Easy DIY Coasters
Intro: Easy DIY Coasters
Part 1: Make something you can use with this quick project!
STEP 1: Rolling Out Your Clay
We are going to begin by rolling out a slab of clay. We have chosen a low fire white clay with grog from Standard for this project, but you can use any clay you are comfortable with. You can roll out a slab of clay either by using a rolling pin or a slab roller. We used our 22" Mini-Might II Table Roller to roll out this slab.
STEP 2: Choose Your Stamp Tool
Next, choose a stamp tool. You can use any type of texturizing tool that you have on hand. We've chosen the MKM Big Handroller #34. These handrollers by MKM work great for adding continuous texture to the whole slab.
STEP 3: Cut Out the Coasters
Once you have added texture to the whole slab it is time to cut out the coasters. We selected a 4" square tile cutter to create coasters that will fit under a standard glass or cup.
STEP 4: Forming the Shape
Forming a shape with the tile cutter is easy. Position the cutter directly on the slab and push down through the clay on the sides of the cutter. Once you have cut all the way through the clay, release the tile cutter by pressing the release button.
STEP 5: Continue Cutting Coasters
Continue cutting coasters with the tile cutter to your hearts delight. Allow the clay to set up enough so that the coasters can be handled without affecting the texture or the flatness.
STEP 6: Finishing Up
Wipe the back of the coasters with a wet finishing sponge to clean up the underside. It is a good idea to dry your coasters between two sheets of drywall. Just cut a standard 4' x 8' x 3/8" or 1/2" sheet of drywall down into a few smaller pieces and use duct tape to seal in the edges. Lay your coasters on one sheet of drywall and place another sheet on top of them. The drywall pulls the moisture out of the clay evenly and helps to prevent the pieces from warping. When the coasters are mostly dry, transfer them to a wire rack until they can be bisqued.
Stay tuned! In our next post, we will show you how we glaze and finish these coasters.
