Introduction: Easy Friendship Bracelets
Learn to make friendship bracelets! Get different thread, tape, and a friend to give it to.
Step 1: Thread
First, you'll need to choose your colors. Pick three. They should be cut to be wrapped around you wrist three times.
Step 2: Knots
Tie another half knot. This is called a square knot.
Step 3: Taping Time!
Take the loop off your finger and tape it to a surface. This will keep it stable.
Step 4: First Color
Pick which color you want first. Hold it in your right hand and the other two in your left hand.
Step 5: Over and Under
Lay down the two and put the one over them. Then pull your chosen color between itself and the two.
Step 6: Pull
Pull the loop all the way up to the tape/square knot.
Step 7: Repeat
Repeat steps 5 and 6 about 7 times.
Step 8: Switch
Now pick your next color and do 5-7.
Step 9: Repeat a Lot.
Do 5-8 until you have a half inch to an inch left on ALL strings.
Step 10: Tape Off!
Take off the tape now!
Step 11: Circles!
Now to make it a circle. Remember that loop? Well, tie a square knot with your loose string to that loop.
Step 12: Friends!
Now, give it to you friend! Easy, right?
