Easiest Cupboard Pan Lid Organiser
Intro: Easiest Cupboard Pan Lid Organiser
Haters of messy pan cupboards everywhere... rejoice! This quick cupboard door modification will leave you with more time to enjoy cooking dinner and sipping wine and less time searching for that elusive pan lid that's hidden itself inside your deepest stock pot or slipped down behind that slow cooker you've never used.
Don't have a local pound/dollar store to buy sticky hooks?? Try these from Amazon!
I first did a similar hack a few years ago whilst a student. Finding pan lids annoyed me as much then as it does now and so after seeing a very elegant solution on Instructables, I set out to make it even simpler. Having moved house several times since then, I was impressed when a friend improved on my previous idea, at which point I realised my current house has the same problem... PAN LIDS EVERYWHERE. iceng's uses the existing fixings in the cupboard, which made me think, can there be an even simpler solution? And, since my cupboard fixings were in the wrong place for his hack, here we are. Cheap and easily available sticky hooks.
STEP 1: Tools and Materials
STEP 2: Marking
When you think you've got a good layout, hold a pan lid up against the cupboard door and draw a mark in pencil at the 4 o'clock and 8 o'clock. If you draw them too close to 3 and 9 it will fall out, if you draw them too close to 5 and 7 it might not be so stable.
STEP 3: Sticking
STEP 4: Enjoy!
Enjoy your newly less hectic pan cupboard.
128 Comments
EvaW13 6 years ago
Brilliant! And without turning the hanging of a few lids into a 10 phase government project!
GeorgeHarris 7 years ago
that cool trick
obillo 7 years ago
Peel-off adhesives stick better if the area is wiped w/alcohol first and both area and stuckum are warmed w/hair dryer or even a wet washcloth (esp when applied to smooth surfaces). That said, the hooks I've bought from dollar stores usually fall off within a few months, and I've given up on them. If I WERE to use them for lids, esp glass ones, I'd drill a hole in each and secure with a tiny wood screw--1/2 inch max. OR: use cup hooks. I'd also put the heaviest lids closer to the hinges--the doors on most cabinets are just laminate-covered slabs of glued wood chips, very susceptible to weight pulling down on the hinges. Those are glass lids--heavy--not light metal.
zappenfusen 7 years ago
Jeez, this is 3 years old. Recycling are we?
zapp
JakeT38 7 years ago
New to this also. Just because it's old news to you, doesn't mean is old news to everyone.
JakeT38 7 years ago
What????? Not making any sense with "Like the lids. Pots are just pots."
The pots suck. The lids came with them on bottom.
zapp
essiewoods 7 years ago
100 screw in hooks for $3.00. Heat shrink cushioning and yes, the pots that came with the lids aren't anything special.
zapp
zapp
rogersgeorge 7 years ago
I tried this a couple years back. Be sure you get hooks with strong adhesive. After less than a week, mine came loose!
underground carpenter 7 years ago
If you are questioning the strength of the adhesive, play it safe. Drill a hole in the hooks before attaching them, and then add a screw to reinforce it. If you are putting screws into a particle board or MDF core door, use coarse, deep threaded screws and take care not to over tighten them. The threads of standard wood screws are too dull and sheet metal screw threads are too close together. Both will do more damage than good to particle board or MDF.
fabianfred 7 years ago
yes... afraid the glass lids will fall and break.
'MillieM 7 years ago
The lids are more than likely to be tempered glass like the ones I have. I have dropped mine so many times and they have never shattered or broken. Glass lids have to be tempered in order to be used on the stove.
GHoyle121 7 years ago
Grate I am going to try this one.
thepoisonivy 7 years ago
Doing this! Thanks for sharing the evolution of the improvements to this idea, as well.
Mevlut EvrenT 7 years ago
I need this in my life - doing it tonight! Thank you!
Bought pots on sale at target. Slightly disappointed but I keep the hooks on hand and they made great storage solutions with addition of aquarium tubing. Did this about a year ago.
zapp images posted previously and here though comment seems to ignore the fact.
LenJ3 7 years ago
Great idea but you must make sure the lid handle will prevent the cabinet door from completely closing. I could be wrong but in the photo it appears to me that the handle of the lid would prevent that.
