Introduction: Easy Distance Detector
This Arduino Project is an easy distance detector included with code.
The idea comes from https://www.instructables.com/id/Simple-Arduino-a...
Description of project:
When the further an object is to the sensor, the more LED lights will light up. Every LED lights up, it means that the object is 5 units away from the sensor. The maximum distance this project can detect is 45 units away.
To make this project, please prepare the materials:
glue (Any Type)
markers
cardboards
red LED light bulb *1
green LED light bulb *8
Arduino Uno (Leonardo) board
USB cable resistors *9
jumper wires
breadboard
Ultrasonic Sensors *1
Tape
Step 1: Writing the Code
Link to Arduino below
https://create.arduino.cc/editor/joseph_ray_chen/0...
or
#define trigPin 13
#define echoPin 12
#define led1 10//改
#define led2 2//改
#define led3 3//改
#define led4 4//改
#define led5 5//改
#define led6 6//改
#define led7 7//改
#define led8 8//改
#define led9 9//改
void setup() {
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT); }
void loop() {
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance > 5) { //改
digitalWrite(led1,HIGH); //改
digitalWrite(led2,LOW);//改
digitalWrite(led3,LOW);//改
digitalWrite(led4,LOW);//改
digitalWrite(led5,LOW);//改
digitalWrite(led6,LOW);//改
digitalWrite(led7,LOW);//改
digitalWrite(led8,LOW);//改
digitalWrite(led9,LOW);//改
delay( 500 );//改
digitalWrite(led1,LOW); //改
if (distance > 10) { //改
digitalWrite(led2,HIGH);//改
delay( 500 );//改
if (distance > 15) { //改
digitalWrite(led3,HIGH);//改
delay( 500 );//改
if (distance > 20) { //改
digitalWrite(led4,HIGH);//改
delay( 500 );//改
if (distance > 25) { //改
digitalWrite(led5,HIGH);//改
delay( 500 );//改
if (distance > 30) { //改
digitalWrite(led6,HIGH);//改
delay( 500 );//改
if (distance > 35) { //改
digitalWrite(led7,HIGH);//改
delay( 500 );//改
if (distance > 40) { //改
digitalWrite(led8,HIGH);//改
delay( 500 );//改
if (distance > 45) { //改
digitalWrite(led9,HIGH);//改
delay( 500 );//改
if (distance >= 199 || distance <= 0){//改
Serial.println("Out of range");
else {
Serial.print(distance);
Serial.println(" cm");
delay(500);
Step 2: Constructing the Board
connect (via cables):
GND to negative (blue line) on breadboard
5V to positive (red line) on bread board
(LEDs)
Digital 2 to the long leg of LED1; short leg connect to a resistor then to negative (blue line)
Digital 3 to the long leg of LED2; short leg connect to a resistor then to negative (blue line)
Digital 4 to the long leg of LED3; short leg connect to a resistor then to negative (blue line)
Digital 5 to the long leg of LED4; short leg connect to a resistor then to negative (blue line)
Digital 6 to the long leg of LED5; short leg connect to a resistor then to negative (blue line)
Digital 7 to the long leg of LED6; short leg connect to a resistor then to negative (blue line)
Digital 8 to the long leg of LED7; short leg connect to a resistor then to negative (blue line)
Digital 9 to the long leg of LED8; short leg connect to a resistor then to negative (blue line)
Digital 10 to the long leg of LED9; short leg connect to a resistor then to negative (blue line)
(UltraSonic Sensor)
GND (on sensor) to negative (blue line)
Echo (on sensor) to Digital 12
Trig (on sensor) to Digital 13
VCC (on sensor) to positive (red line)
Step 3: Constructing the Outer Box
Prepare and cut out the cardboards:
(19*9)*2 pcs [front and back]
(19*13)*1 pcs [bottom]
(9*13)*2 pcs [sides]
(12*19)* 1 pcs [top]
Tape [top]
Optional:
Make holes or doors for wires or fixes
Labels
Step 4: Final Product
Yeah!
