Easy Build Heat Treat Furnace - No Power Tools Required.
58,785
434
32
Introduction: Easy Build Heat Treat Furnace - No Power Tools Required.
About: I like making things.
Steel is an amazing material. Take some pure iron and put in a bit less than 1% carbon and you've suddenly got a markedly different alloy. Steel is generally stronger than pure iron, and can be made to be harder as well. Mix in small amounts of other elements and you can make it resist rust, make it flexible and springy, make is super hard and increase it's tensile strength.
In order to get the most out of steel, it generally needs to be heat treated. Different types of steel require different treatments, however the general outline is that it must be heated up to above a certain critical temperature, held at this temperature for a period of time and then rapidly cooled by dunking it (quenching it) in a liquid such as oil or water. Finally, after the hardening process, it usually needs to be tempered - whilst hardening makes it considerably harder, it also makes the steel more brittle as well. Tempering restores some flexibility and springiness to the metal.
I've made a small furnace for heat treating steel, with a MAP gas torch, it will should hot enough to heat steel to a cherry-red heat.
From a few online guides, to heat treat 1084 steel, you need to get it up to around 815°C (around 1500°F).
I'm using some flat stock that is around 3mm thick (0.125") so I probably need to hold the steel at the hardening temperature for 5-7 minutes.
The goal of this furnace was to use some readily available materials to make an insulated enclosure that can withstand that kind of heat and keep the heat in one place long enough for the metal to reach these temperatures.
As guide to the correct temperature, you can heat until the steel is red-hot and then try a magnet on the metal. If the magnet is attracted to it, you need to go hotter. Once iron (which steel is predominately made of) reaches 770°C (1418°F) it hits it's Curie Temperature - this is the temperature at which the metal undergoes a significant change in it's magnetic properties, below this temperature a magnet is attracted to the steel, above this temperature the magnet is no longer attracted. This isn't quite hot enough for the 1084 steel to reach it's optimum hardness, so we need to go just a bit hotter, from a deep cherry red to a slightly more orange colour.
Step 1: What Will You Need
I went to my local hardware store and was able to get most of these items in one trip.
I started out with a block of Hebel which is a brand of Autoclaved aerated concrete common here in Australia.
Concrete is not ideal for this as it breaks down under intense heat, however it was a lot easier to find than aerated fire bricks and will get me through at least a few heat treat cycles.
I got a MAPP Gas torch with a diffused flame - MAPP gas burns a lot hotter than regular LPG (Propane). Look for the yellow cylinder. Make sure the torch attachment you get is suitable for MAPP Gas.
I picked up a few other misc items, some small 90° brackets, some tie wire and a respirator (you really don't want to get concrete dust in your lungs).
For tools, I had everything I needed lying around - an old hand saw (do not use your good saw for this!), some putty knives/scrapers and a large masonry drill bit (big enough to drill a hole to accept the burner for your gas torch)
Step 2: Shaping the Chamber
My Hebel blocks were pretty long, so I was able to cut one in half and still have room to make a big enough chamber. Hebel cuts very easily, even with a blunt saw.
I wanted the chamber to be roughly cylindrical, so I started by putting the two blocks together and sketching an oval/circle on the end. Those marks on the bricks were from the rust on my old saw.
Once I'd worked out the size of the chamber at the end, I drew some guide lines down the blocks so I knew where I had to remove the material.
Step 3: The Fun Begins!
Whist the Hebel is pretty easy to cut, you there's a fair amount you want to remove - it's also very brittle so you want to be careful that you don't attack it too enthusiastically.
I found that the best way to dig it out was to make some parallel cuts with the saw and then break out large chunks of it, and then scrape and smooth it down with the putty knife.
In retrospect, it would be a lot easier if you were willing to cut the back of the chamber off and then re-attach it again, but it would be difficult to seal it up so I avoided doing this.
Step 4: Test Fit
Once you've scooped the middles out of the blocks, put it together and make sure everything lines up.
