Introduction: Easy Install Jeep Wrangler Rear LED Pod Light
Jeep has been the premier brand of motor vehicles for outdoor utility. It has the torque to tread any terrain and has powerful headlights for high visibility in the darkness. However, you can maximize your light output if you want to add more utility or make your Jeep unique from others. You can start with the single or dual LED pod light fit for a 2007-2017 Jeep Wrangler!
Here is how to easily install the Jeep Wrangler over-3rd-brake lamp LED pod light kit.
Step 1: Thread a Spring Washer Through the Included Screw. Put the Screw Onto the Base Bracket.
Step 2: Secure the Base Bracket Onto the LED Pod Light by Threading the Hex Screw Through the Nut Inside the Pod Lamp.
Repeat steps 1 and 2 if you are installing two Jeep over-3rd-brake-light LED pod lamps.
Step 3: Mount the LED Pod Light(s) Onto the Main Mounting Bracket.
Use a flat washer and nut to firmly secure the LED podlamps to the metal mounting bracket.
Step 4: Extend the Wires to Your Existing Reverse Light. If the Wire Length Is Insufficient for You, You Can Purchase Longer Wires at Your Local Hardware Store.
The LED pod light for your 2007-2017 Jeep Wrangler is as powerful as many of our other trucking lights and has multipurpose functions. Instead of extending the wires to your reverse light, you can do so on other parts of your car to serve as a fog light or an off-road searchlight.
