Introduction: ESP32 Ultrasonic Radar: a Real-Time Visualizer With Processing
This project is a DIY Radar system that uses an ESP32 to control an HC-SR04 ultrasonic sensor mounted on an SG90 servo motor. The system scans a 180-degree area, detects obstacles, and sends the data to a PC. Using the Processing IDE, I built a custom graphical user interface (GUI) that visualizes the distance and angle of objects in real-time, mimicking a professional radar display.
To build this radar, you will need:
- Microcontroller: ESP32 DevKit V1
- Sensor: HC-SR04 Ultrasonic Sensor
- Actuator: MG90S (or SG90) Micro Servo
- Software: Arduino IDE & Processing IDE
- Misc: Jumper wires, breadboard
Step 1: Connections
Connect your components following the pinout below. Note that the ESP32 GPIOs are used for the sensor and servo.
Wiring Table:
- HC-SR04 Trig → ESP32 GPIO 12
- HC-SR04 Echo → ESP32 GPIO 14
- MG90S Servo Signal → ESP32 GPIO 13
- VCC (Both) → ESP32 VIN (5V)
- GND (Both) → ESP32 GND
Step 2: Codes
The Arduino IDE code controls the servo's sweep and calculates the distance. Copy and paste this into your Arduino IDE. Make sure you have the ESP32Servo library installed.
Download and install the Processing IDE. The java processing code will draw the radar on your screen.
Note: Ensure the Serial.list()[0] matches your ESP32's COM port.
The Codes are in this GitHub Page : https://github.com/Nikhil-A-E/Esp-Ultrasonic-Radar.git
Step 3: Final Assembly and Testing
Mounting: Use a small piece of double-sided tape or hot glue to fix the HC-SR04 to the MG90S servo arm.
Power Up: Plug your ESP32 into your computer.
Upload: Upload the Arduino code first.
Run GUI: Open the Processing sketch and press the "Run" (Play) button.
Calibrate: If the radar is scanning backwards, simply swap the for loop ranges in the Arduino code.
For a visual guide on how to assemble the hardware and a demo of the software, check out my full video tutorial