At this stage I also rubbed the blocks against each other in a circular motion to smooth the mating surfaces so hopefully there would be less heat lost down the seam.
Step 5: Drill Hole for the Gas Torch
Make sure you've got a drill bit as large as, or slightly larger than, the burner on your torch. Drill a hole through the side at an angle - you want to come in at a tangent to the top of the chamber - the idea is that this will help the heat swirl around and even out the temperatures inside the chamber.
Step 6: Insert the Torch
Here you can see the torch inserted into the hole. I had the hole on the top while I was testing it, however when I use it for heat treating, I'll flip everything over and have it on the bottom.
In the second photo, I've got the torch in too far, but this was just so you could see it more clearly.
Step 7: Tie It All Together
I got some small angle brackets at the hardware store. They had these long ones for $2 and some short ones the size I needed for $1.75. As I needed 8 brackets, and I could cut down two of the long brackets to make 8 small ones, I got the long ones. I also got some tie wire - this wire is galvanised which is usually a big no-no when using with anything that gets hot. Burning zinc produces toxic fumes. The outside of this oven isn't going to get hot enough for this to be an issue.
Wrap a couple of strands of wire around the blocks to hold them together, and use the angle brackets to protect the soft corners of the blocks from the wire digging into them.
Step 8: Fire!
And you're done, time to light the torch, put it in the hole in the side and see how hot it gets inside.
Within a few minutes, I was able to get a test piece of metal to a dull red heat.
I don't think it will be able to maintain this temperature for the whole cavity in the blocks, so the next thing I'm going to do is slice a flat piece off another Hebel block and make a door for the front to keep the heat in.
Concrete and Casting Contest
Runner Up in the
Epilog Contest VII
Epilog Contest VII
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • Big and Small Contest
    • Game Design: Student Design Challenge
    32 Comments
    Stan1y
    Stan1y
    7 years ago on Step 8
    I used to work for a company in the UK that made this style of block they use fly ash pumice and airated clay granules as aggregate and make a adequate base for a brazing hearth. They need to be kept dry though for this as steam will not escape as quickly as water gets in and they tend to crack and spall quite badley if you get them this hot when they are damp.
    FlorinJ
    FlorinJ
    Which is why it might be a good idea not to use a gas flame, but go with hardwood and an air pump instead. You can get iron to light yellow with such a setup - and it works for larger pieces too. Plus, it will diffuse some additional carbon into the piece's surface, making it harder, but leave the core elastic and soft - usually what you want from any steel part.
    If you do use a wood fire, you can also go with regular bricks, since such a fire heats them up slowly, allowing for moisture to escape before the high pressure steam cracks the bricks.
    kai.h
    kai.h
    The next move I've got planned is to use some old brake discs off my car as the base for a small charcoal forge. I'll be sure to post an instructable of that when I do too...
    FlorinJ
    FlorinJ
    I wouldn't use something metallic for the base of a forge. Metal conducts heat way better than ceramic, hence you'll have a lot more heat loss.
    kai.h
    kai.h
    Most forges are made from metal. Whilst ceramic may be better able to resist heat, and not conduct heat, metal is stronger and easier to form into the correct shape.
    terrefirma
    terrefirma
    Wouldn't concrete be more ...formable? Fireplaces have a certain type of white bricks that I assumed were concrete.
    corradini
    corradini
    Reply 6 years ago
    Concrete has enough water content, even after a long cure, that it will often not just spall/crack but actually explode, in contact with high temperatures. It's also really dense. The "certain types of white bricks" you're referring to are firebrick, which is a bit specialized. For extremely high heat in kilns and temp ovens, it's even better to use specialized bricks that are almost like ceramic sponges. (Fortunately, they're cheap, easy to cut with anything more than a butter-knife, and fantastically good at keeping crazy heat on one side from passing through to the other.)
