Introduction: ESP32-S3 HomeKey NFC Reader
Hi! I'm a sophomore at Purdue University studying computer science. I'm fascinated by wireless technology and we have a very old keypad lock for our garage door back at home. I knew I could make something better to take its place. I decided to make an Apple HomeKey compatible NFC reader powered by an ESP32-S3.
The NFC reader also works with generic NFC cards, and even EMV-enabled credit cards as well.
You'll need access to a 3D printer, as well as a computer. The BOM for the circuit board is available on GitHub, and they can be ordered on Digikey or LCSC. LCSC ended up being about $70 for 3 boards.
I suggest ordering extra capacitors and resistors as they are small and will inevitably end up all over the floor!
https://github.com/acvigue/esp32-airreader
Step 1: Design Circuit Boards
I went through many revisions of the board design as this was my first time doing anything with PCB trace antennas. I ended up borrowing the component placement of Adafruit's PN532 breakout board for the RF portion of my board, and then recalculated the antenna matching network to work with the custom antenna I designed.
I designed the board in Altium and I've attached the source files in the GitHub repository in case you would like to make any changes. The compiled Gerber outputs are also available in the repo.
Step 2: Manufacture Circuit Boards
I uploaded the Gerber board files to JLCPCB and ordered them along with a solder stencil. I got 10 boards for under $25, including shipping. You can also opt to have them assembled at their factory with the attached BOM and CPL files.
It's much less expensive and more fun to build them yourself though! ( even if it involves burning your fingerprints off sometimes :) )
Step 3: Assemble Circuit Boards!!!
I like using Altium Designer, as it has an assembly assistant that guides you through the assembly process. Using this, you can solder the components in any order that you want and it will track your progress.
I kept a grab bag of all the parts next to me and as I grabbed a bag, I would just click on the ID in the assistant and it told me where to place the parts.
I think it's easier to use a hot air gun or a rework station for this step, especially for the ESP32 and PN532, as the leads aren't exposed.
Step 4: (Optional) Test Boards & (Not Optional) Upload Firmware
I highly recommend testing the boards after they are done being assembled. Using the firmware I have in the GitHub repo, you can ensure that the boards function properly and that the NFC reader works. It's easier to do this now then after you put it in the case.
I had an issue with one of mine and used a logic analyzer to find the problem.
Either way, you need to use esptool or PlatformIO to upload the firmware to the circuit boards.
Step 5: CAD
I threw together a quick enclosure in Fusion 360 to protect the PCB from the sun. I'm not concerned about water ingress as the final mounting location is mostly protected from rain. I ended up printing this in black ABS.
Step 6: Configure & Enroll Keys!
The current version of the firmware is a fork of the main ESP32-HomeKey project, however I'm working on a new version that is compatible with ESPHome. Currently, the steps to configure the PCB are identical to the ones here.
I will update my repository with the ESPHome firmware as soon as it is ready and working with the integrated Secure Element.
Step 7: Mount & Done!
I ran a 5V cable to the exterior wall and plugged it into the JST connector. You can also plug in a LIPO battery to this port!
