Introduction: Easy Crochet Textured Washcloth Pattern
Crocheting a washcloth is Super Easy. Crochet Washcloth patterns are the best option for a easy and quick project. They make great functional household crochet projects. Washcloth Patterns and very versatile. Typically crochet washcloths are made in square shape, but you easily make them in any shape you need just by changing the starting number of chains.
Today am sharing the tutorial for Easy Crochet Textured Washcloth Pattern. It’s a easy and quick working pattern. The Pattern is made with the Basic Crochet Stitches. The textured Finish of the Washcloth is made by making the stitches in one row below the current row. This also makes the washcloth dense which is great to use.
You can also use any yarn of your choice but When it comes to Washcloths, cotton yarn is the best yarn to use.
8 inches- Customizable to any size
Crochet Terms Used:-
US Crochet Terms
Visit
https://rajiscrafthobby.blogspot.com/2025/04/easy-crochet-textured-washcloth-pattern.html
8 Ply Cotton Yarn
5mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 32.
This measures around 36 inches.
You can adjust the size by altering these stitches according to your requirement.
Start with any multiple of 4.
Step 3:
Round 2:-
3 Double Crochets in the Fourth Chain from the hook.
Skip 3 Stitches.
3 Double Crochets in the next stitch.
Skip 3 Stitches.
Repeat(3DC, Skip 3)
1 Double Crochet in the last stitch.
Once you reach end, Chain 2 and Use the Straight Edge Turning Chain Method to make the Turning Chain.
Straight Edge Turning Chain:-
Usually you would Chain 2, turn and start working the next round. Here is a quick tip to have a nice straight edge .
- Insert the hook into the 1st chain from the bottom.
- Yarn over and pull up a loop. You should have 2 loops on the hook.
- Turn your project and insert the hook into the first space.
- Yarn over and pull up a loop. You will have 3 loops on the hook.
- Again, yarn over and pull through 2 loops. You will have 2 loops on the hook.
- Lastly, yarn over and pull through 2 loops.
- This will make one Double Crochet.
Step 4:
Round 3:-
(1 Double Crochet is already made while making the turning chain)
1 Treble Crochet into the Middle Stitch of One Row Below i.e into the Middle Stitch of Round 1.
1 Double Crochet into the same space.
Skip the next 3 Stitches. We will be working only in each of the spaces.
Repeat(1DC, 1 Trbl(in middle stitch of 1 Row below) , 1DC).
Chain 2 and use the Straight Edge Turning chain method mentioned in the previous round to make the turning chain.
How to make a Treble Crochet??...here it is.....!!
- Yarn over hook twice, insert hook in the Stitch and Pull up a loop.(4 loops on hook).
- Yarn over, pull through 2 loops on hook (3 loops remain on hook).
- Yarn over, pull through 2 loops on hook (2 loops remain on hook).
- Yarn over, pull 2 loops on hook (1 treble crochet complete).
Step 5:
Round 4:-
1 Treble Crochet into the Middle Stitch of One Row Below i.e into the Middle Stitch of the 3 Double Crochets.
Chain 2 and use the Straight Edge Turning chain method to make the turning chain.
Step 6:
Round 5 Onwards:-
Keep repeating Round 4untill the size needed.
Once you reach the size needed, Chain 1 and turn your project.
Step 7:
Border:-
1 Single Crochet in the 1st stitch.
1 Single Crochet into the Middle Stitch of One Row Below i.e into the Middle Stitch of the 3 Double Crochets.
1 Single Crochet into each of the Double Crochets.
Repeat(1SC (into the Middle St of the 3DC Bunch from 1 Row Below),1SC(into each of the DC)).
Once you reach the end, weave off .
