EXTRA HANDS FOR SOLDERING - OCTOPUS
Intro: EXTRA HANDS FOR SOLDERING - OCTOPUS
A extra hands (helping hand), also known as a third hand, is a type of extremely adjustable hands to hold materials near each other so that the user can work on them.
STEP 1: MATERIALS USED
- Piece of wooden block
- Wood sticks with square cross-section (10x10mm)
- Alligator clips - 4 pairs
- Flexible and stiff wire of preferable gauge
- 0.5 W LED - 2 nos
- SPST switch
- 9 V battery with snap
- Wires, Screws and other consumables.
- Tools - Fixtures, Cross-cut saw, Drill, Angle Grinder, pliers, Cutters, Screw Drivers.
STEP 2: Mark & Cut a Slot With Cross-cut SAW
- Use a wood marker or Mica cutter to make impression in wood.
- Then use Cross-cut saw to make a slot just enough for 4 wires to pass.
STEP 3: Insert Wires and Secure Them With Tacker-gun
STEP 4: Connect the Alligator Clips to the Free Ends
STEP 5: Solder Lead Dispenser
Mark and Cut three pieces as shown in the pictures
STEP 6: Drill N Screw
Make hole and then Screw as shown
19 Comments
tominjose 8 years ago
Cool job!
chrisjlionel 8 years ago
Thanks Nanba
geekrex 8 years ago
hmm. may be in future it may need replacement not soon. since it can hold my pliers.
geekrex 8 years ago
dats really good i see your wire quality is better which wire did u used ?
(I don't even know the gauge of the wire)I just went to a hardware store and paid 5 rupees for 1 meter of wire. I suggest gas welding filler rod which will be far more better than this.
geekrex 8 years ago
CheckYourGages 8 years ago
Glad to see your interpretation! This is very well done! A much more permanent solution than mine, that's for sure. I think I'll follow your lead this time, and try to recreate this to my needs.
Thanks friend.
Ninjarooster 8 years ago
Hi, Ningarooster. Please do post the pictures here when you're done.
Royell 8 years ago
Such an orderly, effective build, made from mostly reused materials.
I love the rugged, utilitarian look!
Thanks Royell
Gemini1999 8 years ago
Yes, it holds the flux
adenda2 8 years ago
vaibhavk5757 8 years ago
