Introduction: Easy Homemade Pizza
What I found was that this is fantasically easy to do, bakes rather quickly, and best of all it tastes great! I made this in preparation of my parents visiting, and it didn't last long with everyone digging in.
It's not delivery, it's instructables!
Step 1: Ingredients
1 tube biscuits- will use this for the crust.
1/2 bottle tomato based sauce (I substituted with alfredo sauce)
A bag full of shredded mozzarella
Your choice of toppings (I used sausage, pepperoni, and bacon)
The Tools you need:
A skillet (to prepare the meat), baking stone, rolling pin, and pizza cutter.
Step 2: Prepare the Toppings
One other note, while you have this on the stove, go ahead and pre-heat your oven.
Step 3: Shape the Crust
I took the biscuits out of the tube and slapped them all together in the middle of the cooking stone. This is actually the second time I have made this type of crust. I tried to shape it by hand the first time, and this does not work very well. For whatever reason the dough tends to tear instead of flatten out that way. So, I invested in a $5 rolling pin from the grocery store, and it works beautifully.
Basically, flatten them out and then add a lip around the edge to hold in the toppings. You want the dough to be pretty flat, because it will rise quite a bit when you bake it.
Step 4: Add Your Favorite Toppings
Put your cheese on top of the sauce and don't be quite as stingy with it. I usually use the whole bag of cheese. I didn't with this one because I had a lot of other toppings too. I also added a small amount of a three cheese blend on top of all that porky goodness.
The toppings- I went for meat lovers. pepperoni first, sausage, and finally the bacon. You can of course use whichever toppings your like best.
Step 5: Bake in the Oven
Step 6: Enjoy!
The pizza comes out looking all sorts of fantastic. Using my new crust method, the biscuits actually still cook sort of separately and round out a bit, but that's okay. It makes it easy to cut very even slices.
A few observations- I think it works better to cut from the middle out, because the toppings tend to slide all around and will otherwise bunch in the middle. Also, the crust is very soft. Because of that, it behaves a bit differently than normal pizza crust. It doesn't stick when it is warm, but once it cools off it will stick to the cooking stone/plates/etc. Of course the easiest solution is to consume it all before it cools off!
This is sweet instructable 16, and it's also entered in the bacon contest. Ratings, comments and votes are most appreciated. And, like always, post a picture of your creation, and I'll reward you with a digital patch!
