Easy Amazing Onion Rings
Introduction: Easy Amazing Onion Rings
About: Hello and Welcome to In the Kitchen With Matt. I am your host Matt Taylor. My goal for the show is to teach you how to cook really good food at home for cheap. Eating out everyday can get expensive, but it doe…
In this instructable, I will show you how to make onion rings. Onion rings are really yummy a great substitute for french fries, or you could do a half french fry half onion ring plate! This recipe is really easy to make, if I can do it, you can do it. Let's get started!
If you have any questions or comments, put them down below and I will get back to you as soon as I can.
Follow the easy steps below or watch the video tutorial, or do both!
Step 1: Ingredients
Print this recipe here if you like.
Ingredients:
  • 1 large onion (I like to use sweet onions)
  • 1 1/4 cups of all-purpose flour/plain
  • 1 tsp of baking powder
  • 1 tsp of salt
  • 1 egg
  • 1 cup of milk
  • 1 cup or so of bread crumbs (panko works well, or the traditional kind)
  • Oil for frying (canola, vegetable, etc)
Tools:
  • Tongs
  • Fork
  • Bowls
  • Pie Pan
  • Knife
  • Wire rack
  • Pot
  • Thermometer (I don't always use one, on my stovetop medium heat usually heats my oil right around 350 degrees F.)
Step 2: Prep the Onion
First let's prepare the onion. I am using a large Sweet Onion, but you can use whatever onion you like. Peel and then slice the onion. Keep it to about 1/4 inch wide. Then separate the pieces to make the rings.
Step 3: Mix Dry Ingredients
Now we mix the flour, the baking powder, and the salt together with a fork or a whisk.
Step 4: Dip Onions Into Flour
Now we dip all of our rings into the flour mixture. Then set them aside, I usually just pile them up in a bowl.
Step 5: Make Batter
Now it is time to make our batter, add the milk and the egg to the flour mixture and stir it with a fork or a whisk, until it is well combined.
Step 6: Dip Onions
Next we dip our onions into the batter, then place them on a wire rack to let the excess drip off.
Step 7: Dip in Breadcrumbs
Now we dip those batter coated rings into our breadcrumbs. I like to use a pie pan because it provides a nice flat bottom. Use a fork to help scoop the crumbs over the battered ring.
Step 8: Fry Them Rings!
Now it is time to fry up our onions! Pour your oil into your pot until it is about 1.5 inches deep. Then heat up the oil to about 350 to 360 degrees. I use canola oil, but vegetable or olive oil will work too. Use a candy thermometer if needed to get the right temp for the oil. I know that if I put my stove on medium and maybe just a bit past medium that it gets the temp where I want it. Now we use a fork and place a few rings in the oil. Turn them over periodically, continue to fry them for a minute to 3 minutes, until they are nice and golden brown. Then place on a wire rack to let excess oil drip off. You are done! Nice crunchy yummy onion rings, now enjoy them!
Step 9: Video Tutorial
You may print this recipe here if you like.
Be the First to Share
    • Big and Small Contest
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    44 Comments
    nunc
    nunc
    6 years ago
    Very nice I am sure BUT. What do you do with all the tainted oil.? If you throw it away then they are very expensive onion rings
    brothertuck
    brothertuck
    Reply 6 years ago
    First get a good cooking oil like peanut oil, never use olive oil to deep fry, peanut oil doesn't break down as fast. Strain as was said, I use a fine strainer then restrain thru a coffee filter.
    In The Kitchen With Matt
    Reply 6 years ago
    You can store and reuse the oil several times before it goes bad. :) I usually store mine in a large Mason Jar with a lid. With that said though you don't want to use the same oil with chicken, then store it and then use it for fries or onion rings.
    nunc
    nunc
    Reply 6 years ago
    Thanks for that. What do you consider to be a the number equating to "several" times?
    Reply 6 years ago
    That is a great question. I will throw mine out when it starts looking cloudy or foamy on top, or definitely if it smells rancid. The number of times will vary, if you strain the oil after it cools, that will help it store longer. It also depends on how much you use it each time. Somewhere between 5 to 7 times. Again it will very though. I hope that helps.
    nunc
    nunc
    Reply 6 years ago
    Thanks again. I'll give it a try sometime this week.
    Adrian N.
    Adrian N.
    6 years ago
    Is there something that can be used instead of milk? We're trying to cut off dairy and meat products as much as we can.
    brothertuck
    brothertuck
    Reply 6 years ago
    Beer, turns it into a beer batter or rice wine or sake for tempura type batter.
    Reply 6 years ago
    You can try almond milk or something like Sprite or 7up, or canned coconut milk. :)
    KariL10
    KariL10
    Reply 6 years ago
    I'm going to try to make this a Paleo version which is dairy and grain free. Coconut milk in the can is a great alternative to milk in most recipes.
    Reply 6 years ago
    mmm you could try almond milk? I am haven't tried it yet, but It will probably work fine. :) or you could try using sprite or 7 up, as well.
    Reply 6 years ago
    Thank you!! Try them out and let me know how you like them. Seriouseats.com is an awesome website. I go their quite regularly!
    Chris W.J
    Chris W.J
    6 years ago
    Made these for lunch today. Man, they cook FAST. Really really good!
    hilojohn
    hilojohn
    6 years ago
    This same batter technique works well with fish. Great instructable, you did everything precise with no wasted time or un needed info. I hope to see more from you.
    Reply 6 years ago
    thank you!! :) I really appreciate it. I have 63 instructables on here. Check them out when you get a chance. :)
