Introduction: Easily Turn Cheapest Tough Meat Into the Most Tender Fall Apart Meat in 1pan
The easiest way to make fall-apart mouth watering tender pieces of meat from the cheapest toughest cuts!!
Step 1: Get Some Cheap Meat!!-this Is Stewing Beef
you will need. .. oven proof frying pan,cheap meat,oil,garlic,apple cider vinegar,salt,pepper & (herbs optional)
Step 2: Brown in Frying Pan..
Brown off in a little oil in frying pan for a few minutes either side..this helps to add more flavour & seal in juices
Step 3: Add Extra Ingredients..
take Pan off heat & add salt,pepper, a few spoonfuls of crushed garlic-(as much as you like!) & optional-whatever herbs you have around..I used parsley &thyme stalks in this one..
Step 4: The Secret Ingredient!..
The Secret ingredient!-add a dash-(about a shot worth) of apple cider vinegar. ..the vinegar breaks down the hard tissue &'tough bits'!
Step 5: Seal Pan
cover pan with foil,ensuring it's sealed completely. .. & put in oven at about 160 degrees ..for at least 2hours...
Step 6: Enjoy!
after about 2hours on low/slow bake-remove the pan.When you turn the pieces over-the pieces will be slightly caramelized &fall apart with a spoon!!
Meat Contest 2016
5 Comments
5 years ago
glad you like it dididogsrule45! Thankyou :) x
5 years ago
I love this Instructable so much I hope u win!
5 years ago
Yes,slow baking is awesome! It's amazing the difference in texture after this process.. it's a battle to cut the meat at the start-it's so tough..then afterwards it literally falls apart with a spoon!!..&yes,for sure-root vegetables added for a complete meal is great too!! cheers-enjoy! ;)
5 years ago
I can second the use of the apple cider vinegar, this can also be done in a crockpot. Brown first to seal flavors, then low and slow, I say add your favorite root vegetables as well. Thank for the Information!
5 years ago
I love slow cooking, it makes the meat so tender :)
