Introduction: Easiest One Row Repeat Crochet Scarf Pattern
Crocheted Scarves are the most fun and quick projects to whip up. With just simple stitches you can make yourself a pretty and cozy crochet scarf. They are the best options for making beautiful holiday gifts for your loved ones. The crochet patterns which work with simple stitches are the best for a quick make.
Toady am sharing a Easiest One Row Repeat Crochet Scarf Pattern. The pattern is made with simple stitches. Overall the pattern is just a repeat of one row. The repeat pattern makes this a easy and mindless project to make.
7 / 30 Inches - can be customized to any size
Visit https://rajiscrafthobby.blogspot.com/2023/06/easiest-one-row-repeat-crochet-scarf.html
8 Ply Cotton Yarn
4 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 32 + 2 Chains for the turning chain.
This measures around 7 inches.
You can adjust the size of the Scarf by altering these stitches according to your requirement.
Start with any multiple of 4 + 2 Chains extra for the turning chain.
Step 3:
Round 2:-
1 Single Crochet in the Second Chain from the hook.
1 Single Crochet each in the remaining stitches.
Once you reach end, Chain 2.
Straight Edge Turning Chain:-
Usually you would Chain 2, turn and start working the next round. Here is a quick tip to have a nice straight edge .
Insert the hook into the 1st chain from the bottom.
Yarn over and pull up a loop. You should have 2 loops on the hook.
Turn your project and insert the hook into the first stitch.(the first Single Crochet)
Yarn over and pull up a loop. You will have 3 loops on the hook.
Again, yarn over and pull through 2 loops. You will have 2 loops on the hook.
Lastly, yarn over and pull through 2 loops.
This will make one Single Crochet.
Step 4:
Round 3:-
(1 Double Crochet is already made while making the turning chain)
2 Double Crochets in the same stitch - that's total 3 Double Crochets made.
Skip 3 Stitches.
(1 Single Crochet, Chain 2, 3 Double Crochets) - all in the same stitch.
Skip 3.
Repeat((1SC, Ch2,3DC)Skip 3).
1 Single Crochet in the last stitch.
Chain 2 and use the Straight Edge Turning chain method to make the turning chain.
Step 5:
Round 4:-
**We will be making the stitches only in the Single Crochets.
(1 Single Crochet, Chain 2, 3 Double Crochets) in each of the Single Crochets.
Repeat(1SC, Ch2,3DC) in each of the Single Crochets.
Step 6:
Round 5 Onwards:-
Keep Repeating Round 4 untill the size needed and weave off.
