Easy Build Wine Spike
Intro: Easy Build Wine Spike
Summer is for catching up with friends, old and new, over some home cooked food and good wine . . . .
I don't know about you but as the hours pass and numbers dwindle I always end up settled down in some comfy garden chair chatting. At the end of my first glass of vino I then go in search of more vino and a wine spike.
The wine spike is a "holder" that I dreamt up one afternoon when I realised that I had poured far too much wine into the lawn. It can hold a glass of wine securely along the bottle of wine (my favourite) or just glasses or wine.
STEP 1: Materials
I love projects that are simple so this one especially strikes a cord. The only thing you need is a board that is approximately 1000mm long by 100mm wide. Thickness is whatever you have, be it 10mm or 25mm, all will work.
Ultimately you need to have 3 pieces of wood approximately the following lengths, the same width and ideally the same thickness but it not this is not the end of the world :-)
Upright approximately 400mm long
Bottom support approximately 150mm long
Top support approximately 200mm long
STEP 2: Wine Bottle Holder
As part of the research into this project I did intensive testing of wine bottles and their contents. The benefit was that when I came to cutting the hole to retain the wine bottle I was fully aware of size variations and knew that a 90mm diameter hole would be good for most bottles.
So I loaded an appropriately sized cutter into my pillar drill, clamped the wood securely to the stand and started to cut the hole. Hole cutters have a central drill bit that helps align the cutter and this means that when you have drilled down 3/4 of the distance you can flip the wood over and complete the cut. The benefit of this is that you reduce the amount of splintering or breakout that occurs on the surface.
STEP 3: Cutting the Joints
The wood I have used for this build is a 1 metre piece of oak board left over from another project. The benefit of this is that the width and thickness are going to be consistent along the whole board.
This means that it is an ideal project to use half lap joints on. A half lap joint is one where you remove half the material each of the two pieces of wood that you wish to cross over.
So the starting point is to get the width of the wood, halve it and add a little bit back on :-) So for my project the width of the wood was 98mm. Half of that is 49mm and I added an extra 2mm back on to ensure that when the join comes together the edges of the wood are nice and flush with each other. I will be cutting out 51mm of material in each half of the joint.
To cut the joints by hand you would mark out where you want it on the wood and use a tenon saw to remove the bulk of the material before cleaning and final sizing with a sharp chisel.
I am fortunate enough to have a table saw so I will be using this to make the joints because it is nice and quick. The table saw method involved adjusting the height of the blade so that is protrudes 51mm. With the mitre gauge set to cut 90 degrees to the blade, the wood is run over the blade, returned to its original position and moved along so that the next pass removes the next bit of wood. I repeat this until all but a very small slither of wood remains to be removed. I can then test to see if the wood slides over the other piece and know how much I need to remove to make a nice snug fit.
Two halving joints are required on the upright and one each in the middle of the remaining two pieces.
STEP 4: Wine Glass Holder
The top of the wine spike at this point has the large hole for the wine bottle and the housing joint.
By replacing the wooden disc cut out previously you can work out the distance from the centre of the hole to the side of the joint. This is the distance from the other side of the joint where you will create the wine glass holder hole.
So the hole cutter is replaced by a forstner bit in the pillar drill and the hole is started to be drilled out. Before you go all the way though you need to take a perpendicular line from the centre point to the side of the wood. This is where you will be making a break in the wood that the wine glass stem will pass through.
When the hole is finally cut all the way through, I took the wood and run it through the table saw a couple more time to create the break.
STEP 5: Finishing Touches
Just a couple of small finishing touches needed now; all pieces were given a light sanding and the bottom of the upright was trimmed to create a spike that will go into the ground. A bit of oil wiped over the wood and it is complete.
Slot the 3 pieces together, stick it in your lawn and you are ready to go . . . .
Variations of this would be :
- make it as a double wine glass holder with no bottle
- make it single sided
- round over all the edges
3 Comments
Ismegordo 8 years ago
But just because something is Simple doesn't mean it's any less impressive than anything else.
I voted for you, So Good Luck with the Contests and I hope All goes well.
Well Done and Thanks for Sharing, I can see me having to make a couple of these over the next holiday break.
skibum30 8 years ago
Logisticz 8 years ago
Thats awesome and yet so simple to make! I will definitely make one for my stepmother, she's a wine-o-holic (in the good way :D)
thanks!
