Introduction: Easter Egg Jello Shots
Read or watch the tutorial here :D
Step 1: What You Will Need
1. Eggs, i used 12 for my batch
2. A sharp needle
3. Alcohol (optional), i used Moscato (a sparkling wine) and Passoa.
4. Different colored sodas.
5. Gelatin.
6. Paint (optional)
Step 2: Preparing the Eggs
This is really easy, if you've ever painted Easter eggs you will have no problem with this
You gently poke a hole in each side of the egg and blow out the whats inside over a bowl
Step 3: Adding Sparkling Wine
I measured 3 dl sparkling wine in 3 different cups, one for each flavor.
Step 4: Colour
I wanted to make different colors inside the eggs so i used:
1dl Passoa to one cup
1dl Fanta to the second one
1dl green soda to the third one
Step 5: Gelatin
I used gelatin plates as i find them easier to work with than powder, follow the instructions on your packet to make sure you do it correctly.
For gelatin plates you let them soak for 10 minutes then squeeze out the water before you stir it out in hot water, not boiling water, i used only 3dl of water since i wanted my shots a bit one the strong side
I used enough gelatin plates for 1 liter of liquid.
I then poured 1dl of gelatin in each cup.
Step 6: Finishing Up
This step can be troublesome if you dont tape the bottom of the eggs good enough.
After that i used a funnel to get the mix inside of the eggs, i made 4 of each color.
Then you put it in the refrigerator for about 3-4 hours.
Happy Easter :D
