Introduction: Easy Fifa World Cup Trophy
Step 1: Gathering Materials
For this project you will need tin foil, yellow paint, paint brushes, green tape, a tennis ball, double sided tape ,scissors , and a small fizzy bottle.
Step 2: Get to Work
Use the tape to mark where the bottle begins to curve diagonally as shown.
Cut the bottle at the top of the tape. And again about 3 cm above that.
Step 3: Make a Cone
Take a peice of paper and cut it into the shape shown.
Then roll it into a cone. And tape at the seams.
Step 4: Test
Put together your trophy should look like this:
Step 5: Paint the Tinfoil
Now paint the tinfoil yellow and leave to dry, before wrapping the tinfoil over the tennis ball.
Step 6: Back to the Base-ics
Take your base, the plastic ring you cut earlier, and wrap it in green tape. Then use your yellow paint to mark a ring through the middle. This will be the base of the trophy.
Step 7: More Tinfoil
Use leftover yellow tinfoil to make another cone shape, use you double sided tape to glue the two cone shapes together.
(I have cut a wave pattern into the top of mine in an attempt to copy the trophies patterns)
Step 8: Put It All Together
Put it all together :)
