Introduction: ESP8266-12 Blynk Wireless Temperature, Humidity DHT22 Sensor
in this project using a esp8266, to show the temperature and humidity DHT22 sensor on your smartphone or tablet.
DHT22 sensor is much more accurate than DHT11 but is also more expensive.
but if you only can use the DHT11
ESP8266-12 blynk wireless temperature e humidity DHT 11 sensor
Step 1: Materials
ESP8266-12 (esp8266-7, ...... , esp8266-12e)
DHT11 temperature and humidity sensor
10k resistence
power regulator 3,3v-5v
Step 2: Connections
ESP8266
VCC +3,3v
CH-PD +3.3v
gpio12 ---- pin2 (DHT22)
GND ground GPIO5 ground
DHT22 sensor
pin 1 +3,3v
pin 2 output .---- gpoi12 (ESP8266-12)
pin4 ground
10k resistence
pin 1 (DHT22) ---- 10k resistence---- pin 2 (DHT22)
Step 3: Blynk App
store app
configure blynk
create new project ( use hardware model esp8266 )
generate AUTH TOKEN
send E-mail TOKEN ( copy TOKEN in the esp8266 sketch)
in the app Blynk use Value Display widget or Gauge widget
Step 4: Sketch
Sketch
to programming the ESP8266-12, I use ide arduino 1.6.5 and CP2102 3.3V USB To UART Serial Interface Module Adaptor ( do not connect the power of the CP2102 to esp8266-12).
ESP8266 sketch
change the sketch in the following lines with your data
char auth[] = "xxxxxxxxxx"; //insert here your token generated by Blynk
Blynk.begin(auth, "ssid", "password!"); //insert here your SSID and password
Step 5: Thanks
Thanks by catoplepa
