Introduction: Easy DIY Paint Can Shaker. Never Shake Spray Paint Again!!!
Never shake spray paint again!!! In this video I show you the best and easiest way to shake a spray paint can by converting a commonly used power tool. I convert the reciprocating (sawzall) saw and a clamp into this magical devise. You may have seen other videos out there using a hand drill but this DOES NOT WORK! All it does is rotate the can, it doesn't actually shake it. This spray paint shaker actually SHAKES the can up and down, providing maximum ball movement.
Step 1: Check Out the in Depth Video!
Step 2: Gather Materials
You will need
1. 12" Clamp- https://amzn.to/31Lz11l
2. Reciprocating saw (cheapest one) - https://www.harborfreight.com/6-amp-variable-spee...
3. Reciprocating saw (the one I use) - https://amzn.to/3upJNGZ
4. Saw Blades (cheapest) - https://amzn.to/3upJNGZ
Step 3: Tape Two Saw Blades Together / Drill
Tape two reciprocating saw blades together to align properly for drilling. Drill two holes through both saw blades.
Step 4: Grind Off Clamp Knob / Drill Holes
If your clamp has this little knob, grind it off, then line up the saw blades to the clamp base, and drill out the correlating holes.
Step 5: Thread the Bolts and Secure With Nuts.
place the clamp base between both saw blades. Insert bolt and secure with nuts. Grind off access bolt.
Step 6: Insert Saw Blades Into Reciprocating Saw and Test.
Test out to see if everything is secure. Attach paint can to clamp. Test it out!
Step 7: You Are Finished!
Be sure to check out the in depth video (with some commentary)!!!!
