Introduction: Easter Toon Diorama
Hi, my name is Teagan and I love creating art with my dad. We enjoy working with woods, resin, different tools and paints, and experimenting to see what works best for each project.
As I had an Easter project to complete for school, ( to create an Easter Garden Diorama) we decided to build a 3D model using layers of wood.
NB. You could also achieve a similar result using cardboard if you were unable to use wood, which could be cut using scissors or a craft knife, (always use safety equipment).
I hope you enjoy learning how to make this layered model 'toon' diorama. Thanks so much for visiting my project.
Paper
Pencil
printer for the base templates
Scissors
MDF or Ply Wood ( I used 4mm Ply wood )
PVA glue
Water
Safety eye protection
Scroll saw
Sand paper
Paint brush
Coloured paints
G-clamps
Step 1: Design
Sketch an idea of what you would like to build.
Step 2: Print
Print out base templates (one for each layer) in my project i used 7 layers
Step 3: Draw
Draw each layer starting with the front one first
Trace each next layer over the last
It may help to identify each layer with a reference number
My first layer was grass, my last was a hill in the distance
Step 4: Cut Out
With scissors roughly cut out the templates
Don't cut to close to the lines as you'll need them as a guide when cutting the wood
Step 5: Stick
Mix one part PVA glue with approximately 5 parts water and brush on to the wood
stick the templates to the wood and brush the diluted glue on top again
then allow them to dry
Step 6: Saw
Use a scroll saw to cut the wood in the outline of the templates
**Always use appropriate safety equipment when using tools**
Step 7: Peel
Write on the back of the wood the layer referance number
Peel the templates off the wood (if needed brush the paper with water and allow to soak)
Step 8: Sanding
Lightly sand the edges of the wood to remove any roughness and prevent splinters
Step 9: Paint
Decorate all your layers how ever you like
I used Acrylic paint and felt tip pens
**IMPORTANT only decorate the parts you will see when assembled
Leaving enough wood clear to glue together all the layers**
Step 10: Build
Start with the last layer and use PVA (no water) and stick the layers together
Step 11: Clamp
Clamp the pieces together until the glue is dry for 30 minuets to an hour
Step 12: Finished
Remove the clamps and Tadaaa!
Woodworking Contest
3 Comments
2 years ago
That is so cute! I love the little bunny :)
2 years ago
I absolutely LOVE 💕 this project!!! Teagan is such a talented, creative & skilful little girl and it’s so fabulous to see her learning such amazing skills with her Dad!! Absolutely brilliant!!! ☺️🥰👍🏼
2 years ago
Great project! I enjoy seeing parent-child projects like this, well done to both of you!
