Introduction: Easiest ESP8266 Learning IR Remote Control Via WIFI
The ESP8266 is a wonderful microcontroller. They can be purchased cheaply and have built in wifi.
In this guide I will not go over how to flash the ESP8266 module with the basic firmware as this is covered on the http://ESP8266basic.com web site in detail.
All the parts to build this project can be found on ebay for less than $10 shipped to the US.
Step 1: Gather Your Materials.
You will need the following:
- ESP8266 Module. Suggest the NODEMCU or similar board.
- Infrared LED
- IR Receiver such as the VS1838B
- Some female du-pont connectors.
- Optional USB wall wart power supply. Some TVs have a built in USB jack that can be used.
Step 2: Assemble the Circuit Using the DU-PONT Wires.
I hooked up my entire circuit using only female du-pont wires. You could get a bit more phansy but this worked well for me.
Use the circuit diagram as reference.
Step 3: Program the Module
Goto the esp8266 Basic program editor in your browser and past the following code in.
Then save your program and click run.
dim irButtons(6) as string
dim irCodes(6) as string x = 0ir.recv.setup(5) ir.send.setup(4) IRBRANCH [received]
for x = 1 to 6 irButtons(x) = read("irbut" & str(x)) irCodes(x) = read("ircode" & str(x)) if irButtons(x) = "" then irButtons(x) = "UNUSED" next x
[top] cls cssclass "button", "background-color: powderblue;height: 20%;width: 30%;" Print "ESP8266 Basic Learning IR remote" print "Last IR recvd" textbox ircode print "Text for button" textbox newtxt print "Button number" dropdown x, "1,2,3,4,5,6" Button "Program Code to button", [program] print
button irButtons(1), [bu1] button irButtons(2), [bu2] button irButtons(3), [bu3] print button irButtons(4), [bu4] button irButtons(5), [bu5] button irButtons(6), [bu6]
IRBRANCH [received] wait
[received] ircode = ir.recv.full() return
[bu1] ir.send(irCodes(1)) x = 1 wait
[bu2] ir.send(irCodes(2)) x = 2 wait
[bu3] ir.send(irCodes(3)) x = 3 wait
[bu4] ir.send(irCodes(4)) x = 4 wait
[bu5] ir.send(irCodes(5)) x = 5 wait
[bu6] ir.send(irCodes(6)) x = 6 wait
[program] irButtons(x) = newtxt irCodes(x) = ircode write("irbut" & str(x),irButtons(x) ) write("ircode" & str(x),irCodes(x)) goto [top]
Step 4: Start Teaching Your Remote.
Click the button you wish to program. There will be 6 available for you to use.
Next on your TV remote hit the button you wish for the module to learn.
In the "Last IR Recvd" text box you should see a remote code pop up. If it says unknown press the button on your remote again.
Currently this will only work with codes that say sony or nec.
Once a good code is showing in the textbox type the text you would like for your button in to the "Text for button" textbox and click the "Program code to button" button.
The button has now been set up and can be used to control the TV. Press the button in your browser and test to make sure it works.
Repeat for each of the 6 programmable buttons.
Don't worry. If you reset the module it will remember your button text and codes as they are stored in the flash memory.
Now you are done. You have an awesome tv remote that can be controlled via wifi from your computer or smart phone.
Circuits Contest 2016
LED Contest
1 Person Made This Project!
- mmiscool made it!
22 Comments
1 year ago on Step 2
Hi
I am getting the following error when I try to upload your code:
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Simple_IR_Remote:1:1: error: 'dim' does not name a type
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Reply 1 year ago
this code is not meant to be for arduino IDE ...its for basic flasher ///// me too looking for ide version of code .. i have no programming idea//
1 year ago
please can you provide code in ino format so that i can upload thru Arduino IDE environment
Question 2 years ago
which language is this, doesn't seems micropython?
if done in micropython, are you aware library to ise?
2 years ago
thanks, all these other tutorials asking for a npn transitor and dont freaking work, i guess simple is better, althought your code seems abit off(i used the sheriff code example), thanks so much!!!
Question 3 years ago on Step 4
There seems to be a problem with the code. It learns the IR code and programs the buttons, but when pressing the programmed button, the IR code LED doesnt send anything. Upon checking the voltage on the pin, the voltage on GPIO4 doesn't change when the button is pushed.
Can you help please.
Answer 3 years ago
Are you sure you have the right pin? The pins might be labled with the d numbers rather than the native pin numbers,
which ir led should i buy on aliexpress?
why dont you need a current limiting resistor?
4 years ago
Could you elaborate on this line?
"Currently this will only work with codes that say sony or nec."
Does that mean this will only work with sony or nec electronics? I am unclear as to the purpose of that statement.
4 years ago
Hi!
Just a newbie question... Once you you finished teaching your device the IR receiver is not needed, right? I should be able to remove it and use it for other projects I guess...
Reply 4 years ago
Could you please be a little bit more explicit ? I cannot understand your question.
4 years ago
Hi
I found this board that has everything, I think that is a expensive but is easy, everything is already there, I just flash it.
https://www.tindie.com/products/jorgeci/remotsy-pcb-infrared-blaster/?pt=ac_prod_search
4 years ago
What language do u use above? Can it be use aand upload from ardunio IDE?
5 years ago
Nice work - thanks for the writeup!
I have the Lua version of the esp8266. Is the Basic interpreter accessible on that board or would I need to reflash it? Or do you have a Lua version of your code?
https://www.amazon.com/dp/B010O1G1ES?ref_=pe_1763890_145073570_ste_e801_dp_2
Reply 5 years ago
You will have to flash the basic firmware on to your board.
Goto esp8266basic.com and get the llatest version. Follow the flashing instruction there for installing it.
5 years ago
Thanks for this.Nice and simple. I am going to try it. I have made an LIRC device that works on my PC (winlirc) for about 15 years. There were no ESPs then
A very practical idea would be to be able to "play" the ir_commands over network to other similar stations and so to make a network IR extender. Think of it
5 years ago
Hello, I was looking long time for a project like this
How do I know that my samsung tv uses sony or nec codes?
Also, can I add more buttons, maybe the whole remote?
Thank you.
Reply 5 years ago
Hey
I think samsung is using their own coding system
Well I also have a sammy tv and it says afde3g something SAMSUNG:32
And it will not transmit :/
I also have a sony camera transmitter
Unfortunately it also does not want transmit although it recognizes the code
I would like to have a system that works with ANY given code possible even RF
Reply 5 years ago
You can see what the code is by reading the textbox at the top of the screen.
Reply 5 years ago
YEs. you can ad more buttons.
