Introduction: Easily Re-pot Big Plants
Any garden fanatic can testify to the hassle of re-potting big plants. Only getting some plants out of the planterpots can be a real struggle! Still, some plants need a time in controlled situations to develop strong root-systems so they can be planted in open ground having a good chance at survival.
Also handy for keeping a “portable garden”, if you’re planning to move soon, only have concrete as a “garden”, giving broken buckets a second life etc etc.
I’ll be showing you how to alter your 5 and 8 gallon buckets to planters. A very simple ‘hack’ to make gardening-life just a little easier!
Step 1: Tools and Materials;
· 8GL bucket
· 5GL bucket-lid
· 40cm long tubular object (not in picture)
· Permanent marker
· Ruler
· Sharp knife
Step 2: 8GL Bucket Alterations;
If you take your 5GL bucket-lid and throw it in the 8GL bucket, you’ll see it a perfect fit! It lays on the bottom flat and there is practically no space around the edge!
We’ll utilize this perfect fit for a “faux bottom”.
Take the 8GL bucket and mark a circle on the bottom. Leave only a rim on the outer edge for the lid to rest on (so leave an edge of about 5cm).
I plunge my knife through the bucket-bottom intentionally well inside the line, as I have cut out the primary circle, I’ll go around cleaning everything out cutting it nicely along the line.
My diameter ended up 22cm and I used a sharp Stanley-knife to cut the bottom out.
Please do this carefully, as soon as I started to put pressure on the blade, I slid through 1/3rd of the bucket-bottom! After a third done I started to get the hang and steady hand for a nice cut.
Step 3: 5GL Bucket-lid Alterations;
If we were to throw the lid in as-is, the water will pool up in the bottom and maybe even along the edges if there is enough weight weighting it down to cause a seal. As you look at normal plant-pots, there are always holes in the bottom (there’s always exceptions, I know).
The lid I’m using has no slots or holes in the side like the white one in the picture does. I’ll have to cut these out manually with my Stanley-knife.
I mark off 8 slots on both rims on the bottomside of the 5GL bucket-lid. I cut out these marked rim-parts to make a sort of canal for excess water to flow out.
The middle flat part of the bucket-lid creates a basin for water to pool up in, so along the inner-rim I plunge out holes, and the very center of the lid is also cut out.
Step 4: Push-out Helper;
I use the bottom cut-out from the bucket and a piece of PVC pipe to create a “push-out helper”, to push to plant out of its pot. I used a little hot-glue to keep it in place (which is totally unnecessary!)
Make sure the standing pipe is longer or higher as the bucket is to ensure you can get a good grip on the pushed out plant.
Lift the planter (with or without help) over the “push-out helper”, center it and slowly lower it over the tube, you might have to help the bucket a little to scoot it off.
Use things like stacked plant pots, block of wood, as long as it fits the hole you made and is longer as the bucket!
Creative Misuse Contest
