Introduction: Easy Infinity Stones Made of Hot Glue
Hello, Marvel fans... As we all know... The "Infinity Stones" are again in action after the 8th episode of the 'What If' series..... Ultra vision now posses all the infinity stones... And the multiverse is in great danger... So it's time for us to do something....
If you also want to join the intergalactic fight to save the multiverse.... You should also have a set of the Six Infinity Stones....
I am The creator.... I am your guide through these vast new projects.... Follow me and dare to face the unknown, and ponder the process.... Of making the DIY Infinity Stones....
Step 1: Things We Gonna Need...
For this very easy one-day project... We will need very basic tools and items... Just gather these followings
- Hot Glue Gun (at least a 60 watt one is recommended)
- Clear Hot Glue Stick (take at least 7 sticks)
- White small LEDs... ( SE 186 1)....(you can also use the LEDs with 6 different colors.. If available)
- Small slide switch /or any small switch
- 6 piece 3-volt lithium battery (cr2032)
- Battery holder(if available and if you want to use the stones in long term.. Then it's a must for replacing the batteries)
- Soldering tools
- Glass paint
- Small rocks(I got mine from a local pet fish shop)
- Heat gun... Or any small flame torch or lighter
- Some extra tools and items... (whatever available)
My build video guide...
Step 2: Making the First Layer
Take some masking tape... And stick some on your work surface... It will help you to remove the pieces later easily...
Pour some hot glue on the surface... Let that cure...
Make a total of 6 of these... With one in big size...
Add a second layer on the top and let them cool down also...
Step 3: Painting the First Layer...
After the pieces are cold... Remove them from the work surface..
Now take the Glass paint and apply some on the pieces...
For the...
- 'Mind stone' use Yellow paint...
- 'Reality stone' use Orange paint...
- 'Space stone' use Blue paint...
- 'Power stone' use Violet paint...
- 'Soul stone' use Red paint...
- 'Time stone' use Green paint...
If you see the paint isn't well applied... Use 2 layers...
Step 4: Attaching LED Light on the Battery
Firstly bend the positive leg of the led... And soldier the negative end with the negative terminal of the battery... If you are using the battery holder... Then solder with the corresponding metal piece...
Whatever you do... Make sure to not overheat the battery... Otherwise, the power of the infinity stones will be destroyed π¬)
Step 5: Adding the Switch...
Similarly.. Attach the other end (positive end) with one of the pre-bent legs of the switch with some extra wires...
Also if you are using the holder thingy... Then you have to replace the switch in a suitable place...
Then soldier the other terminal with the positive terminal of the battery...
After the connection is done... Make sure to test everything for any possible loose connection and other faults... And check if the light is turning on properly...
Step 6: Sealing the Lights
Now... Take some hot glue... And seal everything as shown in the picture... It's because we don't wanna damage any connections later...
Step 7: Add Extra Layers of Glue on the Pieces...
Now... Add some more layers of glue to the 6 pieces... In order to make them thicker.....and it's the preparation for the next step...
Add 3 thin layers or 2 thick layers of glue...
Let those cure... And repeat the process for all the 6 pieces...
Step 8: Heating the Glue and Placing the Rocks...
Now.. It's an interesting step...
Heat the top surface of the piece or stone with the heat gun or flame... Until it gets a soft stage... Don't overheat...
Now carefully place the small rocks on the top surface with fingers or Tweezers...
Make sure to add them neatly and don't press too hard...
Let the piece cool properly... Don't rush... It's an important step...
Step 9: Remove the Stones...
When the glue is set again... Gently remove the stones... You will get a nice organic look on the pieces... If you aren't satisfied with the result... You may have another go... Stop when you are happy...
Repeat the process for all the stones...
Step 10: Attach the Top Piece With the Light Portion...
Now... Apply some more glue under the pieces... And attach the light battery contraption with the top surface...
Add some more glue to finalize the shape... Also, use the same previous methods to imprint the texture on the sides of the stones...
Step 11: Final Painting of the " Stones "...
Now it's the final Painting time... Take some more glass paint and apply two coats of paint on the stones...
Based on the quality or the look... The number of coats will vary...
If you want... You can even apply a clear coat on top of the stones...
Step 12: It's Done..... and My Own Thoughts π...
And this is the process of making your very own Infinity Stones...
And you will be able to join the anti-Ultron force...
There are lots of space for improvement in this project... We can make the body with resin... And can use a smaller battery... Or even use a wireless power transfer system to make them even movie-accurate...
I'm planning to make that version very soon... With more marvel-related projects... Like MK 50 arc reactor and others... I'm currently working on the Captain America shield... Let's hope... It will be finished before Halloween π¦
... Thank you so much for having a look at my project... Comment your thoughts down here... I will be glad to hear your opinion and thoughts... Every criticism will be accepted as an improvement knowledge for me... So don't hesitate...
I will be back with many more awesome projects... Until then... Stay creative... I will see you next time π...
And a great thank you to Instructables for giving me such a great opportunity to show my projects to the world...
For more details and a full video tutorial you may also go to my youtube channel where I will upload the whole process from start to end with more details...(as soon as I can finish the editing...)
Thanks for having a look at this project... Pls vote for this Instructable and also subscribe to my channel for more upcoming content...
subscribe to my youtube channel "Infinity workshop".
**Follow Infinity Workshop
Facebook: https://www.facebook.com/InfinityWork...
Twitter: https://twitter.com/InfinityWorkDIY?s=09
Pinterest: https://in.pinterest.com/infinitywork...
Instagram : https://www.instagram.com/infinity_wo...
Instructables: https://www.instructables.com/member/...
Consider supporting my channel by giving like, share, comment & Subscribing
#Infinity_Workshop Thanks for supporting...
Step 13: A Small Gift for My Audience... π
This is a meme... I made back in 2019.... Hope you will like
