Introduction: Eagle Project 2
I previously submitted instructions for making a Small Wooden Eagle. This is a follow-on project. My first wooden eagle was 8.5" wide. This one is 10.5" wide, but it is the same pattern. This is not a professional pattern, so it is freely available as part of the Small Wooden Eagle instructions.
SAFETY
These instructions require power tools. PLEASE BE SAFE. No final product is worth an injury. Remember, SAFETY FIRST.
Band Saw or scroll saw
Belt sander
Router with 1/2" round-over cutter
Wood burning tool
Rotary tool for engraving
Carbon paper
Craft paint
Top coat (optional)
Step 1: Prepare Pattern
As mentioned in the introduction, I used a pattern which I previously included in Small Wooden Eagle instructions. You can download that pattern for free or use any other pattern you like.
To enlarge the pattern, I used Inkscape. I chose 10.5" width because it fit a piece of wood which I wanted to use as the background.
Step 2: Prepare Eagle
I prepared the eagle using oak and walnut. I have not included those steps in these instructions. For those instructions, please see instructions for Small Wooden Eagle. This eagle is a little bit larger, but it is the same pattern.
Step 3: Prepare Background
I choose a piece of high-quality pine for the background because it was available in my garage. Using the eagle shape, I drew a pattern for the background and adjusted it a few times. After cutting the background on a band saw and sanding the edge on a belt sander, I made marks 1/2" from the edge all around in order to see how much space was available for words. Then I rounded the top and bottom of the edge on as router using a 1/2" round-over cutter. Then lots of hand sanding to make the edge presentable.
Step 4: Add Words to Background
I printed the words and adjusted them on the background using the eagle as a guide. When I was satisfied with the words, I used carbon paper and pencil to transfer the words to the background. The last two photos above show the pattern on the wood.
Step 5: Woodburn the Words
I wood burned the words onto the background. The first photo above shows the wood burning complete with the eagle set in place. The eagle is not attached.
Step 6: Engraving a Second Set of Words
The wood burning did not look as good as I hoped, so I decided to engrave the words into the other side of the same background. I transferred the words using carbon paper and pencil. The last photo, above, shows engraving with my Dremel.
Step 7: Painting
I used paint to make engraved letters stand out more. Lots of sanding was required. I did not apply a top coat.
Step 8: Final
Since both sides are final sides, I attached the eagle temporarily with double-sided tape, rather than glue. For display, I set it onto a stand designed to hold a small frame
