){ //function for connecting the esp to wifi.
WiFi.begin(ssid, password); //using the written info to begin the connection.
if (!WiFi.config(staticIP, gateway, subnet, dns, dns)) { //making sure the esp connects with our chosen static ip address.
for(int i ; i < 10 ; i++){ //if the process fails we blink the led.
digitalWrite(ledPin,LOW);
delay(100);
void TurnLightOn(){
digitalWrite(relayPin1,LOW); //setting the relay value low , therefore triggiring it , since it's a common cathode relay module.
void TurnLightOff(){
digitalWrite(relayPin1,HIGH); //setting the relay value low , therefore turning it off , since it's a common cathode relay module.
void AlarmOff(){ //function for stopping all the alarm actions.
TurnLightOff();
LedOff();
SpeakerOff();
void AlarmOn(){ //function for triggering all the alarm actions.
TurnLightOn();
SpeakerOn();
Blink();
void LedOn(){ //function for turning the led on.
digitalWrite(ledPin,LOW); //setting the led pin to low , since the pin is attached to the cathode so the values are flipped around.
void LedOff(){ //function for turning the led off.
digitalWrite(ledPin,HIGH); //setting the led pin to high , since the pin is attached to the cathode so the values are flipped around.
void SpeakerOn(){ //function for playing the speaker tune.
ledcWrite(0,123); //sending the speaker a PWM signal to play a tune.
delay(400); //waiting a while.
ledcWrite(0,0); //turning the speaker off.
void SpeakerOff(){ //function for turning speaker off.
ledcWrite(0,0); //bascically setting the speaker pin low.
void Blink(){ //the led blinking function.
digitalWrite(ledPin,LOW); //turning led on.
delay(75); //waiting a while.
digitalWrite(ledPin,HIGH); //turning led off.
}Step 5: The Html Code
<!DOCTYPE html>
<html>
<head>
<link rel="icon"
type="image/png"
href="https://pbs.twimg.com/profile_images/863510403120222208/rjVOiTe3.jpg">
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<meta name="viewport" content="width=device-width initial-scale=1.0 ">
<style type="text/Css">
.sansserif {
body{
.floater {
height: 100%;
width: 225px;
.floaterMob {
height: 100%;
.container {
.button {
border-radius: 4px;
border: none;
padding: 22px 42px;
text-align: center;
font-size: 24px;
margin: 4px 2px;
cursor: pointer;
.button1 {
color: black;
.button1:hover {
color: white;
.button2 {
padding: 22px 42px;
color: black;
.button2:hover {
color: white;
</style>
</head>
<center>
<body>
<div class="mobileHide">
<header>
<div id="top-header">
<div style="align-items: center;" class="container">
<div class="floater"><img name="wifiLogo" width="160" src="https://i.pinimg.com/originals/db/a9/42/dba94232c569bddc40386bcb540e0f95.png"></div>
<div class="floater"><img name="arduinoLogo" width="400" height="100" src="https://elbag.net/wp-content/uploads//arduino-logo-1024x259.png"></div>
<div class="floater"><img name="Seperation" width="10" height="10" src="https://about.canva.com/wp-content/themes/canvaabout/img/proLandingPage/banner-wave-3.svg"></div>
</div>
<hr>
<nav>
</nav>
</div>
</header>
<br>
<div style="align-items: center;">
<center>
<a href="/ON">
<button id="hell" onclick="document.getElementById('hell').style.display='none' ; document.getElementById('hell2').style.display='block'" class="button1 button">ON</button>
</a>
<a href="/OFF">
<button style="display: none" id="hell2" onclick="document.getElementById('hell2').style.display='none' ; document.getElementById('hell').style.display='block'" class="button2 button"><strong>OFF</strong></button>
</a>
</center>
</center>
</div>
<center>
<div class="mobileShow">
<header>
<div style="align-items: center" id="top-header">
<div>
<div class="floaterMob"><img name="wifiLogo" width="80" src="https://i.pinimg.com/originals/db/a9/42/dba94232c569bddc40386bcb540e0f95.png"></div>
<div class="floaterMob"><img name="separation" width="20" height="10" src="https://about.canva.com/wp-content/themes/canvaabout/img/proLandingPage/banner-wave-3.svg"></div>
<div class="floaterMob"><img name="arduinoLogo" width="200" src="https://elbag.net/wp-content/uploads//arduino-logo-1024x259.png"></div>
</div>
<hr>
<nav>
</nav>
</div>
<br>
<center>
<a href="/ON">
</a>
<a href="/OFF">
</a>
</center>
</div><br><br>
</center>
</div>
</center>
</body>
</html>Step 6: The End Result
At the end , your project should look a little something like the above image , you can choose any project box to contain it , just be careful when handeling the live 220v wires , it'll be best if you leave it to a professionel because every wiring job will be different depending on the house wiring itself , so you'll need to figure that out yourself.
