Introduction: Earth Battery.
Earth batteries have been used for centuries, but it more recent times they were used in the 1800's to power telegraph stations. In this instructable we will try to replicate the earth battery in two forms. First as a single cell and then as multiple cells. How successful will we be? Will it be free electricity?
Source:
http://secure.wikimedia.org/wikipedia/en/wiki/Earth_battery
Note: This project is not for use during a electrical or thunderstorm. If there is lightning, wait for some other time. Also before any digging is done, please check with authorities to make sure you will not endanger yourself, others, or the utility conduits. I will not be responsible for any issues. Practice common sense. If you are not sure, get an expert to help.
Warning: I will not be responsible for any issues from this project. It is up to you to get an expert if you feel uncomfortable in this project. Since you are stringing out wire and pushing posts in the ground, it will be up to you to protect against any safety issues for humans and or animals..
Note:. Our goal is to power router and low power servers. many people have asked me to give test results. Have not done so as to encourage you to try it yourself. I will say that even just putting the stakes in the grond yeiled a voltage.
Note: Syar Arif did not have my permission to post this article on Scribd.
Step 1: What's Needed.
Materials:
Backyard, though I suppose several planters could work for part of the experiment.
12 copper spikes (copper tubing was just too expensive and likely to be stolen from the ground. The spikes are easier to disguise and easy to put in the ground.)
12 galvanised nails. (cut up pieces from aluminium oven pans works better. I used the left over edges from our cannoli form making instructable. (https://www.instructables.com/id/Home-made-cannoli-forms/)
Umpteen feet copper wire
One long roll aluminium foil
High value capacitors.
Tools:
Voltmeter
Wire cutters/stripper
Extra long measuring tape. (or if you know your footstep stride length (usually about 2.5 feet) will be close enough.
Compass (for finding which way is north(if you know which way the sun rises and sets, you can do a 90 degree angle to that and be pretty close)
Step 2: Layout 1 - Single Cell.
In a single cell layout you will only have two posts in the ground. One for each electrode type. Depending on where you live, digging in the ground can be dangerous. You need to contact your local utilities for the exact restrictions on digging. If you live on rental property, you may not be allow to dig at all. For this experiment I probably will not dig more tan two or three inches for safety reasons. Digging at a fence line might be a good thing in most cases. Also less chance of someone tripping over what you have set up.
For this we will only use one copper post, one aluminium post, 30 feet plus stretch of copper wire, and 20 foot plus strectch of aluminium foil. Some sandpaper or the like might me nice to make sure there is no sealer on the copper wire. Of course you will need a spade to make a ditch for the copper wire and the foil strip.
The two posts should be at least several feet apart.
Note: my first test of this yielded more volts than I expected. I also salted the ground to help with the conductivity.
Running the lines parallel can work also.
Step 3: Layout 2 - Multiple Cells.
With multiple cells there is not really any digging, but you have free wire that can be tripped over. This is definite best for up against a building or next to a fence. Somewhere out of a walking path. Use extreme caution when setting this up so no human or pet can become endangered.
Plus stakes should be copper and negative stakes should be foil.
Step 4: Testing.
You probably will not be getting more than just a few volts from this project, you can always use what is known as a joule thief and other circuits to boost your output. or use to make an oscillator for various purposes. https://www.instructables.com/id/555-chip-oscillator. In most cases to convert from dc to ac.
Step 5: Energy From Underground Power Wires.
This is just a sideline experiment. But I thought since power lines are buried underground, maybe they still can be useful. So I took the spare coat hanger TV antenna I built and wanted to put it to work. I also added a rectifier bridge and a DC meter for voltage level readings. Started with seeing what montitors and tv's put out. Then to the yard to see what I could find. Also wanted to make sure there were no powerlines underground where I wanted to dig for the earth battery.
Step 6: Interesting Application.
The picture is oversimplified, but was thinking of using an earth battery to energixe an HHO generator of which the gas would be used in a BBQ pit. Then if you really wanted to go all the way you could heat a home. You can collect rain as fuel for the unit.
You could go one step further and build a generator that runs on water. Less dependence of foreign energy sources.Convert existing gas turbines to run on hydrogen gas from hho units. powered by earth batteries. No fossil fuels required. HHO generator runs for the most part on good ol water. Earth battery farms would be a great possbility for unusable land.
15 Comments
8 years ago on Step 6
While that is some very noble thinking, unfortunately water is not the "fuel" for an earth battery. The stubble-field battery instead uses water as an ion transport medium for the chemical reaction taking place between the copper and aluminum plates. As soon as the plates oxidize, you will have no more reaction. These types of batteries are nice though considering that copper and aluminum (or magnesium) have a long dry shelf life compared to most batteries that are liquid-activated upon construction.
Reply 4 months ago
Here is the link I used to build mine. There is 21 illustrations on that website. If you click on the illustrations while looking at them, it goes from one to the next and it stops at 2.
https://ground-power-generator.blogspot.com/2021/07/earth-battery-design.html?m=0
-Or-
There are additional links all over the web. Use secure links only and just use caution which ones you look at to avoid virus's and other issue's.
Reply 4 months ago
Try Epson salts disolved(displaced) by water. The acidity in our rain does it when copper pipes are used with a zinc or aluminum electrode average 1.1v to 1.5v per cell. Connected in sequence. If you do 14 in a series you get 12-14 volts. If you use more cells you will need caps and diodes and one super long cell. I believe 8 to 10 ft long on your collector. You could also try fertilizer to change the acidity in the soil. I will see if I can find the formula for the patented cell that this is imitating and post it here later.
Reply 8 years ago on Step 6
Thank you for your explanation. This is not a Stubblefield battery.
Reply 11 months ago
You can go to your local electrical supply store and buy copper ground rods and galvanized steel ground rods. Those are your electrodes. You can buy some 10AWG wire red and black and attach those to the electrodes via ground rod clamps, some electricians call them acorns because they have the shape of a acorn.
To put the electrodes in the ground you can pound them in with a fence post tamper. The electrodes come in 10 foot lengths.
This might be easier for novices.
11 years ago on Introduction
Well we finally had some rain. The ground should no longer be rock hard. Need to do some maintenance back there, then I will do some more on the project.
Reply 11 months ago
Reply 4 months ago
This formula is missing the distance between the two. It is supposed to be 6 feet between them just like the 2 sided disks formula. This does work but it takes up a huge amount of room. Also we've always soldered the wires on rather than using acorns. I found the original posting that I used to build them. I can post the URL but I cannot post his formula without permissions. It includes earth capacitors as well.
Or
Look up earth batteries online at wikipedia. You can also search earth batteries online.
9 years ago
Do you have to have aluminum foil strips for wires?
Reply 11 months ago
I prigially intended to use alumionium rolled up but I eneded using.steel wire. I still may go back and use the foil.
That's nice. Better if we have some real phots of the project :D.
Verything is buried underground, so not much to see.
What results did you get - volts/amps?
What are the high value caps for - energy smoothing?
Reply 11 years ago on Introduction
Yes about the capacitors. When I put up the pics, I will also include more details. Hopefully by this weekend.