    FlorinJ
    FlorinJ
    None of the traditional forges I've seen, in villages around here which still have a blacksmith, is made of metal. All are built from bricks. They're typically an elevated small basin filled with charcoal, into which the blacksmith blows air with a bellows, when he needs more heat. The embers mostly don't touch the bricks, they sit on a layer of ash from previously burned charcoal - which is also a good thermal insulator. The blacksmith adds more or less charcoal to the fire, grouping it into a pit into the ashes, depending how large/small the piece he as to work on is, to keep heat concentrated.
    Things may be different with industrial/modern forges, though. And traditionally metal was expensive, which may have been a reason to settle on building forges from bricks, which were cheap.
    corradini
    corradini
    Reply 6 years ago
    Also: metal burns - quite literally. Oxidation can be slow, i.e. "rust", but there're faster processes too: heating the heck out of iron/steel in the presence of oxygen will eat it. (That's (more or less) what scale is.) Whereas: ceramics, pretty much by definition, are metal oxides. Meaning they've been, well, "pre-burnt". That's why fireplaces are built out of firebrick, potters use ceramic liners in kilns, and so many bread/pizza ovens are built with mud, clay, and stone. It's not the cost or effort of making things from metal (although those are also prohibitive!), or insulation issues (although that's relevant too) - it's that the fire will eat the metal.
    And then you don't have an oven, fireplace, kiln, etc., anymore.
    Backyardhobbies
    Backyardhobbies
    Reply 7 years ago
    I think you mean brake drum.
    kai.h
    kai.h
    Reply 7 years ago on Step 8
    Thanks for the info, Stan1y - it's good to know that the Hebel is up to the task - I've noticed it starting to get very dry and brittle where it's had direct flame on it, but other than that it seems to hold up well. I had my first heat in it today and with a couple of small tweaks, I think it's going to be quite decent.
    https://www.instructables.com/id/Heat-Treating-1084-High-Carbon-Steel/
    LegendofPedro
    LegendofPedro
    Would adding a small sacrificial Hebel diffuser at the back help?
    kai.h
    kai.h
    That's a really good idea - I'm going to try relocating the port for the gas torch to around 1/3 the way down, instead of at the end. This will hopefully even out the temperature a but along the length of the blade. I'll also try putting a diffuser in there as well and see how it goes
    GaryC6
    GaryC6
    7 years ago on Step 4
    It would not be difficult to seal gaps like from end being cut off, if you use furnace cement. It used to be sold in an 8oz can and was a black paste. However what I am talking about I last used in the late 1960's for a science project and may have contained some asbestos. But, talk to an HVAC supply house and I'd bet you will find something. If nothing else you can use Sodium Silicate with some fine sand in it made into a paste. You will have to use it quickly thought after you mix it.
    kai.h
    kai.h
    Reply 7 years ago on Step 4
    That's some great info - it would be considerably easier to cut out a channel through the whole length of the brick, instead of trying to keep the end on there like I did.
    Luke0B
    Luke0B
    Question 2 years ago
    How well did the Hebel hold up? I'd love to know! I'm thinking of making something similar.
    gpavlovsky
    gpavlovsky
    2 years ago
    Nice and simple! I was a bit surprised to see the cordless drill when the title said "No Power Tools Required"
    Backyardhobbies
    Backyardhobbies
    7 years ago
    Nope sorry this is insufficient as a forge. It will not heat evenly and does not have enough airflow for the optimum forging temperatures. This concert will also break down and become very brittle after reaching proper temps for forging. Kao wool is a must for insulating and can be used as a liner in a metal drum or tank such as an old propane tank, then you can place fire brick inside or coat the lining with satinite refractory cement. You will definitely need forced air flow for reaching proper forging temps.
    kai.h
    kai.h
    That looks like a much better forge - you're right, the temperatures in mine are not even, it's a lot hotter at the end with the gas torch and considerably cooler at the open end. I'm going to have to do it properly one day soon and yours looks like a good way to do it.
    Where do you get "hebel blocks" for ths project? I searched Lowe's,home depot, & Amazon.
