Introduction: Easiest Crochet Voodoo Doll; Completely Customizable and Very Simple
*Uses US Crochet terms.
*This pattern uses half-double crochet, but you can use single crochet if you prefer. The half-doubles add a bit of texture. The pattern will work with either stitch.
*Appropriate sized crochet hook
(I used CraftSmart yarn, with a 5.25mm or I/9 hook)
*Stuffing
*Buttons, thread, extra yarn, and whatever else you may need to customize your doll
Step 1: Starting Up
*Simply chain 7, plus 1 to start your doll. Make one half-double (or single crochet if you prefer) in each chain across. You now have seven half-doubles.
*Chain one, turn and crochet 1 half-double in each stitch. Do not work into the turning chain. Repeat this row six (6) times.
You have completed the doll's head.
Step 2: Making the Arms
*Instead of making a turning chain, we will use this spot to start an arm. Chain 10. Work one half-double in the next nine chains, then continue working across the head. You should have 9 stitches for the arm, plus 7 across. Do not turn you work.
*Slip stitch into the last stitch you worked in, and chain 10. Turn, work the nine stitches for this arm. Then, work the 7 for the body and the nine for the opposite arm.
Tip: When working the arms, make sure not too twist them too much. It will work out well, even if it's a little wonky at first.
Step 3: Finishing the Arms, and Starting the Torso
*Work the main part, the body, until it is 8 rows long.
Step 4: Making the Legs
*Chain one, turn, and half-double across. Repeat until your first leg is 12 rows long. Fasten off.
*Make a second leg by joining onto the body (right at the end of the row where you started your first leg). Chain one, work into three stitches. Chain one, turn and repeat until your second leg is also twelve rows long. Fasten off.
You should have two legs, equal in length, with one stitch space between them.
Step 5: Options...
Or, you can make a functional voodoo doll with an open-able back. Follow the next few steps to see how.
Step 6: Making the Second Piece
*After the arms are complete, work one row for the torso (seven stitches). Turn, chain one and work into the first four stitches with half-doubles. Turn, chain one, work into the four stitches... Repeat this until your first back panel is 6 rows long. Fasten off.
*Fasten onto the spot just under the arms, on the same row where you started the first panel. Work into the first three stitches, just as you did previously. Repeat until the second panel is also 6 rows. Do not fasten off yet.
*Turn, chain one and work into the first three stitches. Then, continue into the next four stitches (the other back panel).
------> *Note: If your panels are not aligned (preventing you from working straight across), you must fasten on at a different point. The two panels should basically be worked in opposite directions. This is weird to explain, but will make sense when you have the work infront of you.
Step 7: Second Piece, Part 2
Step 8: Sew 'Em Up!
You can also just sew the two pieces together. It's simple enough to do by hand, and you can use yarn (rather than thread). Of course, thread or a sewing machine are both viable options. Once sewn, you can flip the work inside out (to hide the stitching), or keep it visible (which is what I did).
Really, you can do whatever you like. Experiment with textures and colors; use contrasting colors to make your stitching pop!
Don't forget to stuff your doll! It's best to stuff as you sew, even if your doll has the open back.
Step 9: Customize & Decorate
When you sew up the back (if you made your doll this way), you can use any color yarn. Contrasting colors look as good as matching ones.
Because this project is pretty basic, it's easy to change the size of the doll. Just add more chains and rows to make it bigger. Want thinner arms? Just take out a row. Longer legs? Don't stop at 12, keep going.
Step 10: Final Notes and Tips
To fill my dolls, I use the insides from cheap pillows. Poly-fil is nice, but pillows can be much cheaper (I usually grab a $3-5 pillow from Family Dollar or Wal-Mart).
Mismatching eyes is a great way to use up random buttons. Similarly, you can use scrap yarn for this project.
To make the doll in someone's likeness, just use the appropriate skin, hair and eye colors. Other distinguishing characteristics (like birthmarks or tattoos) can really solidify the look. Don't stop at friends and family members; you can even make fictional characters into dolls.
After fastening off, one would normally tie in their ends. If you use the crochet edging, you can actually work them into your stitching to save time.
And the most important thing is to have fun and be creative!!
