Introduction: Easy Fruit Freeze Dessert
Easy - tasty. What more does one need to say?
Ingredients:
- 8oz cream cheese
- 3/4 cup granulated sugar
- 3 bananas (diced)
- 12oz strawberries (diced)
- 1 cup crushed pineapple (drained)
- non-stick spray or butter
- garnish, if desired
Tools:
- measuring cups
- mixing bowl
- fork, knife, and cutting board
- strainer
- 9x13 freezable pan
- freezer
Fancy-shmancy tools:
- cookie cutters or molds
- wax paper
- spatula
Step 1: Prepare Ingredients
- Drain the juice from a can of crushed pineapple.
- Measure 1 cup.
- If you want to shred a fresh pineapple instead of using canned - go for it. But that doubles the effort of this easy recipe without adding any real value.
- Whip the cream cheese and granulated sugar together with a fork until it is smooth.
- Dice the strawberries and bananas.
- Mix the fruit into the cream cheese mixture.
Step 2: Freeze and Serve
If you don't want to over-complicate things, simply spoon the mixture into a pan and freeze it.
- Lightly coat a 9x13 freezer-safe pan with cooking spray or butter.
- Put the mixture into the pan.
- Freeze for several hours; overnight if its convenient.
- Scoop and serve. (Thaw at least 5 minutes before serving.)
Step 3: Fancy-shmancy Options
Special occasion? Molds or cookie cutters can make this dessert extra special.
Tip 1: The more intricate the shape the harder it is. All I have are dinosaur cookie cutters. As you can see, I had to use a lot of mint to create enough contrast to identify the shapes. Maybe just stick to stars and emoji faces.
Tip 2: Once you start cutting the mixture it thaws quickly. Pre-freeze a serving tray.
Option 1. Freeze the fruit mixture in the cookie cutter forms on wax paper. You'd need a lot of cookie cutters.
- Fill the forms on wax paper and freeze them on the cutting board.
- Peel the frozen forms off the wax paper and put them on plates.
- Remove the cookie cutters.
- Garnish, as desired.
Option 2. Freeze the fruit mixture in the pan.
- Use the cookie cutters in the pan.
- Use the spatula to place the cutouts on plates.
- Collect the excess in a bowl.
- wax paper
- spatula
But really, the only embellishment this dessert needs is a spoon. Enjoy!
