Introduction: Easy 3D Topographical Maps With Slicer
Here's a super easy way of making a 3D topographical map of anywhere in the world: you could literally be laser-cutting a map within 10 minutes of reading this instructable. I've always liked maps like these and there are some great tutorials out there... but the complexity had always put me off. But I recently learned how to use Slicer for Fusion 360, a plugin for Fusion 360 (free to educators, students and hobbyists) that slices up STL files into pieces that you can stack together and make a 3D model. So I figured all that I needed was a utility that converted terrain into an STL, and happily, there exists one in Terrain2STL.
Note: this instructable was updated in January 2018 to reflect changes in the software.
Step 1: Select Your Area of Interest
Go to the wonderful Terrain2STL utility. You will be greeted by an interactive Google map. Navigate to the geographical area of interest by zooming and dragging, and click "Center To View". Go next to Model Details, and use the Box Size slider to make the red box large enough to incorporate the feature you want. Be aware however that the larger the feature you select, the bigger the STL file you will end up downloading. To start with, I suggest you pick a box size of 1080 or smaller. You're ready to make your STL file! Click Create and Download.
Step 2: Slice It
If you haven't already, install the Slicer plugin for Fusion360.
Open Fusion 360 and make sure you're in the DESIGN space, and select Insert... Mesh. Browse to your downloaded STL file, and open it. Now go to Tools... Make... Slicer for Fusion 360, and it will launch as a new program (which used to be a standalone product called 123D Make).
KNOWN BUG: if you get the error message "File has failed to open in Slicer for Fusion 360, please try again", select instead a simple non-STL geometry (e.g. draw a sphere) and open that. It will launch Slicer, and at that point you can open the STL file you want to use just fine. Thanks to jon-a-tron for answering this on the Autodesk Forums.
You will end up slicing the model, and you may have to rotate the Slice Direction so the material stacks as horizontal layers.
It is important to consider what you are going to make the model out of. Click on the pencil under Manufacturing Settings and specify the width, length and exact thickness of the material you are going to use. Under Select a Technique... choose Stacked Slices. Now, adjust the model size until you get a form that is pleasing. Very often, you will need to exaggerate the vertical scale to get interesting topography, and to get the features you want accurately displayed you may have to tweak the overall size of the model. Once it has taken a form you like the look of, click on Get Plans (the Nested option uses material slightly more efficiently) and export the plan as an EPS file.
I strongly recommend starting with cardboard - the material itself is cheap and the cutting time is fast.
Step 3: Clean Up the Files and Prepare for Laser Cutting
Open the EPS file in Illustrator or Inkscape or CorelDraw or whatever vector drawing program you like, and tidy up the files. I delete the border, delete layers I don't need (often full sheets with no features on them that are generated because the feature I'm mapping is at high elevation), and improve the nesting for efficient cutting. I also delete the numbers and pinholes* from the top layers.
I then set the line thickness to 0.001" (which the Epilog lasers I was using recognize as cuts rather than rasters), and enable color mapping. Set blue up to cut (whatever setting is appropriate for that on your machine) and red up to cut but at maximum speed and a MUCH lower laser power, so it only very lightly scores the surface.
* these are added by Slicer to aid assembly, but topographical maps are easy to put together because the shapes are all unique and there are no overhangs, so you don't need them.
Step 4: Laser Cut and Assemble
Send your files to the laser cutter (or service). Free all of the pieces from the sheet and lay them out in numbered order.
Assembly is easy and quite fun for simpler maps. Just glue each layer one at a time (you did lay them out in order, right?), using the scored lines as a guide. You pretty much can't go wrong provided you're careful to line everything up.
This example was Mt Taranaki, a beautiful Fuji-esque volcano on the west coast of New Zealand's North Island, rendered in corrugated cardboard. The vertical scale is slightly exaggerated. This glue-up took me 10 minutes. The time lapse was recorded using my orbiting time lapse rig.
Use the appropriate glue for your material. A glue stick is fine for cardboard.
Step 5: Add Water
I really wanted a version with water that showed depth, so I got some pale blue transparent acrylic and used it to represent water. Terrain2STL does not provide bathymetric data (which would be cool!),* but for the effect you want it doesn't really need to be super-accurate. I just looked up a bathymetric map and eyeballed a few layers. You will need to cut the underwater land (I hope that makes sense) out of plywood (or whatever) and the water out of acrylic. Use more than one layer for best effect. This example was done with Tuhua (Mayor Island), a dormant volcano off the coast of New Zealand near where I grew up. It's far enough off shore that it is sometimes lost in the haze, but big enough that when it does emerge it looms enigmatically on the horizon. It's spectacular; the hiking and fishing and snorkeling are all world class.
