Introduction: ESP32 and ILI9486 Display - PlatformIO
This project is a basic test of a ILI9486 display connected to a ESP32 micro-controller. The code will display some text and the background color will change every 10 seconds. This project uses code from the TFT_eSPI example - TFT_Print_Test. Thank you very much to Bodmer for his amazing work!
https://github.com/Bodmer/TFT_eSPI/tree/master/exa...
All code for this project is located in the folder:
https://github.com/LaZorraTech/ESP32-and-ILI9486-D...
The display has the following specs:
Driver: ILI9486
Resolution : 320x480
Bus: 8bit
ILI9486 3.5" Display
https://www.amazon.com/gp/product/B075FP83V5/ref=p...
ESP32 Board - Lots of options available - This is the one used in this project
https://www.microcenter.com/product/613822/inland-...
Jumper Wires
https://www.amazon.com/gp/product/B07GD2BWPY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Step 1: Wiring Connections
Display -> ESP32
TFT_DC -> 18 // Data Command control pin (Labelled as LCD_RS on my display)
TFT_CS -> 33 // Chip select control pin
TFT_RST -> 32 // Reset pin
TFT_RD -> 2
TFT_WR -> 4 // Write strobe control pin
TFT_D0 -> 12 // Must use pins in the range 0-31 for the data bus
TFT_D1 -> 13 // so a single register write sets/clears all bits
TFT_D2 -> 26
TFT_D3 -> 25
TFT_D4 - > 21
TFT_D5 -> 5
TFT_D6 -> 27
TFT_D7 -> 14
GND -> GND
3.3V -> 3.3V Connect both 3.3V and 5.0 V
5.0V -> 5.0V Connect both 3.3V and 5.0 V
Step 2: PlatformIO - Code
Copy the code from the github folder into the src/main.cpp.
(This is the modified TFT_Print_Test mentioned earlier.)
Step 3: PlatformIO - Platformio.ini
Add this line to your platformio.ini file to load the TFT_eSPI library:
lib_deps = bodmer/TFT_eSPI@^2.3.59s
(Make sure you have the necessary libraries!)
Step 4: PlatformIO - User_Setup.h
Click on .pio to expand it.
Click on libdeps/esp32dev/TFT_eSPI to expand it.
Find the User_Setup.h file and open it.
Make the following changes:
Comment out the #define ILI9341_DRIVER (line 39)
Enable the #define ILI9486_DRIVER (line 46)
Comment out lines 157 to 159 ("For NodeMCU - use pin numbers...")
Enable the #define TFT_PARALLEL_8_BIT (line 224)
Cut and paste the pin definitions from the main code (lines 227-241)
All other values at the end of the file, I did not modify.
In the end, your User_Setup.h should look like the photos. I've included it in the github folder if needed for reference.
Step 5: End Result
Build it and upload it to your ESP32 and cross your fingers!
And hopefully the end result is a working display. Once you get the hang of modifying the User_setup.h file it's easy enough to try other examples from Bodmer's 480x320 examples.
Wishing you luck with this!
