Introduction: ESP8266 & Ubidots MQTT Connection Tutorial
I made a short but presise video about how to setup the ES8266 with Ubidots
Ubidots
Low Code IoT Plateform that allows for the connection of IoT devices via alot of different technologies. This totorial is to help anyone get the connection between the two systems going via MQTT so that you can build out your project from there.
All you need is a micro USB cable and ESP8266 12F model, link below is what i used
https://amzn.to/3kHFfML ESP 12F
But it should work with any ESP, just might have different settings
Step 1: Open Ubidots Acount
Create a ubidots account using this link https://stem.ubidots.com/
Step 2: Install Ubidots Libraries
Download the Ubidots MQTT Arduino Library from this address
https://github.com/ubidots/ubidots-mqtt-esp
and install it via the library manager in arduino IDE
Also from the Library manager tab in Arduino, search for "PubSubClient" and install that aswell
Arduino should be setup and ready to go
Step 3: Copy and Past the Below Example
 * Include Libraries
#include "UbidotsESPMQTT.h"
 * Define Constants
#define TOKEN "....." // Your Ubidots TOKEN
#define WIFINAME "...." //Your SSID
#define WIFIPASS "....." // Your Wifi Pass
Ubidots client(TOKEN);
 * Auxiliar Functions
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i=0;i<length;i++) {
    Serial.print((char)payload[i]);
  Serial.println();
 * Main Functions
void setup() {
  // put your setup code here, to run once:
  //client.ubidotsSetBroker("industrial.api.ubidots.com"); // Sets the broker properly for the business account
  client.setDebug(true); // Pass a true or false bool value to activate debug messages
  Serial.begin(115200);
  client.wifiConnection(WIFINAME, WIFIPASS);
  client.begin(callback);
void loop() {
  // put your main code here, to run repeatedly:
  if(!client.connected()){
      client.reconnect();
  float value1 = analogRead(0);
  //float value2 = analogRead(2)
  client.add("temperature", value1);
  //client.add("status", value2);
  client.ubidotsPublish("my-new-device");
  client.loop();
Then look for this section of the code and update it with your wifi detials aswell as the Ubidots account Token( see video for screenshots if you can't find it.
Try and compile the skecth
Step 4: Select the Correct Board and Comport
Next you want to make sure you have the correct settings for your board type and comport and upload
after the upload was succesful if you open the comport in 115200
you should see something like this
That means it was succesful and we can try and see if data is on ubidots
Step 5: UBidots Device View
If you look at your ubidots account you should see a new device was automatically created under the device tab. it will looks something like this
If you click on the device, you will see your new data that was sent from the device.
and thats it, expand, play, build from here!
Let me know if you have any questions
