Introduction: Easy French Braid
About: Hi! My name is Abby. I'm 13 years old, and I love crafts of any sort
Before we start I would like to say that this is my first instructable so bear with me. This is a very easy hair style that you can do to your doll(s), friends, I've even been able to do this to myself. (with difficulty) I am showing you on my doll because it's the easiest option.
Step 1: Braiding
To start off you need to comb out any knots in the hair, if you don't this will be almost impossible.
Now separate a small section on either side of the head. I am starting on the left and braiding to the right, but you can do it the other way too.
Then break that small section into thirds.
Start the braid by taking the left section and passing it over the middle section. Then take the right section and pass it over the new middle which used to be the left section.
Now I take the left section and add in a bit of hair from the large chunk to the right. Make sure you add the new hair under the other two sections. Then braid that hair in by bringing it over the middle section.
Then add a little bit of hair from the bigger piece to the strand on the right. Braid this strand into the braid in the same way.
Continue doing this until you run out of hair in the large right section. Then just braid the rest of the way down without adding in any more hair.
Step 2: Enjoy!
Thank you for reading through this, and I hope this was helpful to you. Since this is my first instructable please let me know what I should do better next time. Thanks!
