Introduction: ESP8266 - Thermometer
Hello,
This is my first instructable, then sorry for the syntaxt :)
For my projet I made a thermometer by using an ESP8266 cheap WiFi module (you'll say ok an other one... yes but using AA battery for 1 year)
I'm using MQTT an Jeedom for my domotics and I would like to perfom a thermometer for heater regulation in room, my specification is :
- low cost
- simple to use and install
- 1 year autonomy with simple AA battery
To do this project I'm using :
- ESP8266 module (ESP-7)
- protyping board
- battery holder
- DS1820 temeprature sensor
- PVC tube diam 40mm
- wood for the caps and base plate
Step 1: The Hardware
Hardware explanation :
the sensor is powered by a GPIO of module to reduce consuption
the jumper is use to select the sensor number in my case only 7 sensors can be configured on same network
the power supply is measured by the analog input to check battery level with MQTT
remarks : some resistors are already mounted on module for for correct ESP configuration check on the net
Step 2: The Software
I'm using arduino environement for building the software
there are no difficulties but lot of optimisation for reducing power consuption
First optimisation
I remove the LED resistor on the module to remove 8mA from power LED (the red one)
I put the module in deepsleep for 5 min
see line ESP.deepSleep( DEEP_SLEEP, WAKE_RF_DEFAULT);
I start the WiFi only if temperature change +/-0.2°C
setup :
WiFi.mode(WIFI_OFF);
WiFi.forceSleepBegin();
in loop :
if( (TemperatureRAW >= (u16_oldTemperatureRAW + 4)) || (TemperatureRAW <= (u16_oldTemperatureRAW -4)))
WiFi.forceSleepWake();
WiFi.mode(WIFI_STA);
I'm using the RTC memory to store the old value for comparaison with new one.
I check the best RSSI before connect to network
With all that I have
- 40.8µA during deep sleep 90% of time
- 15mA during temperature measurement 8% of time
- 75mA during WiFi connexion 2% of time (estimation depending the temperature room variation)
Step 3: The Enclosure - Final Mounting
To make the enclusure I'm using a standard PVC tube used for vacuum whater in france, the diameter chooseen is 40mm. I have painted it in black color just for style other coulor should work :)
I'have turning the base and caps in wood
After you can introduce the battery holder and the circuit directly in the tube close this with the wooden caps.
That all !
note : I don't explain how to connect the thermometer with Jeedom because there are lot of sample
