Introduction: Easy Guide to Fix a Table Lamp
About: Just making some projects.......
I would like to tell you the story that led me to do this, It started when I used to go to my table every evening to read stories but as soon as I switched on the lamp it started flickering. Sometimes it would stop suddenly, Which used to bother me a lot while reading stories and its battery also drained within a few hours. One evening when I went to read the story it stopped forever and after that I thought to throw it in this store room.
Recently I came across a contest in Instructables called Fix It Contest. This is the story that came to my mind when I saw this. Then I thought it is a very common problem so we could definitely fix this. That's what brought me to this project.
So in this project, we are fixing a table lamp and this is a simple guide that help you to replace your table lamp battery quickly and easily. No complicated steps or tools are needed—just follow these steps
Materials and Tools required:_
  • Table lamp (Not Working)
  • Screwdriver
  • Multimeter
  • Soldering iron or Soldering Station
  • 1* Battery 18650 (3.7v)
Step 1: Open the Lamp
  • Table lamps come in various designs, so take a moment to analyze how your lamp is assembled.
  • Use a screwdriver to remove the screws holding the lamp's casing together. Be gentle to avoid damaging the casing or internal components.
  • Carefully separate the casing, keeping an eye on any clips or additional fasteners that may secure it.
Step 2: Testing the Battery
  • Use a multimeter to test the voltage of the existing battery. The minimum required voltage for most table lamps is typically around 4 volts, so check if the battery is providing sufficient power.
  • Check for signs of a dead or malfunctioning battery, such as significantly lower voltage readings or irregular fluctuations in voltage when the lamp is turned on.
Step 3: Removing the Old Battery
  • Locate the position of the old battery inside the lamp. Keep in mind that the placement may vary depending on the lamp's design.
  • Use a soldering iron to carefully desolder the connections attaching the old battery to the lamp's circuitry. Take proper precautions to avoid damaging other parts of the lamp.
  • Ensure that the soldering iron is at the appropriate temperature and work in a well-ventilated area to minimize fumes.
Step 4: Checking the New Battery
  • Before installing the new battery, use the multimeter to check its voltage. Ensure that it meets the minimum requirement, which is typically around 4 volts for most table lamps.
  • Additionally, verify that the new battery fits properly in the designated slot and is compatible with the lamp's specifications. Ensure that the polarity markings match for correct installation.
Step 5: Installing the New Battery
  • Insert the new battery into the designated slot, ensuring it matches the polarity markings for correct installation.
  • Carefully solder the connections to secure the new battery in place. Take caution to avoid harming other components of the lamp.
  • Verify that the positive and negative wires are correctly connected to the new battery and fit them securely without any loose connections.
Step 6: Testing the Lamp
  • Without closing the lamp's casing, carefully inspect the connections and ensure there are no loose wires or solder joints.
  • Visually check for any signs of damage or irregularities in the soldering of the new battery.
  • Verify that the positive and negative wires are securely attached to the battery terminals.
  • Test the lamp for any issues such as flickering, dimming, or irregular light output.
Step 7: Closing the Lamp
  • Carefully reassemble the lamp's casing, ensuring that all components fit back together snugly.
  • Tighten the screws securely to hold the casing in place.
  • Double-check all connections and wires to ensure they are properly seated and secure.
  • Test it again to confirm that everything is functioning as expected.
Step 8: Conclusion:
Summarize the steps taken to replace the battery in the table lamp and emphasize the importance of regular maintenance for electronic devices.
Tips:
  • Always use caution when working with electrical components.
  • Double-check the polarity of the battery before soldering it in place.
  • Dispose of old batteries properly according to local regulations.
Step 9: Well Done
Congratulations on successfully replacing the battery in your table lamp! Take a moment to appreciate your handy work and the improved functionality of your lamp.
  • Keep this guide handy for future reference or share it with others who may benefit from it.
  • Enjoy your well-lit study space and continue exploring DIY projects to enhance your skills!
