Introduction: Easy DIY Porch Rail Decoration Hangers
About: I've been building up gadgets from scraps and re-missioned tech since the days when a 555 was considered high function silicon. People doing such things weren't called "Makers", but that's what it wa…
A porch railing is a convenient and prominent location to hang holiday decorations such as strings of lights or garland. This instructable shows an easy and inexpensive way to hang those decorations in minutes. The railing is not modified in any fashion, and the decorations come down as quickly as they go up.
What you'll need is several feet of single conductor, solid core electrical wire of a gauge stiff enough to hold a section of your decorations.
A pair of wire cutters to cut sections for fashioning the hangers is the only tool needed.
Step 1: Select Your Wire
I got my single strand of insulated electrical wire from a length of 14 gauge three conductor Romex left over from a previous project. I slit the outer casing to separate the white, black, and uninsulated copper ground wires. My railing has white spindles, so I chose to use the white insulated wire for my hangers.
Step 2: Fashioning a Hanger
The process for forming a hanger is quite simple.
Take one end of the long hanger wire and place it pointing down behind the rail. Bend the wire under the rail, forward past a spindle or post, across the front of the spindle and back along the other side off the spindle.
Now bend the long wire coming up from behind the railing so that it crosses over the top of the railing and then bends towards the ground.
Cut the long wire at a point an inch or so lower than where you want the decoration to hang. Now bend the end of the wire up to form a small hook.
That's it. You've made one hanger. Repeat as needed.
Step 3: Handling Corners
The process is slightly different for corner posts. The wire coming across the top of the railing does so diagonally to place the hook at the outside corner.
Step 4: Using, Removing, and Reinstalling
Using the hangers is simplicity itself. simply drape or hang the decoration on the hook that you fashioned in front of the railing. You may want to pinch the hook mostly closed after hanging the decoration to keep it from blowing off of the hook. The weight of the decoration keeps the spindle loop firmly pressed against the spindle.
To remove the hangers, remove the decoration and then tip the hook up towards the railing. This will tilt the partial loop that is around the spindle or post. Twist the tilted hanger to the side to release the partial loop from around the post. The hanger can now be lifted from the railing and stored until it's needed again.
To reinstall, reverse the removal maneuver. Put the spindle loop behind the railing between two spindles. Angle the loop in front of and around a spindle. Pull the hook down in front of the railing.
