Introduction: ESP32/ESP8266: DHT Temperature and Humidity Readings in OLED Display
Learn how to display temperature and humidity readings from a DHT11/DHT22 sensor in an SSD1306 OLED display using an ESP32 or an ESP8266 with Arduino IDE
In this project we’ll use an I2C SSD1306 128×64 OLED display as shown above.
The temperature and humidity will be measured using the DHT22 temperature and humidity sensor (you can also use DHT11).
For this tutorial you need the following components:
- 0.96 inch OLED display
- ESP32 or ESP8266
- DHT22 or DHT11 temperature and humidity sensor
- Breadboard
- 10k Ohm resistor
- Jumper wires
Step 1: Schematic
The OLED display we’re using communicates via I2C communication protocol, so you need to connect it to the ESP32 or ESP8266 I2C pins.
By default, the ESP32 I2C pins are:
- GPIO 22: SCL
- GPIO 21: SDA
If you’re using an ESP8266, the default I2C pins are:
- GPIO 5 (D1): SCL
- GPIO 4 (D2): SDA
Follow the schematic diagram above if you’re using an ESP32 board
Step 2: For ESP8266
If you’re using an ESP8266 follow the diagram above instead.
In this case we’re connecting the DHT data pin to GPIO 14, but you can use any other suitable GPIO.
Step 3: Installing Libraries
Before uploading the code, you need to install the libraries to write to the OLED display and the libraries to read from the DHT sensor.
Installing the OLED libraries
There are several libraries available to control the OLED display with the ESP8266. In this tutorial we’ll use the libraries from adafruit: the Adafruit_SSD1306 library and the Adafruit_GFX library. Follow the next steps to install these libraries:
1. Open your Arduino IDE and go to Sketch > Include Library > Manage Libraries. The Library Manager should open.
2. Type “SSD1306” in the Search box and install the SSD1306 library from Adafruit.
3. After installing the SSD1306 library from Adafruit, type “GFX” in the search box and install the library.
Step 4: Installing the DHT Sensor Libraries
To read from the DHT sensor we’ll use the libraries from Adafruit.
2. Search for “DHT” on the Search box and install the DHT library from Adafruit.
3. After installing the DHT library from Adafruit, type “Adafruit Unified Sensor” in the search box. Scroll all the way down to find the library and install it.
Step 5: Code
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
#define DHTPIN 14 // Digital pin connected to the DHT sensor
// Uncomment the type of sensor in use:
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
void setup() {
Serial.begin(115200);
dht.begin();
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;);
delay(2000);
display.clearDisplay();
display.setTextColor(WHITE);
void loop() {
delay(5000);
//read temperature and humidity
float t = dht.readTemperature();
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
// clear display
// display temperature
display.setTextSize(1);
display.setCursor(0,0);
display.print("Temperature: ");
display.setTextSize(2);
display.setCursor(0,10);
display.print(t);
display.print(" ");
display.cp437(true);
display.write(167);
display.print("C");
// display humidity
display.setCursor(0, 35);
display.print("Humidity: ");
display.setCursor(0, 45);
display.print(h);
display.print(" %");
display.display();
Step 6: How the Code Works
Importing libraries
The code starts by including the necessary libraries. The Wire, Adafruit_GFX and Adafruit_SSD1306 are used to interface with the OLED display. The Adafruit_Sensor and the DHT libraries are used to interface with the DHT22 or DHT11 sensors.
#include <Wire.h>
#include <DHT.h>
Create a display object
Then, define your OLED display dimensions. In this case, we’re using a 128×64 pixel display.
Then, initialize a display object with the width and height defined earlier with I2C communication protocol (&Wire).
The (-1) parameter means that your OLED display doesn’t have a RESET pin. If your OLED display does have a RESET pin, it should be connected to a GPIO. In that case, you should pass the GPIO number as a parameter.
Create a DHT object
Then, define the DHT sensor type you’re using. If you’re using a DHT22 you don’t need to change anything on the code. If you’re using another sensor, just uncomment the sensor you’re using and comment the others.
Initialize a DHT sensor object with the pin and type defined earlier.
setup()
In the setup(), initialize the serial monitor for debugging purposes.
Initialize the DHT sensor:
dht.begin();
Then, initialize the OLED display.
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
for(;;);
In this case, the address of the OLED display we’re using is 0x3C. If this address doesn’t work, you can run an I2C scanner sketch to find your OLED address. You can find the I2C scanner sketch here.
Add a delay to give time for the display to initialize, clear the display and set the text color to white:
delay(2000);
In the loop() is where we read the sensor and display the temperature and humidity on the display.
Get temperature and humidity readings from DHT
The temperature and humidity are saved on the t and h variables, respectively. Reading temperature and humidity is as simple as using the readTemperature() and readHumidity() methods on the dht object.
In case we are not able to get the readings, display an error message:
Display sensor readings on the OLED display
The following lines display the temperature on the OLED display.
display.print(t);
display.print(" ");
display.write(167);
display.print("C");
We use the setTextSize() method to define the font size, the setCursor() sets where the text should start being displayed and the print() method is used to write something on the display.
To print the temperature and humidity you just need to pass their variables to the print() method as follows:
display.print(t);
The “Temperature” label is displayed in size 1, and the actual reading is displayed in size 2.
To display the º symbol, we use the Code Page 437 font. For that, you need to set the cp437 to true as follows:
Then, use the write() method to display your chosen character. The º symbol corresponds to character 167.
display.write(167);
A similar approach is used to display the humidity:
display.print(h);
Don’t forget that you need to call display.display() at the end, so that you can actually display something on the OLED.
display.display();
Step 7: Demonstration
The following figure shows what you should get at the end of this tutorial. Humidity and temperature readings are displayed on the OLED.
