DIY Easy Induction Heater // DIY Aquecedor Por Indução Fácil
Intro: DIY Easy Induction Heater // DIY Aquecedor Por Indução Fácil
In this instructable i'll be showing you how i made my induction heater in a very simple way with components from old electronics.
Nesse Instructable vou mostrar a vocês como fiz meu aquecedor por indução de uma maneira muito simples usando componentes reaproveitados.
STEP 1: Getting the Components // Achando Os Componentes
I removed most of the components from an old computer motherboard, i removed 2 power MOSFET's and 2 inductors, in another pcb i found a capacitor and the necessary resistors for the project, the diodes i had on my components bin, they were the only thing i had to "buy"
Retirei a maioria dos componentes de uma placa mãe velha de computador, 2 MOSFET's de potência, 2 indutores, em outra palca achei um capacitor e os resistores necessarios, os diodos tinha em uma caixinha de componentes, eles foram a unica coisa que precisei "comprar"
STEP 2: Necessary Components - Parts List // Componentes Necessários
The necessary components for this project are:
- 2 MOSFET's:
Found mine on an older motherboard, just search for the model number + datasheet on google and you should get the datasheet for your MOSFET, it needs to be a power MOSFET, and you get the pinout on the datasheet too.
- 2 Inductors:
Also removed from the old motherboard, the mobo usually has 2 inductors, these are the ones we want...
- 2 Resistors:
Found mine on the same board i found the capacitor, we need 2 220R resistors.
- 1 Capacitor:
Between 100-500nF should work, got mine from an old pcb that was lying around here.
- 1 Coil
I used 2mm thick copper wire to make a coil with around 10 turns on a 20mm pvc pipe.
- 2 Diodes
I used 1n5817 diodes (they need to be fast switching), that they were left over from an old project, that i bought too many of them
Os componentes necessários são
- 2 MOSFET's
Retirei de uma placa mãe velha, pesquise pelo numero dele + datasheet no google e você acha o datasheet, ele precisa ser do tipo power MOSFET e você tambem descobre a pinagem para o seu mosfet.
- 2 indutores
Também foram retirados da placa mãe, ela tem geralmente 2 indutores, são esses que queremos.
- 2 resistores:
achei os meus na mesma placa que o capacitor, precisamos de 2 resistores de 220R
- 1 capacitor
Entre 100-500nF deve funcionar, retirei o meu de uma placa velha que tinha por aqui dando sopa.
- 2 diodos:
usei dois diodos 1n5817 (precisam ser de chaveamento rápido), sobraram de um projeto velho que comprei diodos de mais.
STEP 3: Putting All Together // Montando Tudo
This step has no secret, just follow the schematic and then you're done, there are some pics of mine induction heater above
Special thanks to GreatScott for making a video about this induction heater and giving us a free schematic!
Link to the video:
Esse passo não tem segredo, só seguir o esquemático e está pronto, tem algumas fotos do meu aquecedor logo acima.
Agradecimentos especiais ao canal GreatScott por fazer um vídeo sobre esse aquecedor e disponibilizar o esquemático grátis.
Link do video (ingles):
STEP 4: Powering Up and Testing // Ligando E Testando
Now that you're done making the project, you can power it up and test, for power you need 12V at about 7 Amps (i used notebook battery cells), to test if it works, put a metal (preferably iron) object inside the coil and see if it gets hot, if it gets, then your project was a success!
Agora que o projeto está pronto, você pode ligar ele e testar, é necessario 12V com mais ou menos 7 amperes (usei celulas de bateria de notebook), para testar se funciona, coloque um objeto de ferro dentro da bobina e veja se o objeto esquenta, se esquentar seu projeto foi um sucesso!
7 Comments
si_list 7 years ago
itsmescotty 7 years ago
your schematics are a work of art and your printing is exceptional. I couldn't do that well when I took drafting in school..
LucasT_ 7 years ago
Yes, no problems. If you leave it on for a very long time i recommend using heatskinks on the MOSFET's
klauson 7 years ago
LucasT_ 7 years ago
Swansong 7 years ago
Thanks for sharing!
LucasT_ 7 years ago
You're welcome!
