Introduction: ESP32-S2 Saola Making the RGB Work
I could not find any example code on how to access the Neo Pixel on my new ESP32-S2 so I decided to write some and share for anyone else who would like to do the same.
Step 1: Here Is Some Code to Get Your NeoPixel on Your ESP32-S2 Cycling.
First you need the ESP32 S2 devices installed in your Arduino IDE, downloaded here:
https://github.com/espressif/arduino-esp32/tree/es...
You will need the NeoPixel Library from Adafruit to get this sketch to work.
https://github.com/adafruit/Adafruit_NeoPixel
Finally just run the code attached.
//Sample code to control the single NeoPixel on the ESP32-S2 Saola
#include <Adafruit_NeoPixel.h>
// On the ESP32S2 SAOLA GPIO is the NeoPixel.
#define PIN 18
//Single NeoPixel
Adafruit_NeoPixel pixels(1, PIN, NEO_GRB + NEO_KHZ800);
#define DELAYVAL 25 // Time (in milliseconds) to pause between color change
void setup() {
//This pixel is just way to bright, lower it to 10 so it does not hurt to look at.
pixels.setBrightness(10);
pixels.begin(); // INITIALIZE NeoPixel (REQUIRED)
// Simple function to return a color in the rainbow
// Input a value 0 to 255 to get a color value.
uint32_t Wheel(byte WheelPos)
//Assume the wheel value is less than 85, if so Green value is 0
uint32_t returnColor = Adafruit_NeoPixel::Color((byte)(255 - (WheelPos * 3)), 0, (byte)(WheelPos * 3));
//If we are greater than 170 Red value is 0
if (WheelPos > 84 && WheelPos < 170)
WheelPos -= 85;
returnColor = Adafruit_NeoPixel::Color(0, (byte)(WheelPos * 3), (byte)(255 - WheelPos * 3));
//Finally above 170 and Blue value is 0
else if (WheelPos >= 170)
WheelPos -= 170;
returnColor = Adafruit_NeoPixel::Color((byte)(WheelPos * 3), (byte)(255 - WheelPos * 3), 0);
return returnColor;
//Counter to run from 0-255 to cycle the colors of the rainbow.
int colorCount = 0;
void loop() {
//Set the new color on the pixel.
pixels.setPixelColor(0, Wheel(colorCount++));
// Send the updated pixel colors to the hardware.
pixels.show();
//Cycle the colors at the end.
if (colorCount > 255)
colorCount = 0;
// Pause before next pass through loop
delay(DELAYVAL);