I liked the look of the island in its raw plywood + blue acrylic form, so didn't bother finishing it.
* I've corresponded with the author of Terrain2STL on this topic and got this reply "As for bathymetry - do you know of a good global bathymetry data set? I've looked into it a bit in the past but I haven't found a good, global map for ocean depth. Do you know of any? I'd definitely be interested in looking into adding it to the site if we can find a good dataset." Anyone?
Step 6: Experimenting With Finishes
I tried making the area around where I live (Saanich, BC) out of green stained plywood and one layer of acrylic for the water. This map was really fussy to make, and I strongly advise starting with something simpler. All those tiny islands were a pain in the neck. If you end up with too complex a map, consider smoothing it in Fusion 360 before slicing it, or simply delete the smaller features altogether.
7 People Made This Project!
- Wilding87 made it!
- ZB45 made it!
- Gluboy made it!
- TwelveFoot made it!
See 3 More
73 Comments
4 months ago
Is there some trick to getting the red outlines of the layer above to show? I've been messing with the settings and trying google for an hour with no luck.
Question 1 year ago
Hey, I'm having problems using Slicer for fusion, whenever I try to export a EPS file, It does not work. Do you know any way to possibly fix this problem or an alternative to Slicer for Fusion?
2 years ago
I'm excited to try this, but whatever I try, I get an error from slicer. When I try to run slicer from Fusion 360, I get an error "The file has failed to open in Slicer for Fusion360, please try again." And when I try to import directly into Slicer, I get the message "Import Failed Mesh could not be imported." Any suggestions?
Reply 2 years ago
I think I've solved my issue. Changing the water drop to 2mm creates an STL file that slicer isn't able to open (at least for me). Leaving water drop at zero is working fine (so far).
Reply 2 years ago
Thanks for letting me know, David. Glad it is now working
Reply 2 years ago
Hmm... is it an enormous area? If the stl file is very big Slicer does seem to get indigestion. Try with a smaller area and see if it still happens
Reply 2 years ago
Nope, I get the same error even with the smallest area I can select.
Slicer is working for simpler parts, however, so I do suspect complexiry may be playing some role.
Reply 2 years ago
Hi David! Solved, and I have updated the instructable to reflect the bug (see Step 2). Thanks for drawing it to my attention, much appreciated.
Reply 2 years ago
I must still be doing something wrong, because I can get the sphere into slicer, but I still get the error when I try to open the topo. Can you provide a bit more detail?
Reply 2 years ago
So once I have Slicer open, I can open new files from within Slicer (ie not using Fusion360 anymore) including the STLs from Terrain2STL. Are you getting an error dialogue from Slicer or from Fusion 360?
Reply 2 years ago
I went and tried it myself, and yes, you're correct: I get the same error. That is very disappointing. I will reach out to Help and see if I can find out what the issue is.
Tip 2 years ago
Looks like the slicer is a plugin now:
https://apps.autodesk.com/FUSION/en/Detail/Index?i...
3 years ago
I would love to make this. Unfortunately 123d is no more. Can anyone advise what software I could use to replace it to do the same job? I’m new to the laser cut world so any advise would be gratefully received. Thanks!
Reply 3 years ago
Instructable now updated for Slicer for Fusion 360. Let me know if you have any issues.
Reply 3 years ago
That's amazing, i will try this shortly and let you know how i get on. Thanks again.
Reply 3 years ago
It's now part of Fusion360, and is called "Slicer". I will try to get this instructable updated when I have some spare time... in short supply at the moment! If you get Slicer working any feedback very welcome
3 years ago
Thank You so much for putting this together. I just got my GlowForge and I'm trying to jump right in. It seems that Terrain2STL isn't detailed enough for my needs. I'm trying to do a mountain that's approx. 3 miles x 3 miles. Mine is coming out really blocky. Is that normal? Is there a way to get higher quality files?
Reply 3 years ago
That is normal, the resolution is pretty low. I don't doubt there are higher res topographical maps out there, but I don't know of ones that also neatly convert into .STL files. If you find a source, please let me know and I will update the instructable
3 years ago
if i wanted to make one of a lake, how would i go about doing that?
Reply 3 years ago
See step 2. Bathymetric data not available in Terrain2STL
