Introduction: Easy French Toast
Hello, in this instructable, I will show you how to make French Toast. This French Toast recipe is super easy to make, if I can make it then you can make it. If you have any questions or comments, put them down below and I will make sure to get back to you. Follow the easy steps, or watch the short video tutorial, or do both!
Enjoy!
You may print this recipe here if you like.
French Toast Recipe:
1 egg
2 pieces of thick sliced bread (whatever bread you like)
2 Tbsp of Milk
1/4 tsp of vanilla extract
Butter
Tools Needed:
Skillet
Spatula
Fork
Bowl
Shallow bowl/pie pan
Step 1: Combine Ingredients
First let's combine our egg, milk, and vanilla extract in a small bowl. Then using a fork or whisk we will mix them together really well.
Step 2: Dip the Bread
Now we take the batter and place it in a shallow bowl or pan. I like to use a pie tin. Shallow tupperware container works great as well. Then you dip your bread slices, making sure to cover both sides, and draining the excess back into the pan/bowl.
Step 3: Cook Them
Now we turn our stovetop on to medium to medium high heat. Then take a bit of butter once the skillet is hot, and coat the pan with it. Next, lay your batter soaked bread on the pan.
Step 4: Continue Cooking
Let them cook for about 1.5 minutes on each side, until they look nice and golden brown. Then take your same butter and while the top is still hot, put butter on the top of the french toast.
Step 5: Toppings
Now you just add whatever toppings you like!
Note: One egg makes about 2 french toast, so double, triple, quadruple the recipe as needed.
Step 6: Video Tutorial
Now enjoy your French Toast!
